Question about Pelonis HC-461 Ceramic Heater
Code E0 pelonis heater hc-461
What do the error codes on the display indicate the heater starts the turns off immediately?
2 Suggested Answers
MNfisherman
  • 11896 Answers
SOURCE: looking for manual FOR PELONIS HEATER MODEL#
You can find your manual here:
http://www.pelonis.com/oilfill.htm
And for electric type you can get it here:
http://homeappliance.manualsonline.com/manuals/mfg/pelonis/hb211.html
Posted on May 15, 2009
Whirlpool stove shooting code F9E0
F9 or F9 E0
Possible Solutions
Reset power to the product:
This code will most often indicate that the appliance is wired incorrectly at the home electrical supply, or at the hard wire connection.
  • If your oven was installed recently (within approximately 3 months), contact a qualified electrician to verify the electrical supply.
During a power outage, if there was an unexpected amount of power supply line "noise" that the control detected as an incorrect voltage amount, the control could display the F9, F9 E0 or PF Error Code. Also, if any keys were pressed before the 10 second delay interval on power up, this could cause the F9, F9 E0 or PF to appear.
  • Power unit down by turning off the circuit breaker(s) for one (1) minute.
  • Power unit up by turning on the circuit breaker(s).
  • Monitor the oven for one (1) minute to ensure the error code does not display again.
  • Verify oven operation.
Still need help? Call or schedule service.
You may need assistance from a qualified technician. Call 1-866-698-2538 or click below to schedule an appointment.
Schedule Service Online
Feb 01, 2018 | Whirlpool Kitchen Ranges
KitchenAid KHMS155LSS when press "bake potato" button,start flashing error F3
Question: Error Code - Oven - F3 Error Code - F3 E0 Answer Product Symptom:
Error Code/Message - Oven - F3 Error Code - F3 E0
Control displaying F3 E0:
There may be a problem with the Oven Temperature Sensor, or the associated wiring.
Jul 31, 2014 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Canon Printer error code E0
To reset that error remove the two screw in both side of control panel then after that remove the control panel then you will see a board in that board just look for two terminal there is service indicate in that terminal just make it shorted that 2 terminal then turn on the power switch
Oct 03, 2012 | Canon Office Equipment & Supplies
Error E0
Error E0 results from the copier being turned off and on immediately after an error. Most likely there is another underlying error on your copier that needs to be resolved, but in some cases leaving the copier powered off for a couple hours can resolve the problem automatically. If you see another error code (most likely E000, E001, E002, or E003), your copier may need repairs.
May 10, 2012 | Office Equipment & Supplies
I love this heater but now after a few seconds of running it shuts itself down. Im wondering if there is too much dust or something that is causing it to overload the heat sensor? Its level on the...
I would definitly try to give your heater a through cleaning before before giving up on it. Remove screws that hold back cover on and remove cover. There shoulb be a fiter directly behind it,remove it and give it a through cleaning. I don't know on the new ones if the filter is made of foam material,the older ones like mine are.It is safe to wash them in warm water and a little dish soap. Rinse fully and pat dry. Clean any lint,hair,dust or any other foreign material from fan motor. Blow it out with compressed air if you can. You can use a tooth brush to clean around motor shaft and air ports on motor. You can use a couple of drops of fine grade machine oil on motor shaft,such as 3 in 1 oil or WD-40. Wipe off excess. Lightly brush heating elements and reassemble. I hope this works for you. Thanks We had our first pelonis disc heater for twenty years.
Nov 18, 2010 | Pelonis HC-461 Ceramic Heater
Why is my kenmore elite (top loader) oasis washer HE is displaying a code of HC
The water inlet hoses are probably removed and reconnected in reverse, and then trigger the HC error code to flash indicating the hot and cold water inlet hoses are reversed. Reconnect the water inlet hoses properly and start a cycle then let us know what happens next.
Apr 18, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Canon PC785 fails and turns off immediately after turning on. Displays code ''EO'' just befor shutting off
E0 error means Fixing Unit failure. It could be a dirty Thermistor. It could be an open Thermal Fuse. It could be an open Heater Lamp. Anyways, once the culprit has been isolated and corrected, the copier will need to be reset via "jumpering" certain points on DC Controller.
Jun 22, 2009 | Canon Office Equipment & Supplies
F2e0 error on stove
Turn off the breaker and wait for 5 minutes. the follow this 3 steps:
--> After turn the breaker back on, go to the range and press "OFF", "OFF", "START", then click on the "clock set", there is a message on the display saying that do you want to delete the error, at this time press on the "START" again. And wait for a while until the everything on the screen disappear except the clock time. Hope this will fix yours. It fixed mine.
Dec 28, 2008 | KitchenAid KESC307 Electric Kitchen Range
Canon Copier NP 1020 - error code E0
pretty much the same, the codes are good for several models not just one.
you need to find the other numbers to know exactly which code it is, press the start or stop key to see it display the other #'s.
fuser is on the left side if you replace the parts might as well replace the claws and oil roller.
"E000" Heater lamp, Thermistor, DC controller "E001" Heater lamp, DC power supply / AC Driver circuit board, Thermistor, DC controller. "E010" Main motor clock sensor, DC controller PCB, Main motor, DC power supply / AC Driver circuit board
Sep 16, 2008 | Canon Office Equipment & Supplies
Beko AP930 with Error code E0 in LHS of display .... what does this mean ? .... nothing in manual
Error codes are printed on underside of plastic cover on top of fridge. Warning electrical components inside! Error code E0 is the FREEZER door not being recognised as closed, switches are normally ok may be problem with printed circuit board. Freezer will work as normal but engineer should be called.
May 08, 2008 | Refrigerators
Pelonis HC-461 Ceramic Heater Logo
81 people viewed this question
Top Pelonis Heating & Cooling Experts
Paul Carew
Mack Baxter
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Pelonis Heating and Cooling Expert? Answer questions, earn points and help others
