Question about Pioneer DEH-P2000 CD Player
How to install?What wires hook up to where?
I've had this unit setting for a long time because I tried hooking it up in the house using a spare battery I had.Thought I knew how to hook up and when only the face lit up I thought it must have gotten damaged when it was pulled out of a friends car.He swore it wasn't.AndI know it worked just the day prior of removing. Well I just stowed it away and now I'm thinking I just didn't test it right.I know the speaker wire hook ups.It's the power wires I need info on.Red,Yellow,Black.Please any help would be great. tx
  • kenny s Oct 10, 2007
    Thats what I did.I'll try 1 more time,but it sounds like it's fried. Ty
    Brigadier General:
  • 6,966 Answers
Hi, Re the power wires - black is ground (or - of battery), red goes to the + terminal of the battery and the yellow would go to the Acc in the ignition switch of a car. If you are hooking it up on a spare "battery", you have to twist together the red and yellow and connect both to the + terminal. Good luck and kind regards.
Posted on Oct 10, 2007
How do you hook up the thermostat to a Central Electric feh-017ha-04 furnace? Also, where do the A/C wires hook up to the furnace?
The standard color code for the HVAC is as follows....
Red=Hot or 24v
White=Heat
Green=Fan
Yellow=A/C
White 1=secondary heat.
Blue=Spare
Orange=Heat Pump
C=Common
The thermostat has the terminals marked R,Rh,W,G,Y.
The furnace should have a terminal strip with similar markings.
If you only have 1 control transformer this will be easy.
Hook the wires up using the colors I have listed. If you don't have the same color wires go with whats close to them....such as use Orange for Red etc. It really doesn't matter as long as they are landed on the same terminals on the thermostat and furnace. Two wires running to A.C unit outside put one on Y the other on C. If you need any more help let me know!
Jun 02, 2014 | Intertherm Heating & Cooling
Toyota Corolla 1997 I've installed kickers in the rear (KS series to match the front)... had those going for a couple of weeks with no problems. Yesterday i went to install the KS400 series in the...
take one of the front speakers out and pull out the head unit and unplug a set of audio wires(front right, front left ect.) and hook it up directly from the radio to the speaker there for bypassing all the cars wires. If it works then there's a problem with the car's wiring(maybe an inline amp). If it doesn't work, then try a known good speaker from somewhere else(home stereo speaker for example) and connect it to the radio, if the speaker works, your radio is fine and there may be a problem with the speakers. If it doesn't work then you have a problem with the head unit.
Jul 22, 2011 | Kicker KS400 Coaxial Car Speaker
Am installing a ceiling fan and do not have the installation instructions. The fan has a black wire (labeled Motor), a white wire (labeled Neutral) and a blue wire (labeled Light). What is the proper...
When dealing with older houses, you run into this a lot, but the somewhat newer houses will actually have the 3 wires to hook up the ceiling fans. You can still use your 2 wires, but you will have to double up the motor and light wires. Wire nut the Black and Blue wires together with your Black wire from the house, and the White wires will be tied together for your neutrals. You should also have a green ground wire also, be sure to hook that to a ground in the house too. Hope this helps!
Aug 04, 2010 | Heating & Cooling
Thermostat wires running from house to outside Kenmore AC unit were chewed by dog. Got replacement wire. Took panel off. There were three encased wires running into AC unit that were chewed. Only see...
If you have a central air conditioner, or a split system, where the indoor unit is attached to the furnace and a outdoor unit is located outside of the home. 2 copper lines will be connected to it, a larger and a smaller one. If it is a air conditioner and not a heat pump, the A/C usually uses 2 wires, that are connected. Allot of times a installer will use a 3 wire thermostat wire, to run to the outdoor unit, if this is the case, the third wire will be folded back out of the way.
The color of the wire is usually picked by the installer, I myself usually use white and red and fold the green out of the way. If you only had 2 wires hooked to it to start with, it really would not make a differace which one you hook up to either one of the yellow wires.
All you are doing it having one wire coming in and one wire leaving,,,, just creating a complete circuit, just don't connect the two yellow wires together.
Example: If you have 2 yellow wires on the A/C unit and 2 wires coming from the house "example a red and a white" hook the white to "One yellow wire" and the red wire to "the other yellow wire".
You are just creating a complete circuit, when the thermostat calls for cooling, it creates a magnetic pull and closes the contact points, in the air conditioner, outside, this allows the 220 volt to flow to the compressor,,, and ahhhh cooling!
I hope I have not confused you, I am just starting to help on this site and still trying to make things understandable.
Wish you the best,
Paul Gibson
Mar 29, 2010 | Heating & Cooling
I have a 1988 ford t bird i bought the wiring kit and installed the after-market stereo and everything works expect the sound. and i ve tried other stereos and double checked the wiring and still no audio.
Check under the passenger's seat for a factory amp. If the blue wire on the aftermarket head unit (accessory/antenna) supply isn't hooked into the power line for the factory amp. You'll get nada. It's usually a bump in the carpet if it's not visible. Look for a spare wire in the dash that originally went to it.
Mar 15, 2010 | Car Audio & Video
No heat after installing honeywell thermostat H8110U
hook up the blue wire in the furnace cabinet where the blower section and the other thermostat wires are connected to the furnace. the thermostat you have uses a common wire from the thermostat to the furnace and this needs to be hooked up in the furnace otherwise you will have the problem you are having.
Dec 07, 2009 | Honeywell Electronic Programmable...
We had a clarion reciever with tape deck in our boat and found another clarion reciever with two new speakers and two good 1996 speakers which had not weathered. The instalation was difficult but the...
As long as you have connected the ground(black) try adding one wire at a time to the live(red). If possible try connection each wire one at a time to the power line and then both together. If nothing has blown(fuses) and the unit starts working then you can try by trial & error method the remaining wires. You should be able to figure out which wire is required and if there are any extra wires like cellular phone(mute) and then decide whether to connect them or keep them open.....sodeep
Jul 27, 2009 | Clarion DB245 CD Player
I am trying to problem solve for dishwasher that is properly installed and is not working or even responding to being hooked up electrically. My husband tried to wire it and unfortunately wired it...
no matter what brand it is the unit must have been hooked up power to ground to make a spark when turned on.
they dont have a fuse to protect them, but what may have happend is you could have shorted out a door switch.
be sure that you hae the wiring correct now and that your house fuse or breaker is on.
the wiring is very easy to hook up as black to black, white to white, and bare wire to ground.
i dont see how your husband could have done that wrong, but anything is possible.
recheck the power to the unit and just hope thats all thats wrong.
if you are sure power is good, then something in the unit has shorted out.
Jan 31, 2009 | Dishwashers
Heat pump wiring
yes i can , you need to hookup the r and the o together so that the reversing vvalvce is allways energized . so with that im mind send r,y,c,o to theout side unit. at the ahu you'll hook up the 5 wires for the furnace, r g w1 w2 com and at the thermostat r,w1,w2,y,g,com,o then you will be set (the o get hooked up to o and goes straight out side.
Dec 03, 2008 | York Yankees Bedding MLB Comforter
Pioneer DEH-P2000 CD Player Logo
106 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
