Home | Danby | DDR586R Dehumidifier - 58 Pints Dehumidifier | Leaky Danby Premiere 30 ...
Danby DDR586R Dehumidifier - 58 Pints Dehumidifier
Problem for Danby DDR586R Dehumidifier - 58 Pints Dehumidifier
Leaky Danby Premiere 30 pint dehumidifier
By curtfromspac on May 07, 2009
I have a Danby Premiere 30 pint dehumidifier. It has been running well for one and a half summers in our unfinished basement. I have it hooked up to a hose that drains directly into our basement drain. The water drains out of this hose, however there is also a slow, steady drip coming from the bottom right-hand corner (same side as hose hook-up nossle) of the machine. I have checked the hose (plastic surgical tubing), and it seems to be securely attatched without any leaking. Does it have to do with condensation? The weather has been fluctuating quite a lot lately (20 degrees Celcius one day and 3 degrees the next). Any ideas?
Popular Solutions for Danby DDR586R Dehumidifier -
Questions and Unsolved Problems for Danby DDR586R Dehumidifier -
Do you recommend Danby DDR586R Dehumidifier - 58 Pints Dehumidifier?
Answer
Answer
i recently had a brown-out and have had damage to a number of appliances. this occurrance blew the... (More)
Answer
how could i use my ddr586r dehumidifier because i lost my instraction
Answer
Danby Dehumidifier Model # DDR586R Serial # 6763858666 (only 28 months old) - Does not collect water... (More)
Answer
tank does not fill with water at all. How to adjust humidty levels? what does the temp grad mean?... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Danby DDR586R Dehumidifier -...:
Top Dehumidifier Experts
Rank: Guru Guru
Solutions: 1493
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dehumidifier Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
