Question about Healthometer Health o meter Glass Digital Scale Hdm545dq 37 (Health O Meter)
Calibrate HDM545DQN-37 B356DT
SCALE SHOWS 20 TOO MUCH
Scale shows time but will not show weight, shows Err
Go buy a new scale. That one is toast.
Dec 29, 2015 | Health & Beauty
Model 9114 salter scale shows Lo. I have changed the batteries but it still only shows Lo.
I had the same problem and, suspecting that the metal contacts weren't making proper contact with the batteries, I used a long nosed pliers to gently bend all ten contacts towards to the batteries (there are eight small tabs in the battery compartment, and two on the battery cover). If you don't have a long nosed pliers a small screwdriver should do it if you held the fixed part of each set of contacts so it doesn't detach during the process.
Unfortunately, it worked, but only for one weigh, and then it reverted to "Lo". This happened twice, so I telephoned the Salter Customer Service Helpline (01732 360783) who recommended a reset, which is done by removing the batteries, standing on the scale for 20 seconds, and replacing the batteries. That also only worked for one weigh, so they are looking into it further and I'll post the results here, but in the meantime I hope one of the above solutions will work for others.
Jan 21, 2014 | Salter Stainless Steel Electronic Bathroom...
What is the Minimum Curve Radius for Model Trains?
The length of your equipment, even more than the scale of the model, is the most important factor in setting a minimum radius. The list below includes conventionally accepted minimums for each of the major scales.
  • Z Scale: 195 mm
  • N Scale: 9 3/4 inches
  • HO Scale: 15-22 inches
  • HOn3 Scale: 15 inches (narrow gauge)
  • S Scale: 20 - 30 inches
  • O Scale ("Toy"): 13.5 inches
  • O Scale ("Scale"): 72 inches
  • On3 Scale: 36 inches
  • G Scale: 24-44 inches
Jan 10, 2013 | Crafts & Hobbies
Error 2 . How can we solve this problem. Thank you, Margaret
I found this procedure which was given by Taran_2005. I just come to try him(it) on mine, that works.
"The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight, or some other unusual error.
  1. Remove the battery from the scale.
  2. Sit the scale on a hard surface floor.
  3. Step up onto the scale, stand still for about 5 seconds and step off the scale.
  4. Re-install your battery.
  5. Place the scale back on a hard surface floor.
  6. With one foot only, place just enough weight on the scale for the display shows zero's or dashes. Once you see zeros or dashes remove your foot.
  7. Wait for the scale to turn off again.
  8. Step up onto the scale for a weight.
If the reset is successful, you should receive a weight right away."
Sep 10, 2011 | Terraillon FBC Alteo Family Body Control...
My Soehnle scale shows an out2 error - how do I fix?
How to calibrate when "out2" is shown.
With the power off andthe scale on a stable surface, hold "g" and press "on". Some number will show up, probably a negative number. Press the "on" button again and the scale should display "Zero". Wait until it says "200.0". Gently place a 200 gram weight on the scale and wait a few seconds. If your successful it will say "Pass" and your scale will work again, yay!
May 14, 2010 | Salter 2001 electronic kitchen scale
Nothing will display on the read out
  6. With one foot only, place just enough weight on the scale for the display shows zero’s or dashes. Once you see zeros or dashes remove your foot.
If the reset is successful, you should receive a weight right away. If you continue to receive one of the error messages above please call our Customer Service department or contact us via email. You can also try the reset procedure a 2nd time. Sometimes the reset procedure will work the second time.
Jan 03, 2010 | Taylor Dgtl Body Fat Scale
I must create scale diagram of my kitchen on a
Convert your meters to centimeters and divide by 20. That gives you 1/20 scale
Oct 15, 2009 | Kitchen Appliances - Others
How to calibrate a Pelouze model 4010 scale with a
when i turn on my 4010.the screen display shows 4010 but thats all it does.any solution.
Jul 08, 2009 | RTO Pelouze Scale With Remote Display -...
How to calibrate a taylor scale 5571
The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight,to calibrate, or some other unusual error.
If the reset is successful, you should receive a weight right away. If you continue to receive one of the error messages above please call our Customer Service department.You can also try the reset procedure a 2nd time. Sometimes the reset procedure will work the second time.
Jun 13, 2009 | Taylor Body Fat Analyzer & Scale, Model...
Healthometer Health o meter Glass Digital Scale Hdm545dq 37 (Health O Meter) Logo
74 people viewed this question
Top Healthometer Health & Beauty Experts
StormERage
Level 1 Expert
Tom Chichester
Bill Boyd
Are you a Healthometer Health and Beauty Expert? Answer questions, earn points and help others
