Question about Sewing Machines
Uneven stitch length
Stitch skips, at times with regular length and at times jumps to several stitch length
SOURCE: Singer Touch Tronic 2001 Sewing Machine Stuck on Sewing Straight Stitch Only
I had a similar problem a couple of years ago. I finally figured out that I had the straight stitch needle plate (the one with the single hole), rather than the zig zag needle plate (the one with the curved hole). When I changed plates, it worked fine.
Posted on May 27, 2009
  • 3 Answers
SOURCE: How do you adjust the stitch length on Consew 226 R-1?
if it is like the other industrial machines I've used, here is the general principle:
On the machine there is a button with no label. Hold button while turning the handwheel toward you. When you feel the button depressl you can adjust the length. Hold the button in the machine and crank the hand wheel back to decrease the length of ths titch and foward to increase it. I usually put a notch on the fly wheel for my standard length with some nailpolish. Release the button and sew to test the length.
Posted on Jun 16, 2009
  • 55 Answers
SOURCE: bernina 1080 stitch length and needle jumping problem
you will most likely find that just adjusting the stitch length and width controls for a while will correct the problem (if the machine has been sitting idle for some time the stepper motor linkages seem to stiffen up a bit but i have good success with continual adjustment until they free-up.
also try switching machine off and on again to ensure it resets correctly.
the combination of both above fixes works 95% of the time - otherwise, as you mentioned circuit board and or stepper motor replacement may be necessary (however if both length and width are playing up it is unlikely to be an electrical fault).
scott
Posted on Jul 27, 2009
  • 371 Answers
SOURCE: stitch length not working and sticking in reverse
sounds like it needs servicing and cleaned. Suggest only using authorized husqvarna viking dealer for service. You can find your local dealer at the Husqvarna Viking website http://www.husqvarnaviking.com and selecting "dealers" link.
Posted on Feb 11, 2010
Zenqi
  • 208 Answers
SOURCE: Inspiration 4205 stitch length won't change
Are you certain that the pattern selector is set for straight stitch and not buttonhole?
Turn the handwheel so that the needle is up and the take-up lever is in it's highest position. Then turn the pattern selector knob through all of the patterns back and forth a few times. Finally, select straight stitch and see if the length works. If not, need to take it to a repair person to determine the course of action.
Posted on Feb 21, 2010
Skipping right side stitch on a zigzag stitch, so when i am running a zigzag stitch when the needle goes through the fabric and comes back up it pulls the stitch back with it ??
check your bobbin and is the needle good and sharp and the proper length.make sure its not bentthe tiniest defectt n a needle can mess up any stitch.
how does it work on regular stitching.
most problems with machines involve.bad needles incorrect threading of bobbin or spool,dirty bobbin,incorrect needle.
it sounds like the needle isnt catching the bobbin thread.
hope this helps
Apr 05, 2017 | Sewing Machines
What is the setting for regular straight stitching?
Stitch length @ 2.5mm (between 2 and 3 on the scale).
Stitch width @ zero.
Top selector lever @ 1 / 2 or (1 slash 2).
Needle position @ center.
That's it, no rocket science here. Stitch length will vary per application and per user choice. The 2.5 setting is only a suggested default.
Sep 22, 2015 | Bernina 1008
Stitch is uneven
Change needle is always Rule #1
Mar 23, 2014 | Elna Sewing Machines
Uneven feed
machines can have single or double feeders. what type does yours have? feeding problems can usually be fixed by a good cleaning+ oiling of the feeder mechanism which regularly gets clogged with lint+threads/scrap threads. brush it out thoroughly with a stiff-bristled brush like an acid brush. apply 1 drop of oil to each feeder seen on the foot-plate. wipe excess oil off with a clean dry rag being sure not to get any debris from the rag caught in the feeder(s). other problem might be your bobbin tension. this is usually adjusted on the bobbin race with a very small screwdriver.
Feb 22, 2014 | Brother PC-420
What would be a "stretch" stitch setting?
For a stretch stitch use a narrow zig zag stitch. Use a ball point needle with knit fabrics.
May 30, 2017 | Sewing Machines
What are the settings for regular sewing, I do not have a manual. It has 3 knobs on the front and 1 on top? This might have something to do with my problems.
The three front dials are as follows....left to right-Stitch width, type of stitch, and stitch length. The dial on the top adjust the top tension.
For straight stitch you want 0 stitch width, straight stitch, 3 for stitch length.
For zig zag you want turn your stitch width to how wide you want the zig zag, choose zig zag stitch, and choose how close you want the stitches to be on the stitch length dial. Practice on a piece of fabric. Usually for zig zag you will want to loosen your top tension a little bit.
Aug 11, 2009 | Brother XL-5130 Mechanical Sewing Machine
Bernina 1080 stitch length and needle jumping problem
scott
Jul 27, 2009 | Bernina Virtuosa 160
When appliqueing in stitch 11 the thread kees looping...
I believe stitch 11 is a zig zag so you are probably decreasing the length to get a satin stitch. You will get a better satin stitch if you select it directly. I think that it is about 29. The machine forms the satin stitch differently than the zig zag and it should look better. If you still get loops on top, you may need to have a qualified technician check the needle to hook clearance. If this distance is too great, the machine skips stitches and you will form loops. Several other adjustments may be needed to get a perfect stitch and a qualified Husqvarna technician should be able to take care of this problem for you.
Nov 23, 2008 | Husqvarna Viking 1
Janome 1600P DB Stitch length
The machine is skipping stitches and is probably out of time. Change the needle, rethread the machine and try it again. If it still skips stitches, try lowering the needle by about 1/16 inch and see if it works better. If the timing is off you should take it to a technician for a complete service.
sewman7
Jul 14, 2008 | Janome Sewing Machines
Sewing Machines Logo
11 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
