Question about Oster HDX23 12-Cup Coffee Maker
Will not perk coffee - Oster HDX23 12-Cup Coffee Maker
When perking coffee in the Keurig, only 1/2 a cup perks and the remaining water goes back into the reservoir. What's wrong.
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Feb 26, 2011 | Keurig Special Edition B60 Coffee Maker
Perks ok coffee lukewarm
After perking the coffee the pot is to switch to a thermostat to keep the coffee warm...that thermostat is probably bad...
Not sure if it is replaceable on those pots...
Would call the Customer service number for the Regalware...
http://www.regalware.com/customer-service/contact-us
heatman101
* Contact
262-626-2121
1675 Reigle Drive
Kewaskum, WI 53040
(google map)
Dec 08, 2010 | Regal Ware K1301 Coffee Maker
I have a 55 cup Farberware Urn. Pot will perc coffee sometimes & sometimes not. Problem exists since new, & have replaced both thermos. Water gets very hot, but not as Coffee. Sounds like...
Hi. The spring slips onto the stem just under the coffee basket, it holds the stem with pressure so the perked coffee go up the stem onto the spreader, check repairshack.com Ron
Aug 15, 2010 | Faberware 12-55 Cup Coffee Urn
Coffee is not hot. Only about 100 degrees.
Hi. If it perks it is not the main element, it is the keep warm element, it is very instrumental in perking. Water should be about 170 to 190 they all differ a bit. Go to repairshack.com. Good luck. Ron
Feb 12, 2010 | Faberware 12-55 Cup Coffee Urn
Need a manual for west bend party perk, no. 58030
wont shut off automatically and the light wont go on
Dec 11, 2009 | West Bend 58030 Coffee Maker
My stainless steel Mr. Coffee maker just quit perking coffee and the water does not run totally through. It has been perking slower and less quantity but today I cleaned it by running vinegar through it...
this is set up on a conventional mr coffee; if the hot plate is not as hot, it will not work, on the newer ones, a small chip could be getting hot, and like a car, it will either shut down or work part time. send it back to mr coffee, and they'll repair it, but it might be cheaper to replace it.
Jul 02, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
VillaWare mini-perk 5120-o5 clear perc top
I have a miniperk 5120-05 that has stopped working.  I will let you have the whole thing if I can not get it fixed.
Jul 24, 2008 | VillaWare Mini-Perk 5120-05 Coffee Maker
Oster HDX23 12-Cup Coffee Maker Logo
15 people viewed this question
Top Oster Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
richie46
Are you an Oster Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
