Question about Crosley Audio Players & Recorders
How do i set the clock on cr3012a
Just received this system. How do I set the clock to the correct time
The system clock will not stay set, when I turn off laptop the clock stops and calendar stops . I reset it every time I turn it back on so I receive all up to date updates . Windows updates are set to ...
You need to set the correct date and time in your system BIOS. To access that you need to press the correct key when the computer is first booted (usually DEL or F10/F2/F11).
Most computers will have a message stating press xx Key to enter setup or etc.
If this problem persists even after setting the correct time in your BIOS, your laptop needs a new CMOS battery. I recommend having a professional do this.
May 09, 2011 | Acer Aspire 6920-6422 Notebook
How to set the time on a simplex series c model number 6334-9140 digital clock
For independent operation, the clock is connected to a reliable source of 120 VAC 60HZ (or 230 VAC 50HZ), and time is maintained with a real time clock chip. Switches located on the front of the clock allow for easy and accurate time setting. For system clock applications, synchronization can be accomplished by connection to Simplex BCD digital data for instantaneous time updates. Clocks can also be connected to power line carrier/synchronous timing inputs that provide hourly and 12 hour corrections. Impulse correction from the 6400 Series Master Clock is ideally suited for Time and Attendance System expansions. A capacitor in each clock maintains timekeeping for approximately 12 hours in the event of power failure in the facility. The Celestra 2000 can be corrected with six different clock codes to suit any specific retrofit or new synchronized time system.
Jan 30, 2011 | Office Equipment & Supplies
It looses time and the radio controlled feature does not bring it back to the correct time. I put in a new battery and it still happens. It is a La Crosse Technology Radio Controlled clock Model:WT-3101
When the battery is installed the second hand will advance eight seconds (2 seconds per step x 4 steps). The clock is now searching for a signal. For the initial setting it is recommended to stand the clock in an upright position near a window. Within five minutes the clock will either receive the WWVB signal and set itself to the exact time, or it will determine that the signal is not receivable at its current location and time of day. If a signal is not receivable it will fast-forward the hands to the 4, 8, or 12 o'clock position and search for WWVB each hour until a signal is received. If the time is manually set the clock will continue to periodically search for a signal and automatically reset the hands when the signal is received.
Jan 24, 2011 | La Crosse Radio Controlled Atomic Clock
My WWVB radio controlled quartz ch 899 clock is 21 minutes off the correct time. How do I set the clock by minute intervals?
these really aren't atomic clocks and are set at the factory. It receives, it's LF signal out of Colorado and should correct itself. If not contact the manufacturer.
Jan 12, 2011 | La Crosse Radio Controlled Atomic Clock
7:15 p.m., 10/6/09-I don't know how to set up the time & date on the machine. I need clear, step-by-step instructions. Help! AT&T digital answering machine model 1738. THANK YOU!! Barbara S.
To set the clock. You must set the clock once so that the system announces the correct day and time with your messages. After this, if you subscribe to Caller ID, the system will automatically reset the clock each time new call information is received.
Press PLAY/STOP to exit at any time while
setting the clock.
1 Press and hold CLOCK until the Message Window displays C, and the default day is announced.
2 To change the day setting, press and release MEMO/REPEAT or ANNC/SKIP until the correct day is announced.
3 Press and release CLOCK. The current hour setting is announced.
4 To change the hour setting, press and release MEMO/REPEAT or ANNC/SKIP until the correct hour is announced.
5 Press and release CLOCK. The current minutes setting is announced.
6 To change the minutes setting, press and release MEMO/REPEAT or ANNC/SKIP until the correct minutes setting is announced.
7 Press and release CLOCK. The current year is announced.
8 To change the year setting, press and release MEMO/REPEAT or ANNC/SKIP until the correct year is announced.
9 Press and release CLOCK. The new day, time, and year are announced.
To check the clock, press and release CLOCK.
If you need futher instructions for your answering machine you can download a copy from:
http://phone.manualsonline.com/manuals/mfg/att/1738.html
Please rate this solution. Thanks..
Oct 07, 2009 | AT&T Lands Phones
Model 1739 answering machine
Set the clock
You must set the clock so that the system announces the correct day and time with any incoming messages. After this, if you subscribe to the caller ID service, the system will update the clock eac h time new call information is received. Press PLAY/STOP to exit at anytime while setting the clock.
1. Press and hold CLOCK until the message window displays C and the default day is announced.
2. To change the day setting, press
3. Press CLOCK. The current hour setting is announced. The correct day setting is saved.
4. To change the hour setting, press
5. Press CLOCK. The current minute setting is announced. The correct hour setting is saved.
6. To change the minute setting, press
MEMO/REPEAT or ANNC/SKIP until the correct minute setting is announced.
7. Press CLOCK. The cu rrent year is announced. The correct minute setting is saved.
8. To change the year setting, press
MEMO/REPEAT or ANNC/SKIP until the corr ect year is announced.
9. Press and release CLOCK. The new day, time and year are announced. The correct year setting is saved.
To check the clock, press CLOCK.
Jan 08, 2009 | AT&T 1717 Digital Answering Machine
Need to change the date and time
You’ll need to set the clock so that it can
announce the day and time that each
message is received. Press "Play/Stop" to exit
Setting the Clock at any time.
1 Press and hold "Clock" until the
2 To change the day setting, hold down
"Memo/Repeat" or "ANNC/SKIP" until the
correct day is announced. Then
release the button.
3 Press and release "Clock". The current
4 To change the hour setting, hold down
"Memo/Repeat"or "ANNC/SKIP" until the
correct hour is announced. Then
release the button.
5 Press and release "CLOCK". The current
6 To change the minutes setting, hold
down "Memo/Repeat" or "ANNC/SKIP" until the
Then release the button.
7 Press and release "CLOCK". The new day
and time are announced.
"Clock".
Nov 26, 2008 | AT&T 1717 Digital Answering Machine
Setting the clock
Setting the Clock for Systems with the
Set Button
Press SET. Within five seconds, press and hold the right
SEEK arrow until the correct minute appears on the
display. Press and hold the left SEEK arrow until the
correct hour appears on the display.
Setting the Clock for Systems with HR
and MN Buttons
Press and hold HR until the correct hour appears on the
display. Press and hold MN until the correct minute
appears on the display. To display the clock with the
ignition off, press RECALL or HR/MN and the time
will be displayed for a few seconds. There is an initial
two-second delay before the clock goes into the
time-set mode
Nov 13, 2008 | 2002 Chevrolet Silverado 2500HD
"C" in display window and "power failure" keeps getting announced
Set the Clock
Press Pto exit at any time while
setting the clock.
1 Press and hold Cuntil the Message
is announced.
release ror auntil
3 Press and release C. The current
release ror auntil
5 Press and release C. The current
release ror auntil
7 Press and release C. The current
year is announced.
release ror auntil
9 Press and release C. The new day,
Feb 26, 2008 | AT&T 1738 Digital Answering Machine
When I go to messages, it says the time and then says "POWER FAILURE."
Set the Clock
setting the clock.
is announced.
release ror auntil
release ror auntil
release ror auntil
year is announced.
release ror auntil
C.
Nov 14, 2007 | AT&T 1738 Digital Answering Machine
47 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
