Question about Yamaha RX-V1000 Receiver
Rvx1000 receiver trips on powerup - Yamaha RX-V1000 Receiver
Philips LX700 fuse blowing on powerup
Philips LX3000D - Fuses blowing on powerup. Help.
Jan 23, 2014 | Philips LX700 System
After starting Zebra S400 the printer makes an automatic calibration each time, spending 2 blanc labels on it. How do you turn off auto-calibration? Already tried the Zebra.com official site, without luck.
SET/UP EXIT
Hit the "+" quite a few times until you get to "MEDIA POWERUP"
Hit SELECT
Use the +/- keys to enter the password (1234)
Hit SELECT - you should see a small - and + button on the screen on either side of MEDIA POWERUP (if not, repeat previous steps)
Hit the + sign until you get to NO MOTION
Hit SELECT to exit MEDIA POWERUP
Hit the + button to go to the next item HEAD CLOSE
Hit SET/UP EXIT to save changes (permanently)
Open and close the printhead to check to see if it worked!!!
Sep 20, 2010 | Zebra Stripe S400 Label Printer
I may have put the batteries in the wrong way round ! unit fails to powerup !
I have done this before without a problem and the unit has powered up fine when the batteries have been correctly inserted. It's easily done with the not-very-sensible design of the contact arrangement.
Oct 05, 2009 | Garmin GPSMAP 295 GPS Receiver
Pioneer VSC-D1S A/V receiver
Did you solve the problem? Mine is doing the same.
Sep 04, 2009 | Pioneer VSX-D3S Receiver
Bought a car with Jensen xcd9020 installed. Doesn't work. Shows "ER-3" on display after powerup.
Er-3 is a Disc error, you can try cleaning the unit to see if that shores it up but it may not work at all but its worth the shot.
Aug 19, 2009 | Jensen XCD9020
Marantz SR82 Turn on but secondary circuit does not powerup
Its worth to fix it. I think it is a best reciever for a price, it really really sounds clean, balansed and natural. Same quality as good Marantz amps.
Aug 04, 2009 | Marantz SR-82 Mark II Receiver
I have 15 bad direct tv reciver h20 h21-200 does not powerup
If you are not getting any power to the box, then the power supply may need to be changed.
Jul 10, 2009 | Samsung SIR-TS160 DirecTV DTV Receiver
Magellan roadmate 700 "powerup problem"
I had a Roadmate 700 with the same problem as yours, and the solution was simple: the hard drive inside had come loose!
All I did was open up the unit (4 screws on the back and a small snap-together clip on the end), and plugged the hard drive back into the cable. The cable has 2 black posts that fit into the hard drive, so you can't misalign the pins. On mine, the hard drive label was facing UP.
Once the hard drive was plugged in, I powered up, and could hear the hard drive spin up (which I hadn't heard before). The unit booted from the "Magellan" screen right into the menu almost immediately!
Hope this helps someone!!
Apr 01, 2008 | Magellan RoadMate 700 GPS Receiver
I have the jensen vm9512 and evey time i start the car the flip screen come out is their a way so i can manually push the buttion instead of it auto
go to the setup menu under hardware, there's an option for auto/manual/off opening of the lcd upon powerup
Jan 09, 2008 | Car Audio & Video
Yamaha RX-V1000 Receiver Logo
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
