Question about Royal 115CX Portable Cash Register
Printer Error Royal 115cx - PE error. How do I clear it?
How do i fix a PE error on my royal 500dx cash register?
PE means Printer Error. check your papaer if it is properly inserted . If all is correct and still PE appears, switch of the machine and call a qualified technician
Jul 30, 2014 | Royal Cash Register 500dx
Royal 435dx- PE error.
Printer error. Either the motor can't turn (jam such as paper stuck) or the printer has a sensing fault. Since the machine works for a while before the error appears, I'd say it needs the rotary position sensor cleaned in the printer. It gives this symptom. If it has been around cooking fumes/ grease then it is VERY common. A dealer can fix this for you.
If anyone needs a manual for a Royal 435dx, try here:
http://the-checkout-tech.com/manuals/cashregisters/Royal_435dx_instruction_manual.html
Jan 12, 2014 | Casio Parts Cash Register PC Desktop
The screen displays PE, machine stops working
PE means Printer Error. your printer is stuck. call a tech
Mar 21, 2013 | Royal Cash Register 500dx
Error code "PE"....paper not jammed.....model,435dx
Then you may have a sensor fault or motor/ drive failure in the printer.
If anyone needs an operation / programming manual for a Royal 435dx, c-tech collective have it here:
Sep 24, 2010 | Casio Parts Cash Register PC Desktop
Royal 435dx - PE error. How do I clear it?
It means printer error. Make sure you don't have paper jammed in the printer, then turn off and on at the wall. -------------------------------------------------------------------------------
If anyone needs a Royal 435dx manual, try here:
http://the-checkout-tech.com/manuals/cashregisters/royal1.php
Jun 30, 2010 | Casio Parts Cash Register PC Desktop
Cash register PE ondisplay and nothing will work
It means printer error. Usually after a paper jam. Clear any paper out and try turning off and on at the wall. ***************************************************************************** *****************************************************************************
All of these manuals can be downloaded at: http://the-checkout-tech.com/
royal 110cx User royal 115cx User royal 130cx User royal 425cx User royal 435dx User royal Alpha-580 User Programming royal Alpha-583cx User Programming royal Alpha-600 User Programming royal Alpha-600sc User Programming royal Alpha-601 User Programming royal Alpha-710ml User Programming royal Alpha-9155sc User Programming royal Alpha-9180sc User Programming royal TS4240 User Programming
Mar 02, 2010 | Office Equipment & Supplies
What is the error code "PE" on the Royal 435dx and how can I clear it?>
According to the manual, press the [C] Clear key. Here is a link to the 435dx manual (.pdf)
http://www.royal.com/drivers_manuals.htm
Jul 16, 2009 | Casio Parts Cash Register PC Desktop
Royal 115CX Portable Cash Register Logo
52 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
