I have a Daewoo front loading washer model DWD WD32Ws. In the middle of a wash. Before it drained all, it lost all power. Now it wont do anything. Why is this?
2 Suggested Answers
  • 3 Answers
SOURCE: E8 code when washer fills on front loader daewoo
E3 CODE WHAT MEANS
Posted on Apr 09, 2010
My Daewoo does not want to spin, any suggestions?
first does all of the water pump out when wash cycle is done? if not then check your drain lines and see if pump is coming on. if it is not then it wont let the washer spin,
Jun 03, 2014 | Daewoo Washing Machines
How to clear impellor
Top unscrews, impellor lifts off. Any tangled items can be pulled clear
May 19, 2012 | Daewoo DWD-WD3011WW 4.0 cu. ft. Capacity...
I have a daewoo front load washing machine dwd-wd32ws. the water does not pump out after the wash cycle
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jun 05, 2011 | Washing Machines
Water wont pump out
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Dec 30, 2010 | Daewoo DW500M Top Load Washer
OE code on front load Daewoo washing machine
According to your owners manual you only have two choices...
Your lint screen is blocked or you have a problem with your drain motor (a separate device ).
Old age & experience will add a third... Assume lint did get past all those sophisticated "filters" and is presently residing inside the impeller housing... In the olden days when those housings came apart (aluminum/aluminium) I took out an entire sock and enough lint to make another... My guess today is you buy another plastic pump.
Sorry I could not get part number or price here in the USA...
Not even cleverly saying "spares" (but I did try).
Hope this was helpful.
Daewoo Washer Drain Pump Spares Yahoo Video Search Results
Yahoo Image Search Results Page
Amazon com Daewoo Dwd m301wp Mini Drum Washing Machine English Menu...
http://www.daewooelecusa.com/customer-service/service-centers
Jan 06, 2010 | Daewoo DW500M Top Load Washer
My washing machine (dwd-wd32ws) only uses hot water to wash!
hi,
try and switch your hot and cold water hoses around the other way. it should start the cycle with hot and rinse cold.. If it still does it you may have to have it serviced..
jm
Nov 27, 2009 | Daewoo Washing Machines
Daewoo DWD-F1011 PFE error code
I hd zs problem before,no problems in z water outlet,z pump
Nov 16, 2009 | Daewoo Washing Machines
Dwd-wd32ws will not drain
Some of the washing machine models have a small pump in the bottom that clogs with lint and stuff. When you disconnect the hose from the pump get ready for alot of water to come out. prevent this by kinking the hose somehow. This was a similar problem GE had with the washer we used to have in apartments. Good Luck. When you find out how to acess the pump the rest should be easy.
Feb 09, 2009 | Daewoo DW500M Top Load Washer
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
