Question about Echo CS400 18" Chain Saw
Cannot pull starter cord on chainsaw shut down while running
3 Suggested Answers
  • 62 Answers
SOURCE: Chainsaw won't start
Time to get out your trusty tool kit. Remove the side cover assembly and look at the recoil assembly. You should see a pair of fingers that when you pull the cord move toward the center. If the fingers are there and not broken, make sure they move when you pull the cord. clean them if dirty or have foreign objects (like sawdust) around them. If the fingers are broken, replace them. You should be able to purchase them from your local saw shop.
Posted on Apr 18, 2009
  • 2239 Answers
SOURCE: My echo 400 chainsaw was
This does not sound good, start by removing the starter, try to turn the engine by hand turning the flywheel, move it back and forth incase there is somthing trapped between the flywheel, if you cannot turn the engine this way, then somthing bad has happened inside the engine, it will now require a strip down to find out exactley what has happened
Posted on Mar 26, 2011
Why is my 14 &20 chainsaw Model 8901/8902 having difficulty pulling cord. It seems to lock. What could be the problem?
if it runs ok after you get it started it could be the starter pulley. the blue max saws have that problem
Feb 10, 2015 | BLUE MAX 2-in-1 - 14"/20" Combination...
How do I replace a pull cord for pm 605 mcculloch chainsaw?
First remove the pull starter housing.
The next part is tricky. You'll have to release and unwind the spring that rewinds the pull starter cord. Remember how you do this because after replacing the cord, you'll have to rewind the cord and spring before inserting it back in the housing.
re-attach the pull cord housing to the chain saw.
Hope this helps.
Oct 19, 2014 | McCulloch Pro Mac 605 610 645 650 655...
U tube chainsaw pull cord wont pull start
Some saws with autotmatic oiling will leak bar oil into the cylinder and cause this. Pull out the spark plug and hold the saw so the oil runs out of the spark plug hole. Pull the starter cord till no more oil sprays out of the hole.Clean the oil off the plug and start your saw. It will smoke more than normal till the extra oil is burned out.
Sep 05, 2014 | Homelite Garden
Saw starter pulling too hard to start.
Check piston rings. Sounds like you have a seized engine.
Feb 20, 2013 | Husqvarna Chain Saw Models 51, 55
My echo 400 chainsaw was working great and then it shut off. Now I cant pull the starter cord to start the engine. I pulled off the cover and it looks like the 2 pawls inside are engaged so that the spool...
Mar 24, 2011 | Echo CS400 18" Chain Saw
How to start a Husqvarna 445?
Set choke to full on. To do this depress throttle all the way down and set choke lever to on. Pull starter rapidly until saw fires . Once it has fired set to start and pull starter cord until it starts. If it doesn't start in ten - twelve pulls,reset choke for two or three pulls,then switch back to start. Pull starter cord until it starts. When it starts it wii be at full R.P.Ms. Let run for twenty to thirty seconds. then move switch to run. Hope his helps, Thanks
Nov 18, 2010 | Husqvarna 16" Chainsaw Chain Saw Bar...
Chainsaw jammed
Remove the starter assembly from the side of the engine
and inspect the cord path--look for kinks in the cord or maybe it got wound on the spool incorrectly. It should be possible to pull it through while off of the engine. Good luck!
Apr 09, 2010 | Garden
How to replace pull start cord on ms 192 stihl chainsaw
Not that bad. Remove the screws from the starter. Very gently lift it off. Now you will see a grove in the pulley where the starter cord is wound. Fish the cord in from the outside, get it in this grove, wind it a few times in the direction of pulling. Now unwind it to its end. Never remove the screw in the center! Install the new cord, wind it up about 4 turns, poke it out, clamp or tie it from drawing back in, install the pull handle!
By the way, Chainsaws are one of the most deadly of all home tools!
Apr 04, 2010 | Garden
The pull cord has come off the spindle, how do I get it back on properly or install a new one and reset the spring tension
Remove the starter cover, rewind or wind a new cord onto the spool. Turn the spool about 2 turns against the spring, thread the pull cord through the starter cover and reinstall the pull handle.
Lou
Sep 05, 2009 | Homelite Consumer Products 9.0 Amp, 14 In....
Echo CS400 18" Chain Saw Logo
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
