Question about Apple Cinema HD 30" LCD Monitor
Does any one know where I can get a Service / repair manual?
My monitor when turned on for several minutes has pixels that start freaking out in patterns and I wanted to take a look and see if there is anything obvious. (also for curiosities sake). I am pretty sure that I will have to remove the white side plastic pieces with suction cups but I am not sure. Can anyone help? thanks Rob
  • 1 more comment
  • rknelson Nov 03, 2007
    Hi this is Rob again Sotty for the delay I have checked all of the pins on the monitor snake and tried the monitor on another computer with the same results when the monitor is on for extended periods of time there are some flickery pixels. Any thing else i can try?
    I would still like to open it up any advice as to how? Thanks Rob
  • Anonymous Feb 20, 2008
    Exactly same problem here. Pixels go wild when monitor is turned on. Sometimes it happen suddenly even when monitor is warm.
    I would like to have Service Manual so I can open this peace of sh*t...
  • achitoni Jun 24, 2008
    Same problem here. This was the third replacement monitor from apple but has been the best one so far. It shows pixellation after running for a few hours/days. Switching it off, waiting a few seconds and then switching back on helps most of the time. But very annoying. Looking forward to a solution.
    Novelist:
    Champion:
  • 382 Answers
Have you reconnected the dvi on the rear of the machine? I would test the connection and reset the graphics card before opening the display.
keep me posted.
Posted on Oct 29, 2007
SOURCE:
How to fix a dead pixel
pressure method. 1. Start by turning off your monitor. 2. Find a pen that has a rounded, dull end and get a slightly damp cloth to protect your screen. 3. Fold your cloth in two so that you do not puncture it accidentally. You don???t want to scratch your precious screen, do you? 4. Put the cloth in front of the stuck pixel and start applying slight pressure on it with your pen. Do not put pressure anywhere else than on the defective pixel, or you may break additional ones. 5. Continue applying pressure, and turn your monitor on. 6. Remove the pen from the screen, and voil? ! The stuck pixel should be gone.
Aug 26, 2011 | Panasonic AG-DVC200 DV Digital Camcorder
I have a red dot on a Coby TF-TV2001. What can I do to repair this?
If you mean you have a pixel that is stuck on and is always red, there's nothing you can do. The only cure is to replace the display. LCD displays sometimes will have a pixel (sometimes several pixels) that doesn't work properly. The manufacturers know this, and as long the display falls within their specifications for what's acceptable, they don't see anything wrong. These specs include the total number of bad pixels, the number of bad pixels that can be clustered together, and where they can be on the display. If you have just one or only a few bad spots, they won't do anything for you. If other problems develop, such as a whole row or column goes bad or a section of the display fails, then you can see about having them fix it if the warranty is still in effect.
Dec 28, 2010 | Coby 20" Flat Screen TFT LCD TV Monitor
Obd2 system rediness status won't clear so I can run the smog test due to replacing the battery.
takes a long time to run the rediness test since there are 6 different tests to complete...
PROCEDURE 1
EVAPORATIVE EMISSION SYSTEM LEAK MONITOR
Inspection Conditions
Engine coolant temperature: 30°C (75°F) or less (The engine is stopped before the test drive is started).
Atmospheric temperature: 5 - 30°C (41 - 113°F).
Condition of A/T: Selector lever D range.
Fuel remained in fuel tank: 30 - 50% is recommended.
Time required: 16 minutes or less after started the engine.
Drive cycle pattern: One trip monitor (from start to ignition switch to "LOCK" (OFF) position. Well be completed while traveling with the following drive cycle pattern.
Test Procedure
Engine: start.
Accelerate until the vehicle speed is 89 km/h (55 mph) or more.
While keeping the accelerator pedal opening degree constant, keep the vehicle speed at 89 km/h (55 mph) or more and travel for 16 minutes.
Return the vehicle to the shop, then turn the ignition switch to "LOCK" (OFF) position.
PROCEDURE 2
FUEL TRIM MONITOR
Drive Cycle Pattern
Engine coolant temperature: 100°C (212°F) or less.
Atmospheric temperature: -10 - 60°C (14 - 140°F).
Time required: 30 minutes or more.
Drive cycle pattern: One trip monitor (from start to ignition switch to "LOCK" (OFF) position). Will be completed while traveling with the following drive cycle pattern.
Test Procedure
Engine: start.
While keeping the accelerator pedal opening degree constant, keep the vehicle speed at 89 km/h (55 mph) or more and travel for 30 minutes.
PROCEDURE 3
CATALYTIC CONVERTER MONITOR
Drive Cycle Pattern
Atmospheric temperature: -10°C (14°F) or more.
Engine coolant temperature: Not set.
Time required: 16 minutes or more.
Test Procedure
Engine: start.
Travel for 300 seconds or more while keeping the vehicle speed at 89 km/h (55 mph) or more.
Decelerate until the vehicle speed is within 80 km/h (50 mph) or less.
While traveling at 56 - 80 km/h (35 - 50 mph) for 10 minutes or more, fully close the throttle at least once in 2 minutes and decelerate for 10 seconds or more.
Do not repeat deceleration too often.
Vehicle speed may go below 56 km/h (35 mph) after the deceleration.
