Question about Stanley Bostitch MIIIFN Flooring Nailers
Staples not going all in
Not going all in
The staples wont penetrate the paper - they keep bending before they go through the sheets.
Ensure the staples are the correct size. If you check the end of the stapler, at the bit where the staples are bent by being pushed against, there may be 2 different width of rexess for the staple to c go in and be compressed....if it is set to the wide setting change it to the narrow setting. THAT MIGHT CURE IT, IF THE PROBLEM PERSISTS TRY BEYING SOME BRAND NEME STAPLES SUCH AS REXEL
Jul 06, 2015 | Staples Office Equipment & Supplies
What are the best staples to use for upholstery
yes, yours are too narrow and the plunger grabs 2
Mar 05, 2015 | Staples Tools & Hardware - Others
The staples go through the material, but don't fasten or close on the back side
This is not a type of stapler that clinches the legs of the staples. There would have to be a lower jaw to do that. Like a desk top stapler has.
Nov 25, 2012 | Stanley TR250 H Heavy Duty Heavy Duty...
I bought a Powerfix Profi hand stapler from Aldi store but cannot get replacement staples. There is no support from their website
You can use about any replacement staples from a D.I.Y. store:
8mm staples or 12mm U-type staples or 10mm T-type nails
Nov 03, 2011 | Tools & Hardware - Others
Can't get the staples to go in. It's a sears
Pull out the part that loads the staples, turn the gun upside down, put the staples in the bottom of the gun and push the loader back in. It took me awhile to realize that you don't load them on the piece that pulls out of the gun.
Cheers.
May 10, 2009 | Tools & Hardware - Others
Arrow et2025Hd staples won't go flush
The material you are putting staples into is too hard for this little staple gun.
You will need a more powerful stapler, such as a staple gun that uses compressed air to drive the staples and where you can adjust the air pressure.
Apr 30, 2009 | Tools & Hardware - Others
Can't load staples
Fire the stapler with the load chamber open and down, see if anything falls out. Point it in different positions and fire it, just make sure it cannot fire anything at you.
Apr 18, 2009 | Stanley Tools TRE550 Electric Staple/Brad...
Refilling the staple gun
The staples do not go on the bar you pull back but directly into the bottom once you have pulled the bar back. I was trying to put the staples on the bar at the back and push them into the stapler.
Oct 10, 2008 | Arrow 8000 Power Shot Pro Staple & Nail...
SHARP STAPLES
For the AR-M335U/455U-they are AR-SC2,5000 staples                            AR-M550U/700U,N-they are AR_SC11 staples                     They are a box of three. Hope this helps
Oct 17, 2007 | Office Equipment & Supplies
Stanley Bostitch MIIIFN Flooring Nailers Logo
Top Stanley Tools & Hardware - Others Experts
John Trevino
yoopertech
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
