Question about John Deere Garden
Replace John Deere 17hp Kawasaki Starter solenoid
17hp kawasaki engine
SOURCE: I have a John Deere 265 mower.The problem I have
I fixed this problem myself. This alternator had a diode in one of the wires, just take it out,problem solved.
Posted on May 21, 2009
rwvanlue
  • 486 Answers
SOURCE: John Deere Gx75, kawasaki 9hp motor- oil in carb!
A very common problem with the GX series with Kawasaki engines. The carburetor 'inlet needle' sticks open and fills the crankcase with fuel. When checking the oil, it can be difficult to see the gasoline and the level appears to be OK. Remove the dipstick and smell the oil, you may detect a gasoline smell. Also, drain the oil, and you may find much more fluid than you expect.
The solution on newer mowers was to install an 'in-line' shut-off valve to keep the fuel from syphoning into the carburetor. The inlet needle and seat in the carburetor is NOT replaceable, so a new carburetor is the ultimate solution, but VERY expensive. Installing and using an in-line shut-off valve is more affordable.
Also, this situation is common when machine is transported on a trailer, as the bouncing causes the needle/seat to leak. When transporting, always turn off the fuel supply to the carburetor.
Posted on Nov 08, 2009
rwvanlue
  • 486 Answers
SOURCE: Starter solenoid on John Deere (Kawasaki) 17 hp engine
It hooks onto the fork.
NOTE: Remove the plunger from the solenoid.
Move the gear to position the fork as close to the solenoid plunger as possible.
Hook over the fork,
Re-insert plunger into solenoid
'a light film of grease could be applied to the plunger, but not TOO much'
Posted on Nov 20, 2009
suzukiracing
  • 200 Answers
SOURCE: i have a john deere 325 with a kawasaki 18 hp v
Try adjusting the deck height up a little or start a the carb.
Posted on Jul 19, 2010
SOURCE: My John Deere 345 dies for no apparent reason
You have dirt in the fuel tank and it sucks the dirt up on the filter that is attached to the pump. After the machine stalls, the dirt falls off and it will restart and run for a few min.
Posted on Dec 31, 2010
John deere x540 with140 hours. Jump started from storage and cut 2 hours without issue. would not crank back up. Installed new battery and checked fuses. Lights and all come on but will not crank.
would not crank Chet, Relay,Solenoid or starter may be defective, give the starter a sharp bang with a hammer, to see if it is stuck.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Test lawn Mower Solenoids
How To Test Solenoid with Taryl
Electrical System Troubleshooting for Lawn Tractors Mowers
JOHN DEERE KAWASAKI RELAY
Mar 30, 2016 | John Deere Garden
17hp kawasaki v-twin loses power when under load
You may have a bad ignition coil. Your carb also may need to be taken apart and cleaned real good. You can find alot of good troubleshooting tips on google or youtube as well.
Feb 19, 2014 | John Deere Kawasaki K Series Air Cooled...
I have john deere lx188 rideon mower when i engage the pto the engine cuts out.
This sounds like a seat micro switch problem, make sure the block connecter is fully home and the switch depresses when you sit in the seat, if all else fails replace the switch
Dec 09, 2012 | John Deere Starter Tractor Lx188 Kawasaki...
Replace starter solenoid on John Deere Lx277 Kawasaki Twin V17Hp engine
the way that its held together you need to take the starter apart to get the drive fork off
Jun 10, 2012 | Garden
A,b,g Tractor Carburetor Float Dltx10: i had my john deere riding mower running then shut...
My John Deere only starts with a hammer. I have the Kawasaki engine and it is famous for bad starters, so I carry a hammer and tap on the bolt when I want to start it. So, you either have a bad solenoid in your starter, or the contacts are dirty, battery connections are dirty. Or the battery is dieing. Check it out. Hope this helps.
May 07, 2010 | John Deere A,b,g Tractor Carburetor Float...
What Engine Model Number is in a John Deere LT166
http://www.deere.com/en_US/govsales/purchaseguide/PDFs/124_125.pdf
Will give you all the info you could need about the LT 166.
The LT166 uses a 303777 Briggs & Stratton Engine
The LT180 uses a FH500V-AS32 Kawasaki Engine, 4 Cycle
The LT190 uses a FH580V Kawasaki Engine.
The LX289 uses a FD501V-DS04 Kawasaki V-Twin Engine.
The X354 uses a FH721V Kawasaki with 4 wheel steer.
Hope this helps.
Apr 13, 2010 | Garden
Hook over the fork,
Nov 20, 2009 | Garden
Cam shaft is not turning when i crank engine model 425 john deere
I'm guessing you have a 7-10 year old Kawasaki engine with the plastic cam gear, that is missing teeth.
Kawasaki has a service bulletin on this,they have changed to a steel gear. your Kawasaki or John Deere dealer will have that info.
Sep 19, 2009 | Garden
Garden Logo
55 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