Stopping and braking are permitted. (If stopped or drive at 56 km/h (35 mph) or less for more than 5 minutes the monitoring may be stopped. In this case please restart monitoring from the beginning.)
After completing the above deceleration, bring the vehicle speed back to 56 - 80 km/h (35 - 50 mph) and keep it in the range until starting the deceleration again.
Repeat the above deceleration at least 5 times.
PROCEDURE 4
HEATED OXYGEN SENSOR MONITOR
Drive Cycle Pattern
Engine coolant temperature: 100°C (212°F) or more.
Atmospheric temperature: -10°C - 60°C (14 - 140°F) or more.
Test Procedure
Engine: start.
Accelerate until the vehicle speed is 56 - 80 km/h (35 - 50 mph).
While keeping the accelerator pedal opening degree constant, keep the vehicle speed at 56 - 80 km/h (35 - 50 mph) and travel for 16 minutes or more.
Stopping and braking during this operation are permitted. Keep the accelerator opening degree constant for 1 minute or more after each acceleration.
PROCEDURE 5
EXHAUST GAS RECIRCULATION (EGR) SYSTEM MONITOR
Drive Cycle Pattern
Atmospheric temperature: 5 - 60°C (41 - 140°F).
A/C switch: OFF.
Test Procedure
Engine: start.
While traveling 16 minutes or more at 56 - 80 km/h (35 - 50 mph) with engine speed 2,000 r/min or above, fully close the throttle at decelerate for 5 seconds or more until the engine speed reaches 1,000 r/min or under.
Stopping and braking are permitted (Rapid deceleration and sharp steering are not permitted).
After completing the deceleration, bring the vehicle speed back to 56 - 80 km/h (35 - 50 mph) and keep it in the range until starting the deceleration again.
Repeat the above deceleration at least 8 times by fully closing the throttle valve.
PROCEDURE 6
OTHER MONITOR (Main Components, Sensors & Switches, Wire Breakage & Short Circuit)
Drive Cycle Pattern
100°C (212°F) or less (Except engine coolant temperature sensor monitoring).
30°C (86°F) or less (Engine coolant temperature sensor monitoring).
5°C (41°F) or more (Except engine coolant temperature sensor monitoring).
-10°C (14°F) or less (Engine coolant temperature sensor monitoring).
Time required: 21 minutes or more.
Test Procedure
Engine: start
Accelerate until the vehicle speed is 56 km/h (35 mph) or more.
While keeping the accelerator pedal opening degree constant, keep the vehicle speed at 56 km/h (35 mph) or more and travel for 16 minutes or more.
Return the vehicle to the shop.
After stopping the vehicle, continue idling for 5 minutes, and then turn the ignition switch to the "LOCK" (OFF) position. Moreover, the vehicle should be set to the following conditions for idling.
A/C switch: OFF
Lights and all accessories: OFF
Transmission: Neutral
Sep 15, 2010 | 1998 Mitsubishi Eclipse
Dead pixel anything i can do about it my tv is 2006
  3. Fold your cloth in two so that you do not puncture it accidentally. You don’t want to scratch your screen, do you?
  6. Remove the pen from the screen, and voilà! The stuck pixel should be gone.
  7. Be very careful doing this. The monitor is very fragile and too much pressure may cause more dead pixels. You can also just try it with your finger while the screen is on... just massage the area. NOT TOO MUCH PRESSURE! also try tapping that spot... if you see a little white color while you tap that is plenty of pressure. Let me know if that helps it. (This is only for LCD)
Jan 11, 2010 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
Screen freaks out when external monitor connected
prombelms quite simple your 42 inch monitor has to many colors for the driver and it cann't work with it is incompatiable.....lala linda
Jan 06, 2009 | Acer Aspire 5100 Notebook
Screen crazies
Doesn't sound like a good situation. My knee **** reaction would be to reseat the cable and power to the LCD screen. If that doesn't work, I'd take advantage of the warranty. They might be able to get you up and running in short order.
Hope this helps!
Ron
Jul 28, 2008 | Dell Latitude D630 Notebook
Monitor image flashes off and on
Sounds like you've done all the trouble shooting. If you just need that extra nudge, I would agree... it sounds like you'll be needing to shop for a new monitor.
Jun 29, 2008 | Dell E153FP 15" LCD Monitor
Monitor goes blurry, colours/pixels start shaking across screen
Do you have your screen saver enabled, i so turn it off and se if it still does it. Secondly boot your pc in safe mode(pressing F8) on boot up and select start windows in safe mode. See if the monitor still does it, if so a monitor fault or loose/faulty vga lead. If it is ok then your graphics driver may be corrupt and need re installing.
Dec 30, 2006 | BenQ FP71E 17" LCD Monitor
Monitor revives only after cycling the power many times
Unscrew 4 screws on the back side. Place the monitor with the front up and open it along the upper seam. Turn it again and lift the back cover. Shift the inner case "up" and take the button holding plate out - it is being held only by a tape. Inspect it and clean it. You might have to replace the condensers and/or switches on it.
This might solve the problem, but there may be other causes as well.
Aug 03, 2006 | Dell UltraSharp 1905FP 19" LCD Monitor
Apple Cinema HD 30" LCD Monitor Logo
100 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Ekse
Jeffrey Groves
Jeffrey Groves
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
