Question about Stanley Bostitch STB-MIIIFS Flooring Stapler
Staple not going all in the floor. Wood is 5/8 bamboo
Wondering if u can adjust this nailer
2 Suggested Answers
  • 885 Answers
SOURCE: which nailer do i need to nail down 5/8 bamboo
Stanley makes a foot, part number MIIIFOOT-KIT, for the MIIIFS flooring stapler that prevents scratching of prefinished floors.
Posted on Jan 20, 2011
Which flooring is better to use in kitchen : Bamboo floor or Wooden Floors?
Bamboo floor is not good with grease, so I would recommend the wood floor for that reason alone. However, bamboo is much softer on the feet, so if you stand a lot, and don't fry a lot then bamboo is the way to go!
Feb 23, 2016 | Building Materials
What are the differences between bamboo and solid wood floors?
Bamboo is much more environmentally friendly than solid wood as bamboo regenerates in time. Moreover, bamboo is harder than some solid woods such as red oak and black walnut.
Feb 06, 2013 | Building Materials
What is bamboo flooring?
Bamboo flooring is a type of flooring manufactured from the bamboo plant. It is considered to be wood flooring although it's a type of grass not wood. The most commonly used specie of bamboo is Mao bamboo.
The staples won't go fully into the Wood
1. The wood may be too hard for the staples to penetrate
2. The stapler drive spring may have ghotten weak
3. You may not be holding the stapler nose firmly against the wood while stapling
Jan 06, 2013 | Stanley TR250 H Heavy Duty Heavy Duty...
Which nailer do i need to nail down 5/8 bamboo prefinished floor i have the basic nailer for 3/4 flooring is there an attachment to add to it
Jan 20, 2011 | Stanley Bostitch STB-MIIIFS Flooring...
Staples wont penetrate wood and keep foldin up
are the nails proper for nailer? the gauge of the nail is important
Oct 02, 2010 | Stanley Bostitch MIIIFN Flooring Nailers
I rented a bostitch MIIIFN to install bamboo hardwood flooring. The nailer is splitting the tongue of the wood. Is there some type of adjustment that I can do to stop the splitting?
you do not use nails to install bamboo floor! EVER!
bamboo flooring is installed on glue alone, and then some weight is put on the top to keep it down while glue is binding. this usually takes about 12 to 24h, depending on climate, temperature and humidity.
if these are standard board, they are 6' long and between 4" and 6" wide, depending on manufacturer. all ends indexed (tongue and grove) and pre-finished.
bamboo is a grass, but because of glue used in it's construction (formaldehyde) it makes it very hard, even harder than ironbark, in jenkins scale, bamboo floorboards are between 13 and 15 (pine is about 4.5, oak about 10 in this same scale)
bamboo expand as well with humidity, and you need to leave 10mm free space along the walls to allow for that expansion. this space is normally convered by skirting. skirting is usually about 19mm thick, therefore gap between 10mm and 15mm is ok.
if running board is longer than 13m, you need to leave expansion joint on it as well.
if you are installing directly on the concrete, do not forget about moisture barrier, if this is on already existing wood floor or cork, moisture barrier is not necessary, but you need to remove old paint from subfloor (sand it to "bare" wood) to allow better glue adhesion.
if you are installing bamboo over the bearers, then use some sort of subfloor and glue bamboo on the top of it. you cannot just stick bamboo to the bearers, bamboo is too thin (15mm) for that
NEVER NAIL BAMBOO FLOOR!
you use glue and sparringly pin-nails on bamboo skirtboard (even pin-nail tend to explode them...).
i hope that this short explanation will help you, it will be better actually if you ask some professional floor shop in your area how to do that...
if you are happy with my advice, please do not hesitate to leave your comments or vote (or both...) for me, thanx!
Aug 03, 2010 | Stanley Bostitch MIIIFN Flooring Nailers
I am using the 1 1/2 staples and going into oak, and can't get the depth wheel to seam to adjust. Leaves the staple sticking up about a 1/8 in.. I have sprayed everthing good with WD-40. Combination...
well oak is a barn hard wood, do you realy need a big staple cant you use a shorter one??? its that or buy a stronger staple gun or a big hammer!
Jan 12, 2010 | Air Tools & Compressors
Question regarding Bostitch MIIIFN or MIIIFS
Read the warranty for Woven Strand Bamboo floors. I think you find this is the wrong tool. You`ll probably find that you need an 18ga 1/4" crown, so it don`t split!
Thanks,
Jeff
May 02, 2009 | Stanley Bostitch MIIIFN Flooring Nailers
I AM HAVING TROUBLE OUT OF MY BOSTITCH MIIIFS FLOOR NAILER
D Farley,
I repair these nailers all the time. Anytime the nail or staple is bending you have 2 causes. Either the stapler has a broken blade, the magazine is loose on the foot gate, or you are shooting into plywood over concrete. that is allowing the staple to hit the cement subfloor. Use 11 /2" staples on 3/4" wood floor over 3/4" plywood when over concrete.
Dec 16, 2008 | Stanley Bostitch MIIIFN Flooring Nailers
Stanley Bostitch STB-MIIIFS Flooring Stapler Logo
20 people viewed this question
Top Stanley Tools & Hardware - Others Experts
John Trevino
yoopertech
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
