Question about Holmes Products Dryers
Holmes hasf1521 parts - Holmes Products Dryers
Red light keeps blinking
Hello, this is Ava with Think Crucial.
It looks like you may need to change your filters. It is advisable to change filters every 3-6 months for optimal use. When replacing your filters, make sure that the unit is turned off and unplugged from the power. Once filters are replaced, turn on your unit then press and hold the filter check indicator button for 3 seconds. The indicator light will blink 3 times and turn off, and reset the filter change timer.
You can purchase a wide variety of high quality Holmes replacement parts for your Holmes Air Purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.thinkcrucial.com/search?type=product&q=holmes
I hope this was helpful.
Ava B.
Think Crucial Customer Care
Aug 24, 2014 | Holmes Products Air Purifiers
When bar light is on level 3 what does that mean holmes air purifier
There are 3 settings for optimum air filtration. You can operate your Holmes air purifier continuously on the Medium (2) setting. It's rugged motor has been designed to give many years of use. For quieter operation (such as bedroom), select the Low (1) setting. When high levels of air polution are present, select the HIGH (3) setting to quickly circulate and filter the room air.
Ava B.
May 19, 2014 | Holmes Products HAP422-UC Air Purifier
I have a 16" black
Contact Holmes at: http://www.holmesproducts.com/warranty.aspx
This is a do-it-yourself help site that is in no way part of Holmes products.
John
Aug 31, 2011 | Holmes Products Dryers
Hi, I have a pedestal fan (16") for which am looking for spare parts. I need - fan blade (5 blades) - the clips that hold the base grill and the front grill Make: Holmes Model:...
Seriously?? It's a $30.00 fan. IF you could get parts for it, they'll cost you more that the original price of the fan, but I guess if you insist. Go here and call them or chat online, they'll tell you if parts can be had.
https://www.holmesproducts.com/fans/
Jun 09, 2017 | Holmes Products Dryers
Need new rubber tank gasket for Holmes humidifier Model HM4600
after scouring the INTERNET AND FINDING PLENTY OF SITES THAT WOULD SELL ME THE WHOLE CAP FOR 24.00. I MAD MINE USING SOMETHING FROM ace hardware THAT COST 2.50 Small suction cups with the hook [CDBL-7500S11] PART NUMBER 7500 .CAN BE MODIFIED INTO MAKING YOUR OWN GASKET. IT WORKED FOR ME ..REMOVE HOOK FROM SMALL SUCTION CUP. cut off nib with sharp pair of scissors. THEN DRILL HOLE THROUGH CENTER OF CUP WITH 7/64 DRILL BIT. re insert plunger part of cap through cap with spring and re- attach suction cup instead of gasket. MINE WORKS FINE ON A HOLMES 3700
woodinvirginia
Jan 23, 2011 | Holmes Products HM4600-U 11 Gallon...
IIcant find parts for the holmes heaters. Who carries them?
I have the same problem. I mean it keeps going off prematurely. The heating area is relatively clean and there is no reason for this other than the Thermal Circuit Breaker to be going bad.
I too have fruitlessly tried to find the part. It is made by Klixon and the info about it is as follows: 1NT15L-4165 It is a manual reset bimetal temperature circuit breaker. Mine says L86 L = Limit and 86 I believe represents 86 degrees Celsius which is about 187 degrees F for us Americans.
I found the Klixon people and they told me the part was not available through them; but only through Holmes themselves. So, I of course called Holmes Customer Service.
Turns out that I had a little spat with Holmes' CS Jerky... She informed me that Holmes does not sell parts and that the heaters they build and sell are not serviceable. So, I argued that they are irresponsible with regard to the environment. What, it's supposed to go to a landfill now?
But she insisted that this was so that people didn't start fires with their heaters. And she says that she has two young girls at home and wouldn't want anyone burning down their house and killing their family. So I guess after all that has nothing to do with her keeping her job by Holmes selling me another $79 heater, huh?? lol Yeah right!!! Because the guy at corporate would not want one of their heaters to start a fire. That wouldn't be an acceptable risk to make money. (Sarcasm, in case you missed it)
On another note... It's real unfortunate that you have to take the HQH307 completely apart to clean the heating area so as to not have the heater be a fire hazard. But I'm a risk to my family by taking the thing apart and then removing the two retaining screws out and two wire leads off to replace the malfunctioning part. WTF??? Since I can't get the part I suppose I could just bypass the circuit breaker. I know that's not a good idea.
Well, bottom line is, (can ya take a guess?), that I will not be buying another Holmes Heater EVER!!! Thanks Holmes...
Answer: As far as I know you cannot get the part.
If anyone has a lead on the part please let me know here.
Thanks, LightningMan
Nov 20, 2008 | Holmes Products HQH307 Compact Heater
Holmes HM4600HD humidifier tank
Mine dried out too. I could not find where to get the rubber valve seal for the tanks. Holmes does not list the part and when I called the rep told me they didid not stock the part. I solved my problem by purchasing thin rubber washers from Lowe's. They are 3/16 X 1 1/4 X 1/16 thick. The 3/16 hole in the center "snaps" on over the end of the plastic plunger just like the original. I had to trim the outside diameter with scissors to about 1" or using the old ones as a guide. Cost me $0.67
Nov 09, 2008 | Holmes Products HM4600-U 11 Gallon...
Dryers Logo
35 people viewed this question
Top Holmes Products Dryers Experts
Darial Jr Lasaria
Darial Jr Lasaria
Jay Finke
Jay Finke
James Coghill
Are you a Holmes Products Dryer Expert? Answer questions, earn points and help others
