Question about Maytag EPIC MFW9700S Front Load Washer
Maytag top load W10468368A
Won't wash fills up and then nothing
  • 18 Answers
SOURCE: Maytag Washer Getting stuckon wash cycle
the possibility of it being the timer is most likely..as the rest of the cycles remain ok.. if you require a timer,you can get one here at this link..(click the link here) http://www.easyapplianceparts.com/AdvancedModelSearch.aspx?ModelNum=HAV4657EWW&mfgModelNum=&fkMfgID=1
please be aware that you will need the machine serial number in order for them to issue you with the correct part/s you will require.. parts are cross referenced with the serial number.
these diagrams will also enlarge in order for you to maintain your machine by yourself at little but the cost of the parts required... but please DO NOT ATTEMPT ANY REPAIR YOURSELF if you think you may not have the technical know how to follow these technical drawings..hope this helps
Posted on Dec 27, 2008
SOURCE: Maytag Top loading Washer, fills but won't stop
there is a small tubing about 12 inches or so that connect from the water level dail to the tub of the washer. sometimes the clamp on there gets loose and that interfers with the communication. try changing the tubing and or just tighting the clamps. you will need to lift the top of the washer off to get to it.
hope this helps
Posted on Mar 17, 2009
dh1200s
  • 335 Answers
SOURCE: Maytag Neptune FAV6800AW Top Loading Washer Noise
Hello gwatson01,
Wondering if you could rate my clarification request as a solution? I joined this forum as a owner DIY’er to help other owners. The machine is just too expensive to junk and as you found fairly easy to work on. As a forum member as you I receive no compensation for my support to other owners. Thank you in advance for your support. Rich
My solution;
I’m an owner/DIY’er of the machine. Please take a look at this post and see if your mechanical noise may be coming from underneath the tumblers, maybe some coins grinding around under the tumblers. If you think it is take a look at the service manual link in that post. It will take you thru the tumbler removal process, see if you feel comfortable with the process, the manual does not call out a #20 Torx driver is required to remove the tumbler.
If you think the grinding noise is very metallic and not muffled by a tub of water the grinding noise may be coming from the transmission/clutch area and removing the machine front vertical cover will be necessary to better sound isolate the suspect area of the machine. Do you feel OK to remove the front panel? If so see this post.
The 1st link I sent you to shows that this owner had issues after the coin removal. I would also like you try a Spin Only cycle with no clothes in the wash basket. Can you let me know if that cycle runs with no noise? We can’t totally rule out an issue with the clutch/transmission components with the info supplied so far. To help you remotely diagnose this issue detail information is needed. Let’s try to sound isolate the grinding noise source location. Follow all safety rules in the Service Manual. If you don’t feel comfortable to proceed I would recommend you call in a qualified FAV6800AWW repair service for support.
Posted on Apr 05, 2009
Maytag317
  • 1136 Answers
SOURCE: Top loading maytag washer leaking water during wash cycle
Hi, There are two spring clips located in the gap between the top and front panel. They are the edges.
If the pump and hoses aare ok, fill the washer with water and look up toward the center of the tub abd transmission area. It migth have a seal going bad.
I hope this helps.
Vic
Posted on May 30, 2009
  • 9 Answers
SOURCE: Leak from under the washer
tub seal has gone bad, will only get worse. Expensive fix,
Posted on Jul 02, 2009
I have may tag wash model nu mav5920eww i just hooked it up tried reg wash it filled with water then would not continue to wash went to pause mode
Maytag & Whirlpool washer diagnostic - Fills with water then ...
? 3:03
https://www.youtube.com/watch?v=71zySSScDPE
Jul 11, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your trusty Maytag Washer that has some of the ...washer diagnostic - Fills with water then cycle stops - LAT8014AAE .... Not agitating Maytag 2 belts top load washers - Duration: 26:55. by theapplianceman 23,820 views. 26:55.Washing Machine Keeps Filling With Water and Will Not Agitate ...
Maytag top loading washing machine stopped working & filled with
Dec 02, 2015 | Maytag MAV5920E Top Load Washer
Maytag atlantis washer water won't stop filling with water even when power is off.
water fill valve have a particle of trash or deposit from water.replace water valve and problem solved.
Jan 31, 2013 | Maytag Atlantis MAV6000 Top Load Washer
Washer wont start, it will spin but will not begin the wash or start to fill
It won't wash till the water fills to the point of tripping the water level switch. Check your screens for clogsthemobilian_3029.jpg
Service manual and more
Sep 22, 2011 | Maytag Centennial MTW5800TW Top Load...
Washer won"t fill with water
check your lid switch if its a top load
May 18, 2009 | Maytag LSE7806A Top Load Stacked...
Washing Machine will not fill with water
It sounds like the water solenoid has gone bad or stuck closed OR timer/control knob has bad set of contacts which control the solenoid.
Jan 17, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Washing machine fills, but won't agitate
Lid switch if its a Maytag Alantis... You said you have a GE top load in the start of your problem and ended witha maytag?
Dec 18, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Fills with water than nothing!
Most likely it's the lid switch, part number 22003804.
Remove the back of the console to gain access.
Jan 22, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Maytag EPIC MFW9700S Front Load Washer Logo
95 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
