Miele w3740 Washing machine rinse and spin problems
  • 213 Answers
SOURCE: whirlpool washing machine won't spin after rinse cycle
there is a coupling between the motor and transmission that has cracked. with the crack in the coupling the transmission cant spin as fast as the motor causeing the loud noise. replace coupling to solve problem
Posted on Nov 21, 2007
  • 16 Answers
SOURCE: Miele Premier novo washing machine
Flashing rinse light is a drive fault. No motor action. If it's an earlier model it would be the motor brushes. Later model will be the electronic which controls the motor.
Posted on Feb 08, 2008
SOURCE: rinse light flashing on miele
Check the motor for worn brushes and or noisy bearings while it is removed for service. Any auto mechanic should have experience replacing brushes and bearings. Much cheaper than ordering a new motor. New brushes and bearings should cost around $30. The shop time should not exceed one hour. Miele charges about $50 for brushes if you can not find a local supplier. The W1930 motor that I rebuilt used a 6202Z and a 6201Z bearing set.
Posted on Mar 14, 2009
  • 686 Answers
SOURCE: Washing Machine is not draining in rinse cycle to go to spin cycl
you both seem to have bad lid switches. A bad lid switch will prevent draining and spinning.
Posted on Apr 04, 2009
Mark Harmer
  • 8 Answers
SOURCE: Washing machine problem
Same - there's a company in Denmark which does brushes - you have to hunt them down on the web. The brushes come in a brass slider and spring, and sit in a rubber cage. Make sure you don't throw away any bits of the old brushes as you might need to reuse the old rubber cage.
Another solution (if you have the rubber cage) is to move the brushes along a bit and bend the metal tabs on the brass slider. That will give you a contact again - the machine will work for a few weeks or so, which gives you time to order the new brushes.
Posted on Sep 21, 2009
Miele Novotronic w310 washing machine - won't spin and flash 'rinse' on the display?
Did you try to set the temperature to the minimum?
Maybe the heating element is faulty....
Nov 30, 2015 | Miele Washing Machines
The rinse light on my miele novotronic w/machine falshes and it wont spin
This means there's a problem with the motor control. Caused by either the motor itself (brushes) or the electronic. See Miele goedkoop repareren cheap repair preiswerte Reparature
Mar 04, 2015 | Miele Washing Machines
After washing and rinsing it doesn't spin the water out.
Check the drain lines for clogs. If that checks out ok, then you probably have a bad drain pump.
May 11, 2012 | Miele Washing Machines
Hi, i have a miele novotronic w 916 and it's not spinning
I mean this is not a filter error and i think the power main board inside on front bottom EL110 has an defekt and must change.
Or you can post the problem on my board www.avpc.de with photos for solving together and find another cheap used power board for it ...
Aug 21, 2009 | Miele Novotronic Premier 500 Front Load...
I have opened the drain filter on my miele W3740, but the inside doesn't look like the picture in the handbook. there is supposed to be a bit that goes round. is there another piece to take out before i...
If you are not the original owner - perhaps it was removed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 17, 2009 | Washing Machines
Miele transit rods stuck
My husband was able to pull it out .
Feb 27, 2008 | Miele Washing Machines
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
