Question about Prime Line Slide Co Prime Line E2103 Sliding Glass Door Lock
How to install E2103 lock
Installation
How do i replace a ignition switch for a 1992 mercury sable
The ignition switch on Mercury Sable is integrated into the ignition cylinder. When this switch fails, you may need to purchase a special switch from a Ford dealership if the switch used a wireless transponder.
Instructions for NON Functional Cylinder (Cylinder will Not Turn or No Keys ):
1. Disconnect the negative battery cable.
2. Remove the steering wheel.
3. Using locking pliers, twist the cylinder cap until it separates from the lock cylinder.
4. Using a 3/8 in. (10mm) diameter drill bit, drill down the middle of the ignition lock key slot approximately 13/4 in. (44mm) until the lock cylinder releases from its breakaway base. Remove the lock cylinder and drill shavings from the lock cylinder housing.
5. Remove the retainer, washer, ignition switch and actuator. Thoroughly clean all drill shavings and other foreign materials from the casting.
6. Inspect the lock cylinder housing for damage from the removal operation. If the housing is damaged, it must be replaced.
To install:
1. Replace the lock cylinder housing, if damaged.
2. Install the actuator and ignition switch.
3. Install the trim and electrical parts.
4. Install the ignition lock cylinder.
5. Install the steering wheel.
6. Connect the negative battery cable, then check the lock cylinder operation.
Instructions for Functional Cylinder ( Cylinder will Turn with Key):
2. Turn the lock cylinder key to the RUN position.
3. Using a 1/8 in. (3mm) diameter wire pin or a small drift, depress the lock cylinder retaining pin through the access hole in the upper steering column shroud (under the ignition lock cylinder) while pulling out on the lock cylinder. Remove the lock cylinder from the column.
To install:
1. Install the lock cylinder by turning it to the RUN position and depressing the retaining pin. Insert the lock cylinder into its housing. Make sure the cylinder is fully seated and aligned in the interlocking washer before turning the key to the OFF position. This will permit the cylinder retaining pin to extend into the cylinder housing.
2. Rotate the lock cylinder using the lock cylinder key, to ensure correct mechanical operation in all positions.
3. Connect the negative battery cable.
Door Lock:
When a lock cylinder must be replaced, replace both sides as a set to avoid carrying an extra set of keys.
1. Remove the door trim panel and watershield.
2. Remove the clip attaching the lock cylinder rod to the lock cylinder.
3. Pry the lock cylinder out of the slot in the door.
To install:
1. Work the lock cylinder assembly into the outer door panel.
2. Install the cylinder retainer into the slot and push the retainer onto the lock cylinder.
3. Connect the lock cylinder rod to the lock cylinder and install the clip. Lock and unlock the door to check for proper operation.
4. Install the watershield and door trim panel
Hope this helps.
Feb 15, 2011 | 1992 Mercury Sable
How do you replace the ignition key switch for a '96 chevy diesel 1 ton 4wd pickup truck?
Ignition Switch Removal & Installation To Remove:
  1. Remove the steering column trim covers.
  2. Remove the wire harness from the retainers as needed.
  3. Slide the 2 connectors of the multifunction switch assembly out from the bulk head connector.
  4. Detach the key alarm connector from the lock assembly.
  5. Remove the ignition switch mounting screws and the ignition switch from the steering column.
Ignition switch removal/installation gm-08-00-1141.gif
To Install:
  1. Install the ignition switch on the lock module.
    • Tighten the screws to 42 lb in (4.7 Nm).
