Question about Radio Communications
Schematic sadelta mp22 - Radio Communications
How do i get parts for the sadelta echo master plus microphone
depends on what parts you need but this company sells a few parts for sadeltas but limited !!! www.hyelectronics.com good luck !!!!
Mar 05, 2014 | Radio Communications
Repair sadelta microphone
try using another mic to see if the mic IS the problem.You might get away with it cheap. You didn't say what was wrong with it , maybe I can help you to fix it.
Sep 07, 2013 | Radio Communications
NEED TO WIRE LESON MICROPHONE TO MAGNUM 257
Notice the black mic plug has the numbers it is solder by numbers. Used rosin core silver solder radio shack sells it.
Mic Wiring
Stock
1-Shield (ground)
2-Yellow (audio)
3-Red (transmit)
4-White (receive)
Astatic
1-Shield & Blue
2-White
3-Red
4-Black
Yellow NC
Turner Roadking 56
1-Shield & Red
2-White
3-Blue
4-Black
Yellow NC
Sadelta the is a BASE mic
1-Shield
2-White
3-Brown
4-Green
Oct 02, 2011 | Magnum 257 CB Radio
I need to wire a sadelta es 880 echo chamber to my cobra 25 LTD ST MOBILE . if i have locator grove on plug upwards . ty for any help you can give
First of all, if you will look closely at the end of the mike plug, you will see numbers 1-4. 1- is shield, 2- is audio,white, 3- is transmit-red, 4-is receive,-black,.....hope this was helpful...
Apr 25, 2010 | Cobra 25 LTD 40-Channels Base CB Radio
Whats the wiring diagram to connect a sadelta es990 to a superstar 3900
1) Shield 2) White 3) Brown 4) Green
1) Shield/ Ground
2) Audio
3) Transmit
4) Receive
Mar 30, 2010 | Superstar SS-3900EGHPA CB Radio
I have a Cobra 21- 23 channel CB and the wires pulled out of the plug. The mike wire has red,yellow black,blue,whiteand a ground. My plug has only four prongs to solder to. What four colors do I use?
Hello there
Here is the diagram for you
Cobra 29LTD, 29LTD ST, 29WX ST
Documentation Project
CBTricks.com
TIPS:
You need to have Acrobat Reader version 5 or newer installed to view the files with pdf_1.gif icon.
If the files with jpg.gif or gif.gif icon will not display see the Site FAQ for help on printing, viewing and using this information.
Click Picture to See Close-up
DIAGRAMS
Page 1 to 11
Page 12 to 34
29LTD
29 LTD Classic Schematic Diagram pdf_1.gif(Courtesy of Rick Jackson)
Mic Wiring
Stock
1- Shield
2- Audio
3- Transmit
4- Receive
Astatic (4 wire)
1- Shield
2- White
3- Red
4- Black
Astatic (6 wire)
1- Shield & Blue
2- White
3- Red
4- Black
Yellow NC
Daiwa EM-500
Cobra CA Series
1- Shield & Black
2- Red
3- White
4- Blue
Galaxy DC-521S (4 wire)
1- Shield
2- Yellow
3- Red
4- Black
Galaxy CB-660EI
1- Shield & Black
2- White
3- Red
4- Blue
Sadelta
1- Shield
2- White
3- Brown
4- Green
Turner
1- Shield & Red
2- White
3- Blue
4- Black
Yellow NC
Nov 17, 2009 | Cobra 29 LTD CB Radio
Micwiring
Wiring the microphone is as follows:
Sadelta 1-White,2-NC,3-Green,4-Shield, 5-Brown
I hope this helps. If I can assist you any further please add a comment.
Oct 08, 2008 | Radio Communications
Omegaforce s45 mic wiring
Sadelta
1-Shield - Ground
2-White - Audio
3-Brown - Transmit
4-Green - Receive
Does this color code look like what you have in your mic?? sorry for the delay,,, Mechanic
May 09, 2008 | Magnum OmegaForce S45 CB Radio
Wiring for echo chamber to uniden 300
Mick, check out this site, they talk about some of the same equip. as your asking about. It's a very good site.
http://www.radiomods.co.nz/forum/viewtopic.php?p=5303
hope this helps you with your search, Mechanic
Nov 18, 2007 | Radio Communications
Radio Communications Logo
70 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
