Macbook pro 13" crashes while booting.
When i switch the macbook on i hear the chime,then i see apple logo with the wheel spinning and few seconds later it shuts down every time.when i tried single user mode it runs tests and it crashes down after some time.when i run verbose mode it gives me bootcashecontrol:unable to open /var/db/bootcache.playlist: 2 no such file or directory... and it crashes again please help.tried smc reset,nvram reset nothing worked still the same
    Scholar:
  • 59 Answers
Have you tried booting off of your restore disc? During startup you can boot from a CD, DVD, or thumb drive by holding "C" while booting. You can also try starting into recovery system by pressing "R" and "command" keys while booting, but I'd reccommend trying the bootable disc method first. Hope this helps!
Posted on May 03, 2014
SOURCE: macbook pro unexpected shut down
After determining the battery health:
http://support.apple.com/kb/HT1519
Then calibrate the the battery:
http://support.apple.com/kb/HT1490
Posted on Apr 22, 2009
SOURCE: Macbook Pro just shuts down
This sometimes happens when you have it plugged in to an electrical socket as well. I have recently been having this problem and I have a brand new battery, so it's likely the logic board. If you're still having the problem, and the monitor image shows weird fragmentation on startup, it's likely to be the logic board that needs to be replaced.
Posted on May 05, 2009
damien729
  • 221 Answers
SOURCE: macbook recognizes dell projector, but not vice versa
Your Macbook should automaticaly find the best resolution, if everything was OK. Is there any HDMI input on the dell projector? What projector is it? Is there is an HDMI input, you can use a HDMI to mini DVI cable: better picture and sound than VGA, and will probably solve your problem
Posted on Jun 27, 2009
  • 20 Answers
SOURCE: MacBook won't start up.
If you have your Mac OS X Install disc, insert it into the drive.
Restart the computer and hold down "C" while booting.
Choose your language.
Select "Disk Utility" from the "Utilities" in the menu bar.
Select your Macbook's hard drive in the left sidebar.
Click the "First Aid" tab thats along the top of the viewer window.
Click "Verify Disk" (not verify disk permissions)
If this shows errors click "Repair Disk"
Once completed close the Disk Utility window.
Restart the computer.
If this fails to fix it as well then your next option would most likely be recovering your files from the macbook either by booting into target disk mode (hold down T at startup) and transferring them via a firewire cable, or removing the hard drive and hooking it up to another Mac to get the files. Then do a clean install of Mac OS X using your installation discs.
Posted on Feb 15, 2010
Macs R We
  • 481 Answers
SOURCE: help with my macbook air, it shows only the apple
Power the machine down. Press the power button to turn it on. After you hear the startup chime, press and hold the shift key. This will trigger an extended file system check and a safe boot. Continue holding the shift key down until you see the spinner, then you can release it. If it doesn't boot completely after this, you will have to bring it in to an Apple-certified tech for repair.
Posted on Apr 03, 2010
MacBook Pro does not start. Gets stuck on the apple logo
Have you tried a PRAM start?
Switch machine off. Restart> when you hear the first Chime, hold down the following four keys at the same time (tricky but can be done) ALT>CMD>P>R. Keep them held down until you hear the second Chime then release.
Feb 02, 2015 | Apple 15.4" MacBook Pro Notebook Computer...
My Macbook pro turns on but then gets stuck at the Apple logo with the loading gear and never finishes loading.
See if you can start your Mac in safe mode:
Shut down your Mac and wait 10 seconds.
  1. Press the power button.
  2. Immediately after you hear the startup tone, hold down the Shift key. You should press the Shift key as soon as possible after you hear the startup tone, but not before.
  3. Release the Shift key when you see the gray Apple logo and progress indicator (spinning gear).
To leave safe mode, restart your Mac normally without holding down any keys during startup.
If you can boot in safe mode, you have something on board your computer that's interfering with startup. If you've recently installed software, system extensions or 3rd party preference panels (Adobe and Microsoft stuff is notorious), try to disable or de-install it. If you can't get booted in safe mode, you may have a hardware or memory problem that might require technical repair. Repost your progress.
Apr 05, 2013 | Apple 13.3 MacBook Pro Notebook Computer ...
How do you start in safe mode? I started with power and shift. Then what do I do?
To start up in safe mode:
Shut down your computer and wait 10 seconds.
Nov 13, 2010 | Apple MacBook Mac Notebook
When I booted my Macbook Pro today, I could hear the hard drive being accessed, but the screen remained black. Have you heard of this problem before? Last night, it was fine and showed no symptons
yes this happens. you can try doing this: power down then power up whilst holding down command, option P and R all at the same time. press these after you hear the chime. hold until you hear the chime a second time.
May 05, 2010 | Apple MacBook Pro Notebook
My MacBook turns on, but stays on a white screen and does not load the OS. Any ideas how to fix?
Dose the apple logo comes and the spin or no ?
if its coming permission issues
if dosent come the apple logo and the spin then please reset the eprom
by pressing command +option+p+r and press the power button to on and wait till you listen three times the chime the third time release all the button and say hello to your Personel desktop
thanks
Apr 18, 2010 | Apple 13" MacBook Notebook Computer ...
Help with my macbook air, it shows only the apple logo and a spinning wheel
Apr 01, 2010 | Apple MacBook Air
Feb 15, 2010 | Apple MacBook White- 2.1GHz Intel Core 2...
When I start up my G4 I doesn't get past the white logo screen with the circular icon spinning. Have removed battery and depressed start up button until a loud beep occurs but still nothing
I had a problem with my hard discs. That's where I got, but my screen froze after a few minutes. try pressing apple + s after the chime. See if you can search around there. Also, try holding the shift key when you hear the chime, or when booting if you don't normally hear the chime, and hold it 'till you see the apple logo.
Jun 07, 2009 | Apple iBook G4 Mac Notebook
The loading 'logo' wont disappear. pls help.
Hold the power button down. Keep it down until the unit powers off. Then press power to start the machine up, and as soon as you hear the starting chime (boooong) press Command+Option+P+R and keep them held down until you hear the startup sound 3 times. Then you can let go and it should start normally.
May 02, 2009 | Apple MacBook Air
Press and hold the power button. After a few seconds, the MAcBook will shut down.
Regards,
Cybernanga
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