  2. Install the key alarm connector on the lock module.
  3. Slide the turn signal and multifunction switch connectors into the bulkhead connector.
  4. Install the harness in the original retainers.
  5. Install the steering column trim covers.
Ignition Lock Cylinder Removal & Installation To Remove:
  1. Disconnect the negative cable from the battery.
  2. Disable the supplemental inflatable restraint (SIR) system.
  3. Remove the steering column trim covers.
  4. Turn the ignition lock cylinder to the run position.
  5. Using an awl with a bent tip, insert the tip into the access hole of the ignition lock cylinder.
  6. Turn the lock cylinder to start and push down and hold the lock cylinder retaining pin.
  7. Release the lock cylinder to the run position and withdraw the cylinder from the steering column.
To Install:
  1. Align the slot in the steering column to the tab on the lock cylinder and install the lock cylinder until it locks in place.
  2. Install the steering column trim covers
  3. Connect the negative cable to the battery
  4. Check for correct operation
Oct 08, 2010 | Chevrolet 3500 Cars & Trucks
Where can i find a web page that can show me step by step Ignition Lock Cylinder Removal for gmc yukon 1996
When carrying a live inflator module, make sure that the bag and trim cover are pointed away from you. Never carry the inflator module by the wires or connector on the underside of the module. In case of accidental deployment, the bag will then deploy with minimal chance of injury.
When placing a live inflator module on a bench or other surface, always face the bag and trim cover up, away from the surface.
  1. Disconnect the negative battery cable and disable the SIR system.
  2. Remove the upper and lower shroud, air bag module and the steering column.
Exploded view of the removal of the SIR coil assembly
  1. Remove the retaining ring, SIR coil assembly, wave washer.
  2. Remove the shaft lock retaining ring using tool J 23653-SIR or its equivalent to push down the shaft lock shield assembly. Discard the ring.
  3. Remove the shaft lock shield and turn signal cancel cam assembly.
  4. Remove the park lock cable assembly from the lock module assembly.
  5. Remove the key alarm switch, if equipped by gently prying the alarm switch retaining clip with a small pry tool. Rotate the alarm switch 1/4 in. turn and remove.
  6. Remove the two tapping screws and the ignition key and alarm assembly. Let the switch hang freely.
CAUTION The lock assembly is under slight spring tension. Hold the lock bolt in place while removing the lock module assembly.
  1. Remove the three pan head tapping screws and the lock module assembly.
  2. Remove the backing plate from the module.
Mark the two sector gears at the OFF-LOCK position to ensure proper reassembly
  1. Remove the sector gears.
  2. Remove the positioning tab on the end of the lock cylinder using an 1/8 in. burring tool. Remove all burrs from the lock module and cylinder assembly.
  3. Push on the locking tab of the lock cylinder from inside the lock module assembly and remove the lock cylinder.
To install:
  1. Align the marks on the sector gears and install the gears and the backing plate to the lock module assembly.
  2. Install the lock cylinder set and ensure that the lock module assembly is in the OFF-LOCK position.
  3. Install the key in the lock cylinder and ensure that it is in the OFF-LOCK position.
  4. Line up the locking tab with the slots in the lock module assembly and push the cylinder into position.
  5. Rotate the lock cylinder to the ACC position. The alignment arrows on the sector gears should be pointing towards each other.
  6. Rotate the lock cylinder to the LOCK position. Push the lock bolt in until it is flush and align the lock module assembly with the head assembly and install the lock module assembly.
  7. Install the three pan head screws and tighten to 53 inch. lbs. (6 Nm).
  8. Install the ignition and key alarm switch assembly and the fasteners. Tighten the fasteners to 12 inch. lbs. (1 Nm).
  9. Install the key alarm switch. Make sure the retaining clip is parallel to the lock cylinder. Rotate the alarm switch 1/4 in. turn until locked in place.
  10. Lubricate the lower brass surface of the turn signal cancel cam assembly with synthetic grease and install the assembly.
  11. Align the inner block tooth of the lock plate to block tooth of race and upper shaft assembly and install the assembly.
  12. Install a new shaft lock ring using tool J 23653-SIR and ensure the ring is firmly seated in the groove on the shaft.
