Question about Hitachi Remote Control RCU-05A p/n:HL11162
How do I program a hitachi RCU-05a remote - Hitachi Remote Control RCU-05A p/n:HL11162
I have two RCA remotes. 1st RCU 310 5538P. 2nd RCU 400 2420BB.
Remote Control Support - RCA ' Made for Moments
www.rca.com/support-remotes
RCARemote Control Support. Select your Type of Remote. Remote Code Finder ...RemoteProgramming. Cable/Satellite Receiver Codes. Select Your Provider.
RCA Universal Remote Control- Target Programming ...
www.thompsontv.com/rcarc.html
RCA Universal Remote Control-Programming Codes. ... Universal Remote. The remotemay already be set up to operate your brand of TV, VCR, or Cable Box.
Program an RCA Universal Remote Without a "Code Search ...
www.wikihow.com > ... > TV and Home Audio > Television
wikiHowHow to Program an RCA Universal Remote Without a "Code Search" Button. Do you have an older RCA universal remote that you want to use, but it lacks a ...
Jan 23, 2016 | RCA Televison & Video
How to program remote control mitzu for tv daewoo
Look up code in book for your model and program it or do automatic code search.
Nov 16, 2011 | Daewoo DTQ-14V1FS 14" TV
Have RCA remote need code or no how to program it to my magnavox dvd player
Hello
Setup codes for Magnavox DVD with RCA RCU-404 universal remote control are:
057, 060, 074
OK.
Jul 19, 2011 | RCA RCU404 Remote Control
Remote control # clu-579tsi seems to stuck on the menu option
Try resetting the RCU of the remote.
- Remove Batteries.
- Press and hold the number 1 for 20 seconds.
- Replace batteries and test.
Apr 26, 2011 | Hitachi Televison & Video
Sky hd remote code needed please
Sky High Definition SkyHD uses a new design of Slim line remote control. The Default TV code pre-programmed into the RCU is now for Phillips and is (0)065. The SkyHD RCU is programmed in the usual manner using either the instructions in the Digital Installation Manual or via the Sky Customer Service option in the Interactive on-screen menu.
The SkyHD RCU can also be programmed to operate Sky+ boxes as well as SkyHD:
Press the TV button.
Press and hold SELECT and i together until the LED flashes twice.
Press the number button 1 and then press SELECT.
(Obviously you can't have a SkyHD and a Sky+ Digibox both in the same room).
Note: To re-programme the RCU for Sky HD box operation only, repeat the above process pressing the 2 button in step three.
Keep pressing HELP and waiting a few seconds until you find the correct command that activates the AV source you require then press SELECT.
The HELP button will now directly activate the chosen AV source instead of toggling through the alternative options to reach it.
There are 18 AV source commands to be tried before the RCU blinks 3 times to indicate it is out of options.
The Sky Guide buttons (SKY, tv guide, box office, services & interactive) can now be directed to use the same AV source as the newly programmed HELP button.
Press SELECT and GREEN until LED flashes twice.
Press HELP then SELECT and the LED will flash Twice.
The Sky Guide buttons will now instruct the TV to switch to the desired AV source and the RCU will be in Sky Mode.
Discussion here: http://www.digitalspy.co.uk/forums/showthread.php?t=944054
You can also use a Sky+ remote to control a SkyHD digibox.
See codes page for SkyHD
Mar 17, 2010 | Televison & Video
What is the code nomber for haier tv
You'll have to do a code search to program your RCA 3-in-1 RCU-703 Remote.
Turn on your Haier TV.
Press and hold the CODE SEARCH key until the indicator light turns on.
Release the CODE SEARCH key.
Press and release the TV key. The indicator light will blink once and remain lit.
Press and releae the OFF-ON key until the component turns off. (you may have to press the OFF-ON key up to 200 times)
When the TV turns off, press the ENTER key. The indicator light turns off.
Your should now be able to control your Haier TV.
Mar 01, 2010 | RCA Universal Remote Control 3-in-1...
RCA RCU-404 UNIVERSAL REOMTE
CyberHome DVD 1024 1023 0816
Mar 02, 2008 | Televison & Video
Hitachi Remote Control RCU-05A p/n:HL11162 Logo
24 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
