Teco air conditioner manual for model LS-LT1507V1
Manual
  • 4 Answers
SOURCE: I do not have the manual for my LG LS-D2461HS air conditioner
Look at
www.canbysales.com/support.htm
Servicemanuals
2005
sevicemanual LSC091PMA / LSC121PMApma
Posted on Jan 20, 2009
  • 659 Answers
SOURCE: No installation manual for new air conditioner
Here you go...........
http://www.frigidaire.com/support/ResultsPage.asp?strModel=FAS257S2A&User=&Search=Search
Posted on Mar 31, 2009
  • 70 Answers
SOURCE: installation manual required for teco split
Is the unit an AC only or a heat pump?
Wiring to the units should in the manual or online.
Both units proper house voltage to inside unit and outside unit.There will also be a two wire low voltage cable between thr two.This is so the inside unit can turn on the higher current draw of the compressor in the outside condenser unit thru it's relay.If you have a heat pump there will also be a set of two wires to the 4 way gas valve in the condenser unit to change from heating to cooling mode,a set of two wires to control the on/off function of the fan in the condenser unit when it needs to defrost and mayby a two wire set to a themal sensor in the condenser to sense if it is frosting up when system is in heat mode.
Try to get a wiring diagram and if you can't get to the point where you understand how to wire the unit don't guess! Call someone who knows wiring or call a pro, he can you money over the cost of replacing parts if unit is miswired.
Posted on Oct 06, 2009
  • 415 Answers
SOURCE: TECO AIR CON SYSTEM MANUAL
Perhaps the manufacturer can assist you with obtaining an electronic copy. Try this link:
http://www.teco.com.au/component/tecofaq/?search=show&task=showcatid&from=browse&divisionname=+Household+Appliances&categoryname=Air+Conditioning
Posted on Feb 25, 2010
SOURCE: cant get air con to work it is a teco air conditioner
Ours did the same. My husband checked the manual and found that the filters were FILTHY! The filter is at the front of the inside unit. If you still have the manual it will show you where. This fixed ours as it was NOT working at all!!
Posted on Jul 28, 2010
I have a teco split system which stopped working the stand by light has gone off too. Can I fix it.... Lost maual
call teco tech support and they will send you a free operator manual and probably refer you to a local service shop.
Jan 04, 2015 | Heating & Cooling
Teco air conditioner LS1826H fault code F2
F2 on this model means that the indoor unit pipe sensor has failed. You would probably need someone who is at least a licences electrician or preferably an Air con tech to repair this. You will need a new pipe sensor. Contact Teco Australia who can put you in touch with your nearest service Agent.
Sep 09, 2013 | Electronics - Others
Operating manual for Teco inverter air con LT1107V1
I couldn't find my manual for the split air con Could someone please tell me how do I find the manuals online?
Jan 21, 2012 | Peugeot Mana 850 Motorcycles
I need operating instructions for a teco air con model LT2424YS
I have an TECO Model 7K34STC, that has the two end bearing & housings missing from the opposite end to the motor.
Could anyone tell me of a parts supplyer in Florida U.S.A.
Please reply to
Peter Lawrence
brin4512@hotmail.com
Jun 28, 2009 | Heating & Cooling
Cant get air con to work it is a teco air conditioner
Mar 01, 2009 | Heating & Cooling
On your email you have the model down as LSC121PMA - this is not the model I posted my query on, it ws the LG LS-D2461HS, and no my query is not solved.
Dec 13, 2008 | LG LSC121PMA Split System Air Conditioner
Heating & Cooling Logo
82 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