  13. Install the center race and upper shaft assembly.
  14. Place the ignition switch to the lock assembly and ensure the coil is centered.
  15. Install the wave washer and the SIR coil assembly.
  16. Install the retaining ring and route the coil wire along the steering column.
  17. Install the wire harness straps to the steering column harness.
  18. Install the park lock cable assembly with the transmission in Park and the ignition switch in the OFF-LOCK position.
  19. Install the upper and lower covers, lock cylinder set and tilt lever (if equipped).
  20. Install the steering column and enable the SIR system. Connect the negative battery cable.
Exploded view of the sector gear timing position (OFF-LOCK)
Jun 02, 2010 | 1996 GMC Yukon
Need to replace the ignation switch in my 2000 chrysler LHS
  1. Disconnect negative cable from battery.
  2. Remove the Instrument Panel Center Bezel, Chrysler and Dodge.
  3. Remove side trim panel to steering column cover.
  4. Remove the screws that secure the steering column cover to the instrument panel and relocate panel.
  5. Pull the steering column cover rearward at the top and right side of the cover to release the snap retainers from the instrument panel.
  6. Remove the screws that secure the instrument panel steering column cover reinforcement to bracket and remove reinforcement from the vehicle. Remove the 2 front mounting nuts.
  7. Remove the lower mounting nut.
  8. Slide the assembly rearward into the instrument panel and down to gain access to switch.
  9. Disconnect the electrical connector from the ignition Switch and SKREEM Module.
  10. Remove the interlock cable by depressing the locking tab and pulling straight.
  11. Remove ignition switch mounting screw.
  12. Squeeze the 2 locking tabs to remove ignition switch from the lockhousing .
Removal and installation of the ignition switch
To install:
NOTE A tab on the ignition switch indexes to a notch in the lock cylinder housing. Also, a slot in the end of the ignition switch fits over the shaft in the end of the lock cylinder housing.
  1. Use the ignition key to rotate the lock cylinder to align the ignition switch with lock cylinder housing.
  2. Insert ignition switch into lock housing until locking tabs are seated into openings on lock housing.
  3. Install ignition switch mounting screw.
  4. Install the interlock cable into the switch assembly. Attach electrical connector to SKREEM Module.
  5. Install switch assembly into Instrument Panel.
  6. Attach electrical connector to ignition switch.
  7. Tighten the 2 mounting nuts.
  8. Tighten the lower mounting nut.
  9. Install steering column reinforcement.
  10. Steering column reinforcement installed.
  11. Install the Steering column reinforcement cover.
  12. Install trim panel end.
  13. Install the Bezel cluster.
  14. Install the ignition switch bezel ring.
  15. Connect the negative battery cable.
May 28, 2010 | 2000 Chrysler LHS
Door lock assembly
Toyota Corolla 1988-1997 Repair Guide Door Locks - REMOVAL & INSTALLATION
(see Figure 1)
  2. Remove the door panel and watershield. Remove the service hole cover.
  3. Disconnect the door outside opening linkage. Remove the two mounting bolts and remove the door handle if in need of replacement.
Fig. 1: Power door lock control system component locations
  1. Disconnect the lock cylinder control linkage.
  2. Remove the lock knob and the child protector lock lever knob.
  3. Remove the lock assembly retaining screws and remove the door lock. If equipped with power locks, disconnect the electrical harness.
  4. To remove the lock cylinder, remove the lock cylinder retaining clip and pull the cylinder from the door.
To install:
  1. Coat all the door lock sliding surfaces with multi-purpose grease.
  2. Install the outside handle with the two retaining bolts, if removed.
  3. Install the door lock solenoid linkage to the door lock.
  4. Connect the link to the outside handle.
  5. Install the lock knob and the child protector lock lever knob.
  6. Install the door opening control link tighten the mounting bolts to 48 inch lbs. (5 Nm).
  7. Install the door lock cylinder control linkage.
  8. Install the door panel and watershield.
  9. Reconnect the negative battery cable.
Hope help with this; remember rated this post and thank you for using Fixya.
