Question about PIAA 2000 Buick Le Sabre - All LeSabre models - Xtreme White Bulbs
Cruise control not working - PIAA 2000 Buick Le Sabre - All LeSabre models - Xtreme White Bulbs
Tip
TROUBLESHOOTING WHY YOUR CRUISE CONTROL DOESN'T WORK
There are many things that can cause your cruise control to act up or not work at all. This article will lead you in the correct direction on finding a solution to your problem. This article is for any type of vehicle.<br /> <br /> <b>If your cruise control won't hold proper speed, </b>you need to look at the following parts. <br /> <ol> <li>Faulty Cruise Control</li> <li>Faulty Speed Sensor</li> <li>Faulty Vacuum or Vent Valve</li> <li>Faulty Stepper Motor</li> <li>Faulty Transducer</li> <li>Incorrect Cable Adjustment</li> <li>A Binding Throttle Linkage</li> <li>Leaking Vacuum Tank</li> <li>Leaking Vacuum servo diagram</li></ol> <b>If your cruise control surges, </b>check the following parts.<br /> <ol> <li>Faulty Cruise Control Module</li> <li>Faulty Speed Sensor</li> <li>Binding Throttle Linkage</li> <li>Kinked Speedometer Cable</li></ol> <b>If your cruise control cuts out on you, </b>check the following parts.<br /> <ol> <li>Faulty Transducer</li> <li>Faulty Cruise Control Module</li> <li>Short or Open Circuit in Cruise Control</li> <li>Brake or Clutch Switch Adjusted too tight</li></ol> <b>If your cruise control doesn't work at all, </b>check these parts.<br /> <ol> <li>Faulty Cruise Control Module</li> <li>Short or Open Circuit in Cruise Control</li> <li>Faulty Clutch or Brake Switch</li> <li>Leaking Vacuum Circuit</li> <li>Faulty Stepper Motor</li> <li>Faulty Speed Sensor</li> <li>Faulty Transducer</li> <li>Faulty Cruise Control Switch</li> <li>A Blown Fuse</li></ol>
on Jul 20, 2011 | Ford F-150 Cars & Trucks
cruise controls are dependent on the following sensors all working together
brake sensor
clutch sensor
auto--vehicle speed sensor
rpm's sensor
fuse for the cruise control
cruise control switch either or all not working will stop the cruise control from engaging
road speed at which you can engage the cruise control has to be above a reset speed before it will cut in and work
Sep 05, 2015 | 2009 Chevrolet Chevrolet Equinox LS
What causes my cruise controll to not work intermittenly
cruise control starts working above 50kmh, so if your under that it wont work. the cruise servo may be at fault, or I have seen battery acid leak down on the vacuum lines causing cruise not to work correctly. cruise control works off of a vacuum so without it, it wont work. if the cruise light doesn't turn on when pressing the set/cruise button intermitantly it may be the switch itself that is starting to fail
Apr 24, 2014 | 2004 Chevrolet TrailBlazer
CRUISE CONTROL WON'T WORK ON 2005 CHEVY TRAILBLAZER
check cruise control fuse and check the brake lights see if brake light working because the brake light switch will deactivate cruise control when brakes is applied.if brake lights dont work either fuse blowed or switch bad.if all is good have vechicle code scan because cruise control control by PCM and vechicle speed sensor and thottle actuator control motor.
Apr 17, 2013 | 2004 Chevrolet TrailBlazer
Crusie control does not work on 2011 gmc sierra 1500 and I've already replaced the switch?
If the switch is replaced,then it can be wiring issue or faulty cruise control board.But as the switch is replaced,get the voltage at the switch tested to confirm the switch is actually receiving voltage.If no voltage received at switch power supply wire then ,apply external 12 volt power to the cruise control switch wire and then see if cruise control comes ON.If yes,then you know wiring is issue.
