Question about Dryers
Pelonis b346263 switch - Dryers
Need KSD-301-V thermo switch for a Pelonis HO-O218 oil filled heater
Amazon has lots of these thermostats available from 3 to 5 dollars. This is the most common thermostatic switch failure for the Pelonis heater . Go to Amazon and type in KSD 301 in the search area. The temperature rating of the sensor is approximately 305 degrees
Jan 31, 2015 | Pelonis Heating & Cooling
I need a switch for my heater,how do i order the on and off switch for my oil heater pelonis-model#Ho-157c0109
http://www.pelonis.com/service_first.htm go to this link and about the second paragraph down are the instructtions for ordering parts, getting ready to do the same thing myself.
Feb 09, 2010 | Pelonis WM-HO202C Oil Filled Radiator...
Looking for manual FOR PELONIS HEATER MODEL#
You can find your manual here:
http://www.pelonis.com/oilfill.htm
And for electric type you can get it here:
http://homeappliance.manualsonline.com/manuals/mfg/pelonis/hb211.html
May 15, 2009 | Pelonis Heating & Cooling
Pelonis model HO157C0110 will not turn on
Bypass the 3 way (hi, med, low) switch, unfortunately it'll always be in the high position when you do this. I have done this with one of my heaters and as long as the thermostat is working properly then it will work as it should on the high setting. I took the extra step of connecting the LED light to the bypass so I know when its on.
Just remember to turn it off you'll need to unplug it.
Oct 12, 2008 | Heating & Cooling
Dryers Logo
70 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
