Question about Onkyo Audio Players & Recorders
My onkyo HT R590 produces a humming noise
HDMI cable going from out port to Samsung TV HDMI 1 makes a humming noise. Tried 3 different HDMI cables and ports. Remove cable, no more hum.
SOURCE: hum niose in my onkyo tx-sr804
Hi there, sounds like you have a ground loop happening there. Check out ground loops in google to get some tips. What you should try is use one wall plug for everything (with an adapter on it) and check that none of your other cables are damaged. try find new cables and put them in place of the old seemingly fine cables.
Posted on Oct 06, 2007
  • 6 Answers
SOURCE: Hum from speakers
I suspect an open ground or bad cnnection in your hdmi cable to the amp from the sat.A hum is very indicative of that situation
Posted on Jan 09, 2008
taran_2005
  • 10515 Answers
SOURCE: No surround sound from my PS3 through the Onkyo 5100. Video OK
Unfortunately only the higher end Onkyo Reciever pass audio over HDMI for sound. 605,705,805,905 exc. Your reciever will carry Video over HDMI but you will need a digital optical cable for sound.
thanks.
Posted on Jan 24, 2009
kel1guy2002
  • 3740 Answers
SOURCE: I cannot get video signal from my Samsung p1590
I think this one is for the Onkyo wizards:
I would write them via email here:
http://www.onkyousa.com/feedback_form.cfm
1-800-229-1687
However I did find this 2 page hookup manual with nice notes at link listed below that may help you solve the mystery:
(seems you may have to assign the digital input)
http://filedepot.onkyousa.com/Files/QuickHookup/TX-SR606_QSS_En_A.pdf?CFID=918117&CFTOKEN=40624545&jsessionid=f0306ea8a0d68bb60a49102e3e5510576756
Assigning the Digital Input
If there’s no sound, you’ll need to assign the digital inputs as
necessary using the setup menus on the TX-SR606’s display.
If you connect your DVD player to the AV receiver’s COAXIAL 1
DIGITAL IN, and your cable/satellite receiver to the COAXIAL 2
DIGITAL IN, as shown, it’s not necessary to assign the digital input.
The onscreen setup menus appear only on a TV that is
connected to the HDMI OUT. If your TV is connected to the composite video or S-Video MONITOR OUT, or the
COMPONENT VIDEO OUT, use the TX-SR606’s display when changing settings.
Thanks for using FixYa!
Kelly
Posted on Feb 19, 2010
SOURCE: onkyo ht-r960
I had the same problem at 1 year after purchase. I was upset. In addition to looking here, I also emailed the company. They took a month to get back to me, but their solution worked perfectly.
"Try resetting the unit by pressing VCR/DVR and the standby/on button at
the same time on the front of the unit while it is turned on. The unit
will display CLEAR and shut down. All settings will be erased. "
All my components connect without any problem now. Hope this helps.
Doug
Posted on Jan 17, 2011
Onkyo receiver is not starting up hdmi from receiver to tv
run an HDMI cable from TV direct to DVD or other HD source instead of going through Onkyo. If it works, you have a bad HDMI output on the Onkyo. If not you may have a bad cable or a bad port on TV. Then try a different HDMI input on TV.
Jan 15, 2013 | Onkyo Tx-nr616 7.2 Thx Certified Network...
HDMI ports CB/SAT and Aux do not work on HT-R670
Check your setup menu and make sure that the cbl/sat and aux functions are set to look at the hdmi jack and not another type of input like analog, optical, etc.
Jan 03, 2013 | RCA Onkyo Ht-r670 7.1ch Receiver From The...
No Audio in HDMI THRU Onkyo HT-R380 Receiver
Hello, I am sorry about your issue. I suggest that you contact us at 800-229-1687 option #3 so that we can troubleshoot with you. Thank you, Onkyo USA
Mar 03, 2017 | Onkyo HT-S3300 Theater System
Sound from Onkyo CD player well and fine. Then connected the Samsung DVD HT-Z310 to Video3 (L/R audio in, V-in from L/R Audio out and V-out of Samsung) but no sound or nor video on TV? Tried to fix it...
What am I missing here?
There are a lot of models mentioned in this post. What are WE discussing?
* A Samsung HT-Z310 is a Home Theater System.
* An Onkyo TX-DS777 is higher-end AV Receiver that DOES have a Video 3 input which accepts composite video and analog audio.
* An Onkyo CD player is irrelevant to the TV sound in any scenario.
* Unnamed TV.
I don't see any path in your narrative that would carry audio TO the TV. Is there an unmentioned HDMI cable in here somewhere? I see no other audio outputs on the HTZ.
Are you running the HT-Z310 through an Onkyo receiver to somewhere (?) else?
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Samsung-HT-Z310-Home-Theater-Systems-manual/id/23122dj393/t/2/
The fewer hops and inteconnects a given signal experiences between its source and your senses, the better. I always run the BEST video from any source to the TV first; the best Audio to the BEST audio electronics. If that helps.
Apr 03, 2011 | Onkyo TX-DS777
Cable TV blinks on and off when connected to my Onkyo receiver.
I have the same problem.  It only occurs with my HD DVR (HDMI cable), not my blue ray (HDMI cable), or my xbox and wii (component video).  Video and audio cutout is random and drives the family nuts.  I am desperate for a solution.
Mar 21, 2010 | Audio Players & Recorders
Picture sound blackout (blink) when cable box/receiver HDMI used
Onkyo service told me, the second timethat I called them, that there is a known HDMI handshake issue with Motorola and Atlanta Scientific cable boxes. The only solution, and it was a solution, is to connect the box through the HDMI 1 port ONLY. All the other (2,3,4) result in blinking/dropping of signal. I did this, changed the cable/satelilte setting to HDMI 1 and all is well.
Apr 12, 2009 | Onkyo TX-SR705 Receiver
What is the best audio configuration with this setup?
You can't just plug in optical cables. Both the TV and amp have to be adjusted to allow the different type of signals to pass. I have an Onkyo receiver myself and you have to set the sound type up for each input. It's a bit tricky to do without a manual, but you can probably download one for free if you have lost yours.
Mar 12, 2017 | Onkyo HT-S5100 Theater System
Mitsubishi HDMI connection trouble
I have the same issue with my 73". Rather then going over all of my connections and equipment I'll just say htat I feel your frustration. I have been on the phone with Mitsubishi directly and it appears as though they have a free software upgrade that should address this problem. If you call 1-800-332-2119 and press 4 in the menu you will get someone to help you. Be patient. They will make you go through all of the fixes that you have already tried. They will mail you a flash drive that goes right into the front USB port of your TV. I hope this is of help. Good luck.
ret4good
Jan 04, 2008 | Mitsubishi WD-73833 73" HDTV
Onkyo HT-SR750
Check out Onkyo's website: The HT-SR 800 description says "a separate audio connection is necessary" Maybe it is true for the --750 too.
Jan 01, 2008 | Onkyo TX-SR605 Receiver
24 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
