Question about Onkyo Remote Control RC-590M p/n:24140590
Red light flashing
Remote doesn't work
Tried to pair it to buttons in car dealer couldnt pair to car and now the remote wont work. the red light flashes when remote pressed but nothing works ?
what you are trying to pair and to what car? is pretty important here. Its like me saying i put it in the machine and it wont work. Whats up with machine
Aug 02, 2017 | Cars & Trucks
FLASHING RED LIGHT ON MY SHARP LCDTV REMOTE RC1910
Check it with fresh batteries. For some remote controls; if battery became low, this should happen. Electro help
Oct 24, 2014 | Sharp LC Televison & Video
Bought a new will remote but it doesn't work.
Check the battery levels. You can do this by pressing A. If all 4 lights flash on and off, your batteries are completely charged. 3 lights, 2 lights, and 1 light signify 3/4, 1/2, and 1/4 battery levels. If lights don't flash, replace/insert batteries.
If it's not working with your console, open up the battery cover and the flip lid on the front of the console. (If it's a Wii U, you don't need to open the flip lid.) In both places, there is a red button. (On Wii U, it's next to the flip lid.) Press both red buttons at the same time. (Your Wii will need to be powered on.) The Wii Remote will continuously flash lights until it either receives a sync signal or about a minute has passed; whichever comes first. If you've pressed the buttons and your remote is still flashing, press the button on the console again. Once the remote is synced, the flashing lights will turn into a single light; the placement of the light will vary depending on how many remotes are signed into the Wii.
*Note* Once your remote is synced, you simply need to press A to sign back in if your remote turns off.
If all of the above steps were followed, and your remote is still not functioning, contact the manufacturer. Brands such as Nintendo and Nyko are usually okay, but generics like GameStop aren't the best. It's often easiest to return it and buy a different brand.
Apr 29, 2014 | Nintendo Wii Console
My remote doesn't work
Do you have any flashing indicator lights on the remote? If you don't you can verify your remote is sending IR signals by pointing a cell phone camera at the front of the remote and viewing through your cell phone screen while holding down a button on the remote. You should see the flashing IR light on your cell phone screen. If you do not see the flashing light either the batteries are no good, or the remote is not getting power due to a problem with the circuit board.
Nov 23, 2012 | Apex Digital Apex 40" Class 1080p 60Hz LCD...
The TV stopped responding to the remote control
tried with reset doesn't work, ok it could be the IR sensor at the front panel of the tv doesn't work. but before you replace it you need to ensure if your remote controller is working. have you tried to check the remote with camera trick just to know if the remote controller is sending light to the IR sensor of the tv.
Sep 23, 2012 | Advent LC-20H15A 20 in. EDTV-Ready LCD TV
Wii remote not working?
You got to sync the remote with your console to activate the remote
Aug 09, 2017 | Nintendo Wii Console
Samsung le40
Have you checked all the inputs to the television? It might be blinking because it doesn't see a signal. If all the inputs are secure try pressing the input select button on the remote. If that doesn't work it never hurts to try unplugging the power cord, waiting a minute, and plugging it back in.
Dec 18, 2011 | Samsung Televison & Video
When my Motorola H720 is plugged in, the red light is flashing quickly, what could be wrong with this? It does not seem to turn on either....problems?
Red light flashes when I try to charge it and nothing all other times. Doesn't turn on, doesn't work. I pretty sure the problem is that it is a piece of junk.
Mar 17, 2011 | Motorola Mobility H720 89382N Bluetooth...
After pressing the red sync button on the console for about 10-15 seconds, and syncronizing the remote, the remote stars to work, but when I start a game the remote is no longer working. Then when I...
There are two ways to sync the Wii remote with the Wii console after pressing the red sync button like you did:
1) Press the "1" and "2" buttons on the Wii remote until the lights begin to flash. This method provides a temporary connection to the Wii.
2) Open the battery cover on the Wii remote and press the red button next to the batteries. This creates a permanent connection or "pair" between the Wii remote and the Wii console.
Based on your description, it sounds like you are using method #1. In order to power on the Wii when the Wii's red light is on (meaning the machine is turned off) and start playing games like you want, method #2 must be used.
Imagine method #1 as "guest mode". If a friend comes over with their Wii remote and wants to play a game, you would open up the game first, use method #1, and your friend would temporarily be connected to the Wii. Using method #1 is like "owner mode" that lets the Wii remote turn the console on and off and always stay connected to it.
Hope this helps!
Mar 10, 2011 | Nintendo Wii Console
Rockband Guitar won't sync
try syncing up one remote so it logs in as player #1 and then press the button to sync the guitar and it should sync up as player #2
Dec 26, 2008 | Nintendo Rock Band for Wii
Onkyo Remote Control RC-590M p/n:24140590 Logo
32 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
