Question about Refrigerators
Our Kenmore side by side model 795.5881 is sticking on the water dispenser. It won't stop when we remove the glass from the water dispenser ? please help
Bgillespie
  • 89 Answers
SOURCE: Kenmore Refrigerator stopped dispensing water
Look up through the ice despencer on the front door of the freezer. Is the flapper door open? If so it needs to be fixed. If its not then try leaving the freezer door open for 3+ hours to defrost the frozen line in the door. If that doesnt work, the water valve must be changed.(located behind fridge, take off back cord board panel at bottom, the valve is blue)... GOODLUCK!
Posted on Dec 31, 2007
TheMobilian
  • 8220 Answers
SOURCE: Ice maker not working Kenmore model 106.55226400
Look for an ice cube lodged in the fingers IM. Get a hair dryer and melt that dude. No ice cube? Add some water to the IM mold. If it kicks out some ice but makes no more then you is gonna need a water valve. If it don't kick out no ice then you is gonna need a ice mold thermostat. Either one is very easy and cheap to fix. let me know Kimosabe.
Posted on Mar 06, 2009
  • 77 Answers
SOURCE: remove faceplate in door of a kenmore frig.
If you look at the bottom of the facial plate, underneath. There are two slots to insert a flat screw driver. You should be able to access everything once you take that off. Good luck
Posted on Apr 24, 2009
  • 77 Answers
SOURCE: remove faceplate surrounding the indoor ice/water dispenser
under the facial plate, if you get way down and look upward, you can see two slots to insert a flat screw driver. Pry it open and there ya go...good luck
SOURCE: kenmore side by side refrigerator
there is valve for each right at the water inlet, your valve is stuck or your coil is bad......get a new valve.
Posted on Dec 22, 2009
Electrolux fridge water dispenser won't shut off
Then I would assume that the micro switch that you press for water is defective and sticking. I am placing a=> 242100001 Dispenser Module to give you an idea to what I am talking about but if you have a model number for your Electrolux refrigerator I may could find a micro-switch that is replaceable, Thanks Sea Breeze
Aug 23, 2012 | Electrolux Refrigerators
I just changed out my filter on my side by side Kenmore yesterday. The ice maker still works...however, when I went to dispense water from the door when I pulled the glass away from the lever the water...
Your switch is sticking and could be you got debris in the shut off part of the hose when you changed the filter . But I'm guessing switch,exercise it a few times and see what happens.
Mar 28, 2011 | Kenmore Refrigerators
Kenmore refrigerator, has water dispensor on front, when you put the glass there to dispense it will not stop flowing, you have to bang the door shut
Sounds like the water activator switch is sticking. It may help to clean the area where the switch is including the hinge. Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Since shutting the door stops it the above is most probable but the water inlet valve on the back where the water supply comes in could be sticking.
Sep 01, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
TFX22CR GE refrigerator TFX22CRXFWW does Not dispense ice.
I had this problem with a similar refrigerator. The problem was the slide switch burns itself especially if you slide it from ice to water while holding the glass in to get ice and water into your glass. Better to slide it to ice, press the glass in to get ice, release the glass to stop the ice, slide the switch to water, then press the glass in again to get water. I "fixed" mine by removing the control panel and soldering some of the connections on the slide switch together so that we now have no crushed ice function, but the ice cubes work again. You can also replace the circuit board in the control panel to restore it to like-new operation. I could not find a place to order just the slide switch.
Not sure if this is the same problem with your unit, but sounds the same.
Dec 06, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Replacing water fitting assembly
water dispenser continues to run too long after removing glass
Oct 23, 2008 | Refrigerators
Water dispenser won't stop dispensing water!
Hi I dont have the knowledge of your fridge, but I'm just going to throw this idea your way , please forgive me if im wrong :)
Perhaps the problem is due to syphonage, the discharged liquids are creating a vacuum along the line.
Did you reposition the height of any supply hoses ? none of them should be above/higher the outlet source itself.
You could also try installing a inline reverse flow suppressor
(small plastic filter that only allows one-way direction of flow.
Jun 10, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore refrigerator water dispenser problem
SORRY TO SAY THIS BUT IT SOUND LIKE YOU HAVE BLACK ALGEA IN YOU WATER SYS WHICH IS GOING TO REQUIRE A TECH TO REPLACE ALL THE TUBING IN YOUR WATER INLET SYS TO GET RID OF IT. GOOD LUCK AND CONTACT APPLIANCE SERVICE CO. P.S. DON'T DRINK THE WATER OR USE THE ICE IT WILL CAUSE MEDICAL COMPLICATIONS
May 30, 2008 | KitchenAid KSRS25IL Side by Side...
Water or ice will not stop after removing glass.
Although I don't have this problem, I took my dispenser apart tonight for a different reason. Moving the lever with the glass actuates a mechanical switch. It's a really simple mechanism. If I were you, I would check to see if that mechanical switch is sticking. Maybe someone had a glass of soda or something sticky, which splashed up there when they got ice. That could be enough to gum it up.
Taking it apart was not tough. The plastic border pulls right off. Then the assembly that has the buttons and lights on it can be removed by pushing it downward enough so that it clears the plastic holders, and then you just pull the top edge towards you. At that point I unplugged the fridge so I couild disconnect some connectors. Then 4 screws gets the whole glass switch assembly out. You should be able to inspect the mechanical switch operation at that point to see if it is sticking.
Good luck.
May 22, 2008 | GE GSH25JFR Side by Side Refrigerator
Either your water tank in the fridge froze up, the waterline that goes up the freezer door from the bottom hinge froze, or the switch that your glass hits is damaged. Do you hear any humming or noises when you put your glass up to get water?
Oct 27, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
54 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
