Question about GE Spacemaker JVM1540 Microwave Oven
No exhaust fan JVM1540 - GE Spacemaker JVM1540 Microwave Oven
Vent fan does not turn on at all
If your cooktop lights recently blew, or if the relay that controls the vent fan is affected, you may need circuit board repair.
Otherwise, it may be a bad fan motor.
There should be a technical sheet hidden behind the grille or behinds the controls. It's very handy to locate and test components.
You can find a video here that shows you how to remove the grille & controller in about 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Apr 14, 2013 | GE Spacemaker JVM1540 Microwave Oven
Microwave turns on but no heat and turntable doesn't turn
It is one of two things, a defective door switch, "most likely" or the keypad control board is faulty.
Apr 22, 2012 | GE Spacemaker JVM1540 Microwave Oven
The GE Spacemaker Microwave Oven model JVM1540 makes a loud fan noise whenyou turn it on. Sounds like the exhast fan but it not?
It sounds like from the description when it is running the noise comes from the magnetron, some microwaves are louder than others, but this could be an early sign the magnetron is going.
Mar 13, 2012 | Microwave Ovens
The GE Spacemaker Microwave Oven model JVM1540 noise
The problem is more than likely the magnetron when it is running.
Mar 13, 2012 | GE Spacemaker JVM1540 Microwave Oven
Ge spacesaver jvm1540 it runs, lights, fan works, just no heat. then slow heat, now heat again, but seems to take longer? please help
Sorry to read about your problem, I hope this helps you out.
it seems you may have defective magnetron, I suggest you contact a service company, that has the proper tools to check the problem...
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 27, 2010 | GE Spacemaker JVM1540 Microwave Oven
It started by it self,and i had to unplug it to stop
if it was actually heating the pc board is bad, if just the fan, turn table and light its a switch
Feb 05, 2010 | GE Spacemaker JVM1540 Microwave Oven
JVM1540 Above the oven microwave is not heating anymore
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
gfgf
Dec 15, 2009 | GE Spacemaker JVM1540 Microwave Oven
GE JVM1540 keypad only works for some buttons
Membrane keypads are not very durable, and do fail after a relatively short time.
The only method is to replace them as a spare part.
Aug 20, 2009 | GE Spacemaker JVM1540 Microwave Oven
Noise of microwave exhaust fan
You can remove the exhaust turbine unit with one screw and reinstall microwave and buy a braun external exhaust unit that fits over the hole where it is at the roof or wall and all of the noise will be outside and it will actually work. It is weather proof and will **** steam or fumes out like the best vacuum cleaner.
Mar 25, 2008 | Microwave Ovens
GE Spacemaker JVM1540 Microwave Oven Logo
13 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