On this case, to troubleshoot this problem, there are solved help links. Click the link directly and refer the details to solve this problem yourself, with help of diagrams: ------
Ford ranger cruise control not working? http://technoanswers.blogspot.in/2012/02/ford-ranger-cruise-control-not-working.html
Horn and Cruise control quit working?
http://howtobyme.blogspot.com/2011/11/horn-and-cruise-control-quit-working.html
Horn and cruise control not working on Plymouth Grand Voyager?
http://howtobyme.blogspot.com/2011/11/horn-and-cruise-control-not-working-on.html
Horn and Cruise control quit working on 2003 Jaguar S-Type?
http://howtobyme.blogspot.com/2011/11/horn-and-cruise-control-quit-working-on.html
Cruise Control stops working, Excessive cranks to start the engine and RPM goes max 2500
http://whoisbyme.blogspot.in/2012/07/cruise-control-stops-workingexcessive.html
Cruise control stop working on 1994 Ford ranger?
http://technoanswers.blogspot.in/2012/02/cruise-control-stop-working-on-1994.html
Cruise control not working?
http://schematicsdiagram.blogspot.com/2011/12/cruise-control-not-working.html
1996 Ford Explorer: Cruise Control Wiring Diagram?
http://schematicsdiagram.blogspot.in/2012/06/1996-ford-explorer-cruise-control.html
These will help.
Thanks.
Nov 28, 2012 | GMC Cars & Trucks
On these case,to troubleshoot these problem,there are solved help links.Click the link directly and refer the details to solve these problem yourself,with help of diagrams:------
----------- Horn and Cruise control quit working?
Horn and Cruise control quit working on 2003 Jaguar S-Type? http://howtobyme.blogspot.com/2011/11/horn-and-cruise-control-quit-working-on.html
Cruise Control stops working, Excessive cranks to start the engine and RPM goes max 2500 http://whoisbyme.blogspot.in/2012/07/cruise-control-stops-workingexcessive.html
Cruise control stop working on 1994 Ford ranger? http://technoanswers.blogspot.in/2012/02/cruise-control-stop-working-on-1994.html
Cruise control not working? http://schematicsdiagram.blogspot.com/2011/12/cruise-control-not-working.html
These will help.
Thanks.
Nov 22, 2012 | 2003 Ford Expedition
How to fix cruise control
Cruise controls can cease to engage if the clutch or brake light cruise switch are out of adjustment. If this happens, try placing you foot under the clutch pedal (if equipped) and lift up on it (toward you) and hold it while engaging the cruise. If it now works, it will likely cut out when you remove your foot from under the pedal. Check the brake pedal in an identical fashion. Adjusting the switch at the pedals can often solve he problem. Some vehicles (Honda, Acura, Ford, to name a few) have a plastic insert that mounts in the pedal arm which presses against the switch. These can become brittle and fracture into pieces. My Acura has little pieces of blue plastic on the floorboard around the brake pedal one afternoon and I noticed the cruise didn't work. It was the pieces of the insert that had come to pieces preventing the cruise from coming on. I replaced the insert and no more problem with the cruise.
Mar 10, 2012 | 2003 GMC Sierra 2500HD
Cruise control don't work
To troubleshoot your problem,there are few help links,provided below.Click the link directly and follow the procedure to confirm the fault.So as per that you can continue further in repairing this issue of cruise control not working.
The direct help links are as follows :-----cruise control not working?
-----------Horn and Cruise control quit working?
Horn and cruise control not working on car?
Horn and Cruise control quit working suddenly?
Cruise control stop working ? http://technoanswers.blogspot.in/2012/02/cruise-control-stop-working-on-1994.html
ford ranger cruise control not working? http://technoanswers.blogspot.in/2012/02/2005-ford-ranger-cruise-control-not.html
My Cruise control not working? http://schematicsdiagram.blogspot.com/2011/12/cruise-control-not-working.html
This troubleshooting help links will help you to confirm the problem.
Thanks.
Feb 13, 2012 | Chevrolet 3500 Cars & Trucks
PIAA 2000 Buick Le Sabre - All LeSabre models - Xtreme White Bulbs Logo
244 people viewed this question
Top PIAA Optics Experts
Lawrence Oravetz
Vernon Taylor
Are you a PIAA Optic Expert? Answer questions, earn points and help others
