Question about Welding Tools
Mitec super 200p ac dc tig welder,, faulty ,,
STICK WELDER WORKS NO PROBLEM.. THE AC,FOR WELDING ALLOY ,POWERS UP ,BUT ONLY JUST ,AND THERES NO POWER ,LIKE PUSH PEDAL ALL THE WAY DOWN ,AND IS LIKE QUARTER OF THE POWER WHEN IT WAS GOING OK.. PLASMA SELECTION,HIT THE SWITCH FOR CUT,AIR FLOWS,AND ARKS,BUT NO POWER OUTPUT/PULSE,,BUT INSIDE THE MACHINE MAKES THE RAPID TICKING SOUNDS WHEN HITTING THE SWITCH AS IT USED TO BE WHEN IT WAS WORKING GOOD.. DOES ANYONE KNOW WHAT PART TO REPLACE?? LIKE IS IT ONE OF THE RELAY SWITCHES NOT CONTACTING OR MAYBE BURNT OUT??OR A DIODE OR SIMLAR ,I HAD REPLACE A FEW SUSPECT DIODES ALREADY WITH NO FIX..
3 Suggested Answers
GiantTechGuy
  • 25 Answers
SOURCE: MITEC SUPER 200P AC/DC TIG WELDER,, FAULTY ,,
Common problem with the SUPER series of Chinese machines. If you can provide some photos of the internals I might be able to help you.
Posted on Nov 09, 2009
  • 176 Answers
SOURCE: lincoln precision tig 225.
Hello; Make sure AC Auto Balancing is Enabled; And when Welding Aluminum Aways use 100% Pure Green Coded Tugsten.Make Sure you dont have 75/25 or possibly if you know for sure your frequency balancing on your machine is working you could possibly have a bad bottle of gas try the bottle of gas on the machine that you say that runs good if it runs good put it back on the 225 if the problems still exist there is something wrong with your machine`s Ac high freqency Auto Balancing.Make sure all connections are good,check tig head for loose connections. Step Up to A 1/8 size tugsten it will carry more heat and gets less contanimated.Every time you stick your tugsten it will run contanimated untill you burn it off or clean it ,if you stick you tugsten go ahead and put a clean piece back in the tig head, Contanimated tugsten wil run dirty for 5 to 20 minutes Untill you BURN it Back Clean !?
Posted on Sep 03, 2011
What settings do i use to arc weld.
Not sure what machine you have, but it should be DC straight (electrode negative or DCEN) and DC reverse (electrode positive or DCEP). The polarities have different characteristics. For example, if you're planning to TIG weld, you would either use DCEN or AC (if welding aluminum). For the general stick welding process, DCEP tends to give you a deeper weld. The welding rod you buy will have recommended machine polarity and amperage range settings, you should use the recommended polarity for whichever rod you're using because different rods are designed to weld under different circumstances. But, generally speaking, most welding rods for steel will work on DCEP without much trouble.
May 17, 2016 | ARC Welding Tools
How to set up welder or aluminum tig welding
If you want to weld aluminium with a welder, your machine must be an AC/DC welder, then you will use only AC to do the weld, but as well you must have a contineous high frequency and according to what thickness you want to weld a water cooling argon torch wont be a luxury
Aug 25, 2014 | Welding Tools
Aluminium welding settings
Check your manual or the welding rods data sheet. The settings depend on what you will weld. Consult online manuals and welding charts. These will help you a lot.
Mar 14, 2014 | ARC Thermadyne Inverter Stick/TIG Welder...
200P AC/DC /PLASMA WELDER WONT WORK
try cleaning the ground inside the welder. and make sure you have a good power supply ie. power cord. check the transformer for continuity and clean all the contacts ( are you sure the power inverter diodes are only passing current one way and are not "open" )
Nov 24, 2013 | Welding Tools
Operating instructions thermadyne sa tig 200p ac/dc
Go to this site and you can download or print a manual for your welder copy and paste to google search engine and it has the manual on pdf. TRANSTIG 200 AC/DC Servic Manual - Victor Technologies
Oct 07, 2013 | ARC Thermadyne Inverter Stick/TIG Welder...
How make tig welder to mig welder
switch from tig welding to mig by switching your current from AC to DC for mig. change from your tig gun to your mig gun. turn water flow off. proper ground and weld away.
Mar 29, 2013 | Miller Welding Tools
How too set up a tig welder for welding thin steel?
DC current, electrode negative (DC Straight, DC-), High frequency for start only (really don't have to use high freq at all for steel but it helps establish the arc without scratching), 1 amp per thousandth of material thickness is a good setting to start, adjust from there for the job. 1 amp/thousandth also applies to aluminum- it has a lower melting point than steel but conducts heat much better so power to weld is very nearly the same.
Use a sharp tungsten, don't ball it at all (as you would for AC work).
lp
Dec 01, 2010 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
TIG welder help
Choose the electrode to use for the project you are starting as well as the variety of alloys you'll use such as the 6061 Aluminum alloy electrode. Grind the electrode to a point. Try to create a tip and sharpen it to help it become more rounded as you weld. Place the electrode into an electrode holder with the tip about 1/4-inch away from the sheath. Choose the settings on your tig welder. The three main ones are AC, DCEP and DCEN. Choose AC for aluminum. Slide the "cleaning/penetrating" slider more to the penetrating side. Set the "air on" to five seconds and the "max amps" to 250. Turn on the gas. For aluminum, use pure argon. For steel, an argon and carbon dioxide mix. Scrub your welding table or flat piece of sheet metal with a wire brush to make it clean and flat. Gear up in full welding safety gear including hood, goggles, apron and gloves. Hold the electrode in your dominant hand and start your welding project. Check your settings every so often to make sure they haven't changed and adjust as needed.
Aug 27, 2008 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
Welding Tools Logo
252 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
