Question about Dell SE198WFP LCD Monitor
Blue light on with blank screen dell SE198WFP monitor
I plug my dell SE198WFP 19 inch monitor up and a blue light is on the power button but does not blink and the screen is blank/black
    Problem Solver:
  • 5 Answers
It depends on what type of connection you are using. If you are using a VGA (analog) cable then you need to select that mode on your monitor menu. If you are using a DVI (digital) cable then you need to choose that mode on you monitor menu.
Posted on Jun 28, 2014
SOURCE: Dell E172FP 17 monitor keeps blinking
That sounds like the backlight inverter board. Check ebay for the board or a repair kit for it.
Posted on Oct 23, 2007
SOURCE: Dell Blinking Power Light
Just wanted to say Thank You for the info on this site. I had the same problem as previously posted. When powered up, the monitor showed a fast flash of the desktop and then went black, with the power indicator flashing green. I read the posts, purchased the capacitors and the 4 - 2sc5707 transistors through ebay. I ordered them on the 6th and rec'd them today. I only had one bad capacitor and one transistor that checked bad, but I ordered 5 caps and 4 transistors. When ordering the caps be careful of the height of the caps. I found this to be a problem because I ordered the 50v, 105 degree Panasonic caps that didn't fit with the enclosure attached, so I used the 4 good caps removed previously and replaced the bad one with a 470uf, 50v. 85 degree cap from Rubycon I found among my spare parts. Installed the parts and the monitor is working properly (for the last two hours) so I'm happy for as long as the repair lasts. Thanks again for the info.
Posted on Jan 09, 2009
  • 1684 Answers
SOURCE: Dell monitor shows blank screen, green power light stays on
You have a monitor with a common problem. After a few years some LCD monitorswill blow a power supply. The problem is caused by parts calledcapacitors overheating in the confined space of he monitor. If you aregood at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htmYou can take the back cover off your monitor and look for the bad parts,replace any that look like the pictues and your monitor should workfine. The capacitors do need to be installed with the correct + and -connections, note the stripe on the old one and insert the new one thesame way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Posted on Jul 03, 2009
  • 1684 Answers
SOURCE: Dell Monitor Problems
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Jul 17, 2009
  • 1684 Answers
SOURCE: Dell E172FPb monitor black screen green flashing power button
We have a dis-assebly and repair guide posted on our web site at:
www.ccl-la.com/monitor_repair.htm
The problem is usually the driver transistors, our guide shows where they are and what to replace to get your monitor back running again.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Jul 30, 2009
The screen goes black repeatedly,blue power light stays on
Check to make sure the signal cable is firmly connected in the socket or Check to see if the computer system's power is ON.
Check that the Brightness Control is at the appropriate position, not at the minimum.
Nov 01, 2009 | Dell SE198WFP LCD Monitor
Dell SE198WFP 19" LCD won't come out of standby
I went into the BIOS (with F2 during restart) and changed a value -- IIRC it was called something like "power management scheme" -- from the default S3 to the other choice, S1. Now the old Dell XP Dimension 2350 will go into and out of Standby correctly and the new SE198WFP 19" LCD will too.
Oct 05, 2009 | Dell SE198WFP LCD Monitor
Monitor Screen goes black every few seconds!
Check the capacitors on your monitors circuit board. If they have opened up at the top, they are fried. Buy new ones, make sure nothing has leaked from the old ones, and replace them.
Sep 26, 2009 | Dell SE198WFP LCD Monitor
Try the troubleshooting procedure here:
Click Here
If that doesn't work, the monitor has most likely failed and will need to be replaced.
Apr 20, 2009 | Dell SE198WFP LCD Monitor
Wide screen not active
wow maybe you should give dell a holler
Jan 24, 2009 | Dell SE198WFP LCD Monitor
Bank Monitor problems
Unplug the cable from your PC, if the monitor shows a test image, the monitor is fine and the problem is with your graphic card. If you dont see nothing on-screen after unpluging the cable from the PC, then the monitor in damaged. Send it to repair.
Jul 09, 2007 | Dell E193FP 19" LCD Monitor
Dell SE198WFP LCD Monitor Logo
170 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
