Samsung AK59-00145A
Can't change tv channels
I have direct tv and accidentally changed the channel on the Samsung tv manually now I don't get my direct tv what is the defalt channel fo the samsungg
Press the last channel view button if you did that only the once, it should go back to the channel it was on prior to the "accident channel". I hope this helps, Jesus loves you, John 3:16-17 (KJV)
Jun 21, 2018 | Samsung Televison & Video
How do I retune my Samsung smart TV 40"with 3D
Country (Area)
Broadcasting > Channel Settings > Country (Area)
Select your country so that the TV can correctly auto-tune the broadcasting channels. This depends
on the country or region.
When the PIN input screen appears,enter your 4 digit PIN number.
Digital Channel
Change the country for digital channels.
Analogue Channel
Change the country for analogue channels.
Manual Tuning
Broadcasting > Channel Settings > Manual Tuning
Scans for a channel manually and stores in the TV.
If a channel is locked using the Channel Lock function, the PIN input window appears.
This function depends on the country and region
Page 147 of this User Manual located on this page will give you more information. (Sorry it wouldn't let me link the PDF manual directly)
UE40H6240AK UE40H6240AKXXU Support SAMSUNG UK
Sep 09, 2014 | Samsung 40" 1080p 3D Slim LED Smart TV...
I have a Samsung LN55B650, and cannot use the remote to change channels, hav eto use cable remote. I change to TV mode, and program in channels, but that option is not available once I switch to HDMI2,...
OK the cable box remote is the only one that can change channels in this case. because you are using the tuner in the cable box not the TV.
all you need the TV remote for is to turn the TV on and off and turn the sound up and down. if you used the cable input on the TV then the tv remote would be used to change the channels.
Dec 25, 2010 | Samsung LN55B650 55 in. LCD HDTV
Samsung tv power cycles when I get to higher channels pass 40. I attempt to change channel. Doesn't change and then front led blinks, tv screens goes blank, led flashes again and then screen is normal. I'm...
We have a similar problem when changing channels/surfing, the TV will begin to power cycle, until you unplug THE CABLE TV input, then it will turn on again and stay on as you rehook the cable and change channels....till it decides to do it again, DTV channels seem to trip it up, but not sure....if I leave it on the same channel it will run for days. Yep and the cable TV is grounded outside
Dec 19, 2009 | Samsung LN40A630 40 in. LCD TV
Cannot change channel to a 2 digit channel eg.
some remotes used to have a key to switch between single or double digits marked ( -/--)
Oct 27, 2009 | Samsung TV Remote Control
Channel stuck problem
How long does it take (in seconds) before it changes teh channel? Because some TV's, if you have more than 10 channels, have to wait before they change because you might want to change to a higher channel Example:
suppose your TV has 99 channels but your remote has only buttons from 0 to 9. So if you want to switch to channel 7 the TV waits a little before it actually switch to 7 because there might come another nuber after the 7 as the TV doesnot know what channel you wants. 2 to 3 seconds should be the maximum delay.
If it takes more time, check if this can be changed in the menu, often there is a delay possibility in the setup menu.
If teh delay is over 4 seconds and you still have warranty on it, just return it to the vendor.
Jan 16, 2009 | Samsung 21" FLAT CRT COLOR MONITOR
Change TV channel on SAMSUNG DVD-VR350
Hello Giancarlo, You'll have to use the projectors remote for T.V. tuning. I don't think the samsung DVD remote will operate your projector or your T.V. channels, will it? If it does, You just have to switch the input button on the remote to change between T.V. and Video. I hope that helps.
Jun 02, 2017 | Samsung DVD-VR320 DVD Recorder/VCR
Old tv samsung
try to check your audio video chord check it if it is open. you didnt mention if your tv has video channel (tuner). if your tv video channel is o.k then the problem of your tv is in the video switcher inputs. in this case you need a service technician.
Mar 05, 2007 | Samsung TX-P3264 32" TV
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
