Question about Coffee Makers & Espresso Machines
Caffitaly S4 seems to be blocked with coffee grinds
Water will not come out in the front
Richie_asg1
  • 1036 Answers
SOURCE: Solis Palazzo - Coffee grinder seems blocked
Hi there!
This is most likely due to a build up of ground coffee at the edges, and the whole lot has become a solid lump.
Disconnect the machine and clean with a small stiff paintbrush.
This is caused by damp beans, or using dark roast beans, or keeping beans refrigerated. Often it is the coffee oil that causes it.
If there are beans in there and the unit is not rotating, please contact here again.
Thanks......Oh, and rate as Fixya! if it helps you.
Posted on Jun 19, 2008
  • 74 Answers
SOURCE: Grinder says no coffee beans after grinding, why?
does it realease the grinded coffe beans in the dregdraw with out using it?
if that is the case it a very small electricboard on the grinder that has stoped working or the connecter has fallen of from it.
Posted on Jul 11, 2008
SOURCE: Jura Impreza E8 - only water comes out no coffee
going to get it fixed.
Posted on Jan 11, 2009
EsWorld
  • 1618 Answers
SOURCE: Water flow problem
Check the coffee chute to see if its clogged. It is easier to use a small amount of white rice to clean your grinder, about a teaspoon.
Posted on Mar 11, 2009
EsWorld
  • 1618 Answers
SOURCE: the Saeco Incanto machine grinds away but no water or coffee
Are there any grounds in discharge tray and if yes are they wet or dry?
If they are dry then the machine has a water circuit problem. If they are wet then the brew unit is blocked or the grind settings need to be adjusted coarser.
Posted on Jun 30, 2009
Caffitaly manual
Hi I have a caffitaly modal so1hs/po1hs , I having a prom with mine , the water dos not go into cup I have cleaned it twice and still , it's doing the same thing need help please thanks Julie Donnelly
Oct 23, 2013 | Coffee Makers & Espresso Machines
Caffitaly coffee machine is continually beeping
The Caffitaly Machine Beeps when it needs Descaling...the reduction in the water flow is an indicator that your machine badly needs this maintenance procedure to be completed. Refer to Page 15 of your User Manual.
Sep 30, 2012 | Dualit Coffee Makers & Espresso Machines
Water not pumping out of coffee machine
It seems that the coffee solenoid valve is blocked or broken. Cofffe solenoid valve is the valve which open to deliver the water after the pump to the coffee shower.
Feb 17, 2010 | Saeco Talea Giro Espresso Machine
Will grind the coffee beans but no water passing
Either the grind is too fine or the brew unit is blocked at the screen.
Feb 05, 2010 | Gaggia Titanium Espresso Machine
Water not coming out of dispensing area, goes to drip tray instead Water comming out in drip tray instead of regular way
Try this, if the machine has a pregrind door(usually on the top front) then use the button to tell it you are using pre grind coffee, if water comes out the spout this way then the grind on the grinder is too fine, if it goes out the drain then the coffee passage is blocked, remove the brew unit and check/clear tubes, also clean the spouts on the door of the unit.
May 30, 2009 | DeLonghi Esclusivo Magnifica ESAM3300...
Water flow problem
Feb 22, 2009 | Solis Master 5000 Espresso Machine
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
