Question about Samsung Ps-fc5500 Front Speaker For Ht-c5500 System
I need to replace my speaker for model PS-FC5500 front speaker as it distorts all the time . the U083L2ssK4 4/09m079-1 100708N Can you please tell me where i can get this from and how much
2 Suggested Answers
Blue Dog
  • 75 Answers
SOURCE: how can i get a replacement front speaker for a
Look at the back of the speaker that you're replacing for a label. You can replace it with any speaker that exactly matches the ohm rating (a number with a little upside-down horseshoe next to it) and that meets or exceeds the wattage (a different number with a "w" next to it).
Posted on Oct 04, 2009
How do i remove the subwoofer on a Samsung home subwoofer, model PS-AW720S or its PA-AW72OS?
Most of these are manufactured in such a way as to preclude speaker replacement. Sorry
Jul 24, 2016 | Audio Players & Recorders
How to fix my acer aspire 5740G model lap top sound distortion, When it with Speaker connection its clear, Without speaker its more distorted, any one can give solution?
This is due to the internal speakers which might need replacing, it sounds better with external speakers because they are plugged into the headphone socket which shows the internal speakers are damaged, get them checked out.
Jun 08, 2014 | Acer Aspire Computers & Internet
Denon AVR 1508 distortion on left channels
I have a different model, but sometimes suffer this when power outages or other strange things happen. Its usually the microprocessor getting confused and not doing its job properly, once none of the speakers came on at atll!
In the handbook, it will tell you how to do a factory reset - that always sorts mine (Same brand, Denon). Just a pain setting it all up again.
You should be able to find a PDF version of the handbook online if your's is misplaced in the house move.
Dec 17, 2013 | Audio Players & Recorders
My SONY Home Theater Model HT-6600DP unit was working fine and then about tow years after...present, my sub woofer is sounding distorted. Why is this happening? Please help me as I often watch my home...
Is it so even at lower volumes?
Are you sure it's the sub distorting and not the front or center speakers?
If you designate them incorrectly as Large (which tells the receiver they CAN effectively produce bass frequencies) they will probably distort in the presence of low frequencies.
See Page 17, 19
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sony-HT-6600DP-Home-Theater-Systems-manual/id/390ag319/t/2/
Mar 13, 2011 | Sony HT-6600DP System
HI CAN YOU PLEASE TELL ME WHY MY FENDER RUMBLE 100 BASS AMP DISTORTS AT LOW VOLUME? EVEN THOUGH THE SPEAKERS IS NOT BLOWN
A common reason for 'distortion' with all bass amps can be either that the screws holding the speaker unit to the cabinet have worked loose or that there has been a build up of dust particles in the corrugations around the edge of the speaker cone, which rattle especially on the lower notes.
The solution is simple - remove the front grille and check the screws are tight. Use a vacuum cleaner to remove dust from the rim of the speaker cone.
Feb 01, 2011 | Fender Rumble 100 Bass Guitar Amplifier
Is it possible to still use my old 90w/4ohm surround speakers on a blue-ray system nornaly using 125watt/3ohm surround spks.without causing any damage..Therefore If this is un-advisable, thus as I...
It would be helpful to understand what electronics we're building a system around.
Next time type carefully and provide exact make/model numbers as typographical errors in a model number will send us careening down the wrong path.
I'll assume you're talking about Panasonic models. I would highly advise AGAINST mixing HTS speakers with any make or model they're not designed for. If proprietary connectors instead of bare speaker wires are present that's a huge warning sign.
Take those wattage specs with a huge grain of salt as they're strictly for show and have no grounding in reality at normal acceptable distortion levels.
4-ohm (or less) speakers will present a challenging load to anything not designed for that low an impedance.
You're treading in unknown territory where creativity might yield poor results at best and equipment destruction or worse.
Jan 17, 2011 | Panasonic Audio Players & Recorders
Distortion
The wattage rating, I take it, for the speakers is more than 45 watts right? Check to make sure that you connected the right wires to each speaker,front right + wire to front right speaker, not front right +, to front left + and make sure that the -'s are connected to the -'s, and the +'s are connected to the +'s.
Mar 29, 2010 | Alpine SXE-1325S Coaxial Car Speaker
I have taken out my standerd sterero in ford fiesta 1996 and cut off the block dont know what wires are what and now clock dont work ant think i have blown the stereo can any one tell me what wires are...
you may have blown the one of the fuses in your car look in the fuse box and check the fuse for the clock ps if you find out what wires are what please let me know as ive got the same problem in my fiesta. cheers kez
Apr 13, 2009 | Car Audio & Video
Jbl distortion! frame warped?
Nope. WE have about 50 of these with no problems. Please describe the type of distortion that you have. It may be as simple as a bad transistor in the power amp.
Dan
Sep 23, 2008 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Samsung Ps-fc5500 Front Speaker For Ht-c5500 System Logo
82 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
