Question about Equity Time USA Audio Players & Recorders
Clock blinking 30007 - Equity Time USA Audio Players & Recorders
How do I get the display to stop blinking?
The blinking display indicates the clock has to be reset. If you follow the reset procedure and the display continues to blink, the clock is defective and should be replaced.
Feb 14, 2016 | Audio Players & Recorders
Synergy global supply model 9105 how to set
http://www.synergythesource.com/doc/alarm-clock-setup-910500.pdf
Quick Setup
Model 9105
Alarm Clock Radio
1) Plug clock in before making any adjustments.
2) If using on East Coast- Do nothing! Time and date are set to EST- Daylight Savings time is 'On". Clock is ready to use.
3) If using in time zones other than EST. Hold the clock with LCD facing you. Lean clock back and find small button on bottom right marked P-M-C-E. Hold for 2+ sec. LCD will blink the time zone. Press button again until LCD blinks the correct time zone, CST, MNT, PACIFIC.
4) Daylight Savings time- Default is always on. If you are in a zone that does not recognize daylight savings time. Hold the clock facing you, lean clock back and on bottom left is a small button marked D. Hold 2+ seconds and the LCD will blink ON. Press again and LCD will blink OFF. Daylight savings time is now OFF.
5) If power goes out, clock will retain time and alarm will sound if in the ON position.
6) Replace batteries once every year...!
7) If clock looses time or date:
a. Hold Volume +, and Tuner + at same time for 3 seconds
b. Clock face will blink year
c. Turn outer ring of alarm to set Year
d. Press Tuner + once, turn outer ring to set Month
e. Press Tuner + once, set Day
f. Press Tuner +, set Hour
g. Press Tuner +, set Min.
h. Press Tuner + to save all settings.
You must go through all set points to have them remain in memory. (have to run thru all a - h, can't set just Day or Hour/Min, etc. without starting with Year)
Any questions please call:
Synergy Global Supply
804 435-7520
8:00am-4:00pm EST
Oct 23, 2012 | Audio Players & Recorders
Reset radio but can't reset clock
just press the clock button for a few seconds then press it again for few seconds and it should stop blinking once it stops blinking press the clock button down again and hold then once it starts blinking release the clock button and adjust the hours and minutes
Jun 13, 2009 | 2007 Honda Accord Sedan
Clock set instructions for Sanyo stereo awm2800U
you need the remote to change the clock press timer am 1200 blinks press timer again for at least 2 seconds the hour blinks press tuning/time set plus or minus press clock adjust the minute will blink press time set to adjust minutes then clock adjust there you go...
Mar 10, 2009 | Sanyo AWM-2800 CD Shelf System
Ultronic lcd clock with a stylus tucked in back of clock
This thing set under my bed, lifeless til I was looking for something else and decided it was time to get this clock working!
(Use the stylus pen for best results) After putting in two fresh batteries (or hit the reset button if your batteries are fresh). This will reset the clock and the 'clock' icon in the upper lefthand corner will be blinking. Now press and hold the display area where the hour of the day is displayed. The entire time will start blinking. Now start tapping on the blinking hours to increment the clock slowly to the correct hours (it will cycle all the way thru military time and regular time, so choose what you desire). Press and hold with the stylus to increment quickly. Do the same with the minutes, that are blinking too. When time is correct, tap the 'clock' icon once. The 'clock' icon will still blink, which I believe is correct operation.
To set the date, tap on 3rd icon down from the top left (it looks like a little calendar). This will put you into the date section of the clock (if you do nothing, it will cycle back to the clock, after ten seconds, as a default). Before it cycles back to the clock, press and hold with the stylus pen right below the word 'DATE', until the the entire displayed date starts blinking. Tap the first two digits of the year to go down in years and tap the right two numbers of the year to go up in years. Tap on the month number to increment; do the same with the date number. When all date entries are correct, either tap the 'calendar' icon, or let the clock sit for ten seconds: it will cycle back to the clock.
I guess you can set the alarm in a similar method.
Hopes this helps!
ExitKC
Nov 03, 2008 | RIM BlackBerry Pearl 8100
Setting the clock
1. Press SOURCE and hold until the unit turns off.
2. Use the MULTI-CONTROL to select clock.
3. Push MULTI-CONTROL left or right to select the segment of the clock display you wish to set. As you select a segment of the clock display the segment selected will start blinking. If you select the hours, the hours will blink, select the minutes and the minutes will blink and so on.
4.Push MULTI-CONTROL up or down to set the clock.
Jun 19, 2008 | Pioneer DEH-P980BT CD Player
RCA,RP9328A,Audio System
I did the following to set the clock:
1. Press the Timer/Clock button until "CLOCK" shows, blinking, on the display.
2. Press Set/Demo. The hour indicator on the clock should start blinking.
3. Use the "Track/Tuner Forward" and "Track/Tune Backward" keys to
set the hour.
4. Press Set/Demo. The minute indicator on the clock should start blinking.
5. Use the "Track/Tuner Forward" and "Track/Tune Backward" keys to
set the minute.
6. Press Set/Demo twice. (Pressing once moves to the timer set mode.)
Feb 09, 2008 | Audio Players & Recorders
The Clock
while a cd is playing and the clock is displaying press the CLK/ DISP button untill the time starts blinking and while its blinking press the number 5 button to set the hour and 6 button to set the minutes these 2 buttons are at the right bottom corner
Dec 03, 2007 | Alpine CDM-7833
Atomic clock
There is a setting on the clock to turn on "DST"- daylight savings time feature. You have to push the set button on the back of the clock repeatedly until you see "DST" blinking. You should also see "OFF" blinking at that point indicating that the feature if turned off. If you now push "+" button on the back of the clock once it should show "ON" blinking instead of "OFF". Hope this helps.
FixerUpper
Nov 04, 2007 | SkyScan 86709 Atomic Wall Clock
Clock
Press POWER to Turn ON the unit.
Press CD/Door OPEN.
With the Doors Open, on the Inside Right is a "Clock Set" Button... Press it once.
With the Hour blinking, press the "CD-Tuner-Skip" Up or Down Buttons to set hour.
Press the "Clock Set" Button again to make the minute display blink.
Adjust the minutes the same way.
Once the hour and minutes are both set, be sure to press the "Clock Set" button
one more time. Now the Hour and Minute display should no longer be blinking and
you should be good to go. (I just figured it out for myself.) Hope this helped!
Jan 04, 2007 | Fisher SLIM-2000 CD Shelf System
Top Equity Time USA Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Equity Time USA Audio Player and Recorder Expert? Answer questions, earn points and help others
