Question about La Crosse Technology E. Howard Ambassador Radio Controlled watch
TX3U remote sensor displays OFL. What that? - La Crosse Technology E. Howard Ambassador Radio Controlled watch
Como hago para que me funcione el ensendido del tv
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
Aug 03, 2015 | Casio Watches
Why my watch not display or blank after keep for long time
As this is a solar powered watch,there is the PS (Power Saver) function.
If PS is ON (which is by default) display will become blank if watch stays in the dark for sometime.As you bring it back in light,display will be activated automatically.You can switch PS to OFF and have display activated all the time even in dark (not recommended) but in this case battery will run short quickly.And this watch needs power as it is a multifunction watch + atomic time setting.
Nov 10, 2013 | Casio PRG-130T-7VDR PRG-130-7 Protrek...
It keeps flashing file! And it's not logging anymore dives.
When the amount of available memory in flash memorybecomes low, "FILE" flashes in the lower left corner ofthe display in all of the submodes of the standard mode as well as in the dive mode. Thewatch automatically switches to the flash memory statusdisplay of the system monitor mode when the water sensor gets wet while thiswarning function is activated. Please note that although it is possibleto use the watch for diving in this state, log data may not be recorded inflash memory during diving. The file error warning function is also activated andadditional log data is not recorded if the duration of a single dive exceeds 2 hours or if morethan 15 dives are made in a single day. The file error warning function may also be activated whenthe water temperature during diving is low. It may not be possible to receive watchsettings by data communication while the file error warning When the watch has switched to the file error warningdisplay, perform the garbage collection procedure in the system monitor mode of the standardmode. Thedisplay returns to normal following completion of garbagecollection. Garbage collection begins when button (C) is pressedfor at least 2 seconds during the flash memory status display. • During the garbage collection operation, an alarmsounds and "G.C." is displayed on the display. When garbage collection is completed,"Done" is displayed on the display. • Garbage collection cannot be performed when"G.C." has changed to "NG" on the battery charge indicator or when the water sensor hasbeen activated. "Fail" is displayed on the disPress button (B) in the system monitor modeof the standard mode to switch the watch to the Flash Memory Status Display. Formatting Flash Memory Formatting of flash memory begins when button (B) is pressed while pressing button (C) simultaneously forat least 2 seconds.play at this time. theoxrysa@freemail.gr
Oct 11, 2010 | Citizen Promaster Cyber Aqualand Nx Dive...
Anyone know how to set time on a NY-1385 watch?
First, go to the time mode which displays week day, seconds and timeas opposed to calendar, seconds and time. To do so, touch and hold upper left sensor until the watch beeps. Then use the upper right button to switch to the proper time mode. Then touch and hold lower right sensor. This will send the watch into settings mode.
May 03, 2010 | Watches
Open display
This is not a documented function of the watch in the user manual to be found at http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2767.pdf Also I have this watch and it has never done this.
It sounds to me like either watch case is not closed properly or there is a fault with the CPU of the watch.
Jan 15, 2009 | Casio Triple Sensor Pathfinder PRG60-1AV...
Need an instruction manual for my Casio Triple Sensor watch
Hi there!
This site is quite useful - http://www.theusermanualsite.com/
Just log in with your Email & postcode to get a PDF of the information it holds.
If this assists you, Please rate as Fixya! (It's free)
Jun 21, 2008 | Watches
La Crosse Technology E. Howard Ambassador Radio Controlled watch Logo
35 people viewed this question
Top La Crosse Watches Experts
Thomas Perkins
Thomas Perkins
Chris Larocque
Are you a La Crosse Watch Expert? Answer questions, earn points and help others
