Question about Jet 330043 PC-Board
The motor stop after a few minutes of operating
  • 1,443 Answers
You have a bad one then needs to be replaced
Posted on Dec 17, 2015
Vacuum turns itself off after 5 minutes of operating. The hose had a little matter in it, but wasn't clogged, and the filter indicator is green. It was cleaning the carpet just fine before it stopped, the...
The motor may have a thermal protect feature built in. Opens circuit when too hot. This is to protect motor and to prevent a fire. If you can check for lint build up around motor. Also, motor could be on it's way out.
Sep 28, 2013 | Hoover UH70120 WindTunnel TSeries Rewind...
Miele brush bar not spinning
Either the touchpad is defective, or the motor is bad.
May 11, 2012 | Miele Vacuums
Got this Heritage II Kirby vacuum that when running for about 5 minutes it will stop and smells like burning from the motor. Is the brush out needing repair or something else.
It sounds as if the carbon brushes in the motor are badly worn and will need replacement. DO NOT operate the vacuum in this condition or you may damage the motor armature beyond repair.
Jul 26, 2011 | Vacuums
It was working fine and them just stopped it is not that old and was not making noises HELP!!
Vacuum cleaners have electric motors in them that require proper airflow to pass over them to keep them cool. Many vacuum cleaners have a thermal (heat) sensitive shut off mechanism built in. This mechanism should prevent the burn out of the motor. If you run a vacuum too long with a clogged hose or clogged filters (especially bagless vacuums) or clogged bags, that is essentially choking the vacuum for air and not allowing it to breath properly. This will cause it to overheat and shut down. Most of the big box store purchased vacuums have very thin wires in the motor windings and can only do this a few times before the motor completely fails. If your vacuum has been shutting down, then cooling off and restarting after about 30 to 45 minutes, then shutting down after only a few minutes of use, your machine is probably clogged up or the filters are compacted.
Jul 05, 2011 | Vacuums
My Hoover U6458-900 shuts off after a few minutes of vacuuming. I let it set a few minutes and it will start up again.
It sounds as if the motor has overheated at some point, and damaged the thermal protector fuse in the motor compartment. Clean the filters thoroughly, change the bag, and try to operate it. If it still shuts down, the thermal protector will need replacement. ( Part # 47534032 )
Mar 02, 2011 | Vacuums
BB1100BdD stops after a few minutes operation. After an hr or so will run again for a few minutes
The motor is overheating and control features cause it to shut off to prevent burning it out. First check the bag. If it is full, remove and replace with a new one. A full bag can cause the motor to work harder, and thereby overheat. Next check the filters. A dusty filter will keep air from cooling the motor and again cause overheating. The HEPA filter needs to be checked also. Most filters can be dusted off. Some can be washed, air-dried, and replaced.Others will need to be removed and replaced. Your owner's manual should tell you how to clean filters. I hope this helps. If it solves your problem, please let Fixya know and post a rating for my solution.
Nov 19, 2010 | Oreck BB1100DB / BB1100DC Housekeeper...
After using the unit for a few minutes it cuts off.
The electric motor inside your Dyson has a built in over-current trip to protect itself (and you if it seriously overheated and caught fire). This normally automatically resets itself, however if the motor has just about had it, next time it is switched on it just trips again.
The primary cause of motors overheating is that the filters are not cleaned or replaced frequently enough. Dont be fooled by Dyson's "lifetime filters". They need to be regularly cleaned and replaced when necessary.
Replacement motors are available on eBay for about £25, however replacing one requires good DIY skills and tools.
Have a look at www.dysonmedic.com and see if you feel you can tackle it yourself. If not, take it to a repair shop or call the Dyson helpline.
Apr 17, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Why doe my hoover mach3 stop during operation? I have to wait until the moter cools down.Then i turn on the switch normal way.Then a few minutes latter it stops again.
Your Hoover is stopping because it is overheating. This is a sure sign that there is a blockage somewhere. Find the blockage and clear it, and that should solve the problem.
Mar 20, 2010 | Hoover U6630-900 WindTunnel Bagless...
Stops after a few minutes
Its overheating, so the TOC (thermal overload cutout device) is cutting the power to the motor to protect it.
Thats why it works when it has cooled down.
Check for blockages and make sure the filters are clean, if it still happens take to an approved engineer to check the TOC
Sep 20, 2009 | Hoover U6630-900 WindTunnel Bagless...
Motor stops running after a few minutes
One thing you could have a bad motor control, part #05408630, mounted by the motor, the other could be a bad variable speed control, part #05412914, it is on top near the back.
Dec 08, 2007 | Miele s558 Silver Moon Vacuum
Open Questions:
See all Jet 330043 PC-Board Questions
Jet 330043 PC-Board Logo
106 people viewed this question
Top Jet Vacuums Experts
domberg2008
Tom Chichester
Are you a Jet Vacuum Expert? Answer questions, earn points and help others