May 20, 2010 | 1991 Toyota Corolla
How to replace the ignition switch
  1. If equipped with an air bag, disable the system as outlined in of this repair guide.
  2. If not done already, disconnect the negative battery cable.
  3. Remove the steering wheel, as outlined earlier in this section.
  4. Remove the shaft lock cover.
  5. Remove the shaft lock retaining ring using a suitable lock plate compressor tool to press down the shaft lock. Dispose of the ring.
  6. Remove the shaft lock.
  7. Remove the turn signal canceling cam assembly.
  8. Remove the upper bearing spring.
  9. Remove the thrust washer.
  10. Move the turn signal lever up, into the "right turn" position.
  11. Remove the multi-function lever.
  12. Remove the turn signal switch arm retaining screw.
  13. Remove the turn signal switch screws and let the switch hang freely.
  14. Remove the key from the lock cylinder set.
  15. Remove the buzzer switch assembly.
  16. Reinsert the key in the lock cylinder.
  17. Turn the key to the LOCK position.
  18. Remove the lock retaining screw and remove the lock cylinder.
  19. If equipped with cruise control, remove the housing cover end cap, unplug the cruise control connector and gently pull through the shroud, bowl, and steering column housing assembly.
  20. Remove the washer head screw, the hex nut and dimmer switch.
  21. Remove the mounting stud and ignition switch.
    1. If equipped with cruise control, gently pull the connector through the steering column housing assembly, bowl and shroud and connect the plug.
    2. Install the housing cover end cap and screw and tighten to 17 inch lbs. (1.9 Nm).
    3. Install the ignition switch and mounting stud and tighten the stud to 35 inch lbs. (4.0 Nm). Adjust the ignition switch by moving the switch slider to the extreme left position and then move the slider 1 detent to the right (off lock).
    See Figure 1
    0900c152801dbcc2.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 1: Ignition switch adjustment procedure
    1. Install the dimmer switch hex nut, screw, and tighten to 35 inch lbs. (4.0 Nm). Adjust the dimmer switch.
    2. To adjust the dimmer switch, depress the switch slightly to allow insertion of a 3 / 32 in. drill bit into the hole above the actuator rod. Force the switch upward then tighten the screw.
    See Figure 2
    0900c152801dbcc3.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 2: Dimmer switch adjustment procedure
  22. Install the switch using the original screws. Use of screws that are too long could prevent the column from collapsing on impact.
  23. Install the lock cylinder and retaining screws and tighten to 40 inch lbs. (4.5 Nm).
  24. Turn the key to the RUN position.
  25. Install the buzzer switch assembly.
  26. Install the turn signal switch and retaining screws and tighten to 31 inch lbs. (3.5 Nm).
  27. Install the wire protector shield.
  28. Install the turn signal switch arm and retaining screw and tighten to 29 inch lbs. (2.3 Nm).
  29. Install the hazard knob assembly.
  30. Install the multi-function lever.
  31. Install the thrust washer and upper bearing spring.
  32. Lubricate with synthetic grease and install the turn signal canceling cam assembly.
  33. Install the shaft lock.
  34. Install a new shaft lock retaining ring. Align it to the block tooth on the shaft, using a lock plate compressor tool to press down the shaft lock.
  35. Install the shaft lock cover.
  36. Install the steering wheel, as outlined earlier in this section.
  37. Connect the negative battery cable. If equipped, enable the air bag system as outlined in of this repair guide.
Jan 19, 2010 | 1993 Oldsmobile Silhouette
I can't find the instructions to install lock.
Here is the installation page for Kwikset. There are some general hints and tips and you should be able to follow the links to a specific lock if you need it.
http://www.kwikset.com/support/installation/default.aspx
Oct 21, 2009 | Kwikset Professional Door Lock...
How do u chang the ingition switch
Park/lock cable removal
Ignition switch alignment
Ignition lock cylinder removal
WARNING On vehicles with air bags, disable the SIR system. The vehicles wheels must be in the straight ahead position and the key must be in the LOCK position when removing or installing the steering column. Failure to do so may cause the SIR coil assembly to become uncentered and may result in otherwise unneeded SIR repairs.
  2. If equipped, properly disable the SIR system, as outlined in Section 6 of this manual.
  3. Remove the left side lower trim panel.
  4. Remove the steering column-to-support screws and lower the steering column.
  5. Unplug the dimmer switch and turn signal switch connectors.
  6. Remove the wiring harness-to-firewall nuts.
  7. Remove the steering column-to-steering gear bolt and remove the steering column from the vehicle.
  8. Remove the combination switch.
  9. Place the lock cylinder in the RUN position.
  10. Remove the steering shaft assembly and turn signal switch housing as an assembly.
  11. Using the terminal remover tool No. J 35689A or equivalent, label and unplug the wires F and G on the connector at the buzzer switch assembly from the turn signal switch electrical harness connector.
  12. With the lock cylinder in the RUN position, remove the buzzer switch.
  13. Place the lock cylinder in the ACCESSORY position, remove the lock cylinder retaining screw, and remove the lock cylinder.
  14. Remove the dimmer switch nut/bolt, the dimmer switch, and the actuator rod.
  15. Remove the dimmer switch mounting stud (the mounting nut was attached to it).
  16. Remove the ignition switch-to-steering column screws and the ignition switch.
  17. Remove the lockbolt screws and the lockbolt.
  18. Remove the switch actuator rack and ignition switch.
  19. Remove the steering shaft lock and spring.
To install:
  1. To install the lockbolt, lubricate it with lithium grease and install the lockbolt, spring and retaining plate.
  2. Lubricate the teeth on the switch actuator rack, install the rack and the ignition switch through the opening in the steering bolt until it rests on the retaining plate.
  3. Install the steering column lock cylinder set by holding the barrel of the lock cylinder, inserting the key and turning the key to the ACCESSORY position.
  4. Install the lock set in the steering column while holding the rack against the lockplate.
  5. Install the lock retaining screw. Insert the key in the lock cylinder and turn the lock cylinder to the START position and the rack will extend.
  6. Center the slotted holes on the ignition switch mounting plate and install the ignition switch mounting screw and nut.
  7. Install the dimmer switch and actuator rod into the center slot on the switch mounting plate.
  8. Install the buzzer switch and turn the lock cylinder to the RUN position. Push the switch in until it is bottomed out with the plastic tab that covers the lock retaining screw.
  9. Install the steering shaft and turn signal housing as an assembly.
  10. Install the turn signal switch. Install the steering wheel to the column, and tighten the steering shaft nut to 30 ft. lbs. (41 Nm).
  11. Install the steering column in the vehicle. Connect all electrical leads. Install the lower trim panels.
  12. Connect the negative battery cable.
  13. If equipped, properly enable the SIR system, as outlined in Section 6 of this manual.
  14. Check steering column operations.
Oct 18, 2009 | 1993 Pontiac Grand Prix
New master lock night watch dead bolt installed. But when we try to lock it from outside or unlock it all it does is spin and go round and round until sometimes if we are lucky it will catch. Does it ned...
Since it was new then I can only surmise that it was installed improperly. You or your landlord will have to take it back out and properly install it. Make sure that the male and female parts of the lock all fit together smoothly. Use your key and operate the lock several times before you screw it all back together. Most of the installation instructions are very detailed and you should be able to see what step might have been overlooked. Hope this gets you in.
Aug 02, 2008 | Master Lock 5400d: Portable Select Access...
Prime Line Slide Co Prime Line E2103 Sliding Glass Door Lock Logo
29 people viewed this question
Top Prime Line Slide Co Home Experts
Donni Steen
Tom Chichester
Are you a Prime Line Slide Co Home Expert? Answer questions, earn points and help others
