Question about Gemini Sound Products Music
Speaker fuse - Gemini Sound Products Music
Do i have the right fuse
This speaker at full power draws average 1.3A at 230V and 2.5A at 120V. Mackie's recommended fuses are in line with this so your fuse is actually too high a rating. It is possible you are using cheap fast blow fuses or are over-driving the speaker (which should cause the fuse to blow) These speakers are only capable of 118db sustained (@1M) so cannot be expected to cope with anything but small venues or gentle music.
Dec 07, 2012 | Mackie Srm 350
Have a hartke lh1000 head . played about 5 total hours then blew the fuse. is this something i shoud be worried about?
If the fuse is correct ( check manual) it shouldn't blow under normal operation. Once in while a fuse will break internally and thus blow the fuse. look close at the blown fuse If it is a "violent" blow (totally black inside) then you have an overload condition. I would use an ohm meter to check the connection to the speakers. Usually it should be between 8 ohms and 4 ohms if the number is lower than 4 ohms your speakers or wiring are putting to much of a load on the amp. If the fuse was not a "violent" blown fuse then replace with a new fuse of the exact proper value. many amps use an MDL fuse that is a slow blow fuse and has much different in circuit function than a ACG fuse so use only the exact proper furse that the manufacture recomends. If the load (speaker and wiring) is correct and the fuse is correct and still blows then you have a component problem and the amp will need repair
Jan 19, 2012 | Hartke Lh1000 Bass Amp Head 1100 Watts...
Peavey Pr-15 fuse blown, speaker not working. What is the fuse rating
Actually its pretty funny thing with those speakers is the "fuse" is Actually called a Lamp in this case. These are what they call a " Red Dot Fuse ". in all the years i've been doing this i've never thought to look up the value haha. Just have to know there are Red Dot lamps and Blue dots and No Dot. If you examine the LAMP you should see somewhere close to the ends ON THE GLASS a color dot of some kind. almost like someone painted it on there. Red Dot Lamp. any parts distributer for people like Harbinger, Peavey, and B52 will KNOW what your talking about
Aug 21, 2011 | Peavey PR15 400w PA Speakers
Could a bad cable connection make a fuse blow in my fender passport 250, or cuase any problemmwith ouput from my speakers...?
A shorted speaker cable could cause this... however, what you do is to replace the fuse BUT wire a 150 Watt lamp in series with the power input... This acts as a resetable fuse for testing. If the lamp stays lit, you still have a failure.
Aug 12, 2011 | Fender Pd250 Passport Deluxe 250watt...
Gemini gvx 15, were is the fuse located, we can't find in nor inside or outside ?
It may NOT have a fuse. If too much power was sent or an amplifier drove DC to the speaker, the voice coil may have fried. The specs do NOT brag aboput protection, so it is likely either the speaker is blown or the internal wiring is broken. Open the unit and use an ophmmeter to tesst the speakers.
May 30, 2011 | Gemini Sound Products Gemini GVX-15 15"...
Hi ther the fuse has blown on the speaker out circet on my new amp any ideas why this would happen?
The fuse blew because of excess current. The cause of the excess current is either excess volume, a short in the speaker, OR the amp has failed and is shorted to one of the power rails internally and is driving DC current out.
Replace the fuse and use a meter to check the output voltage with NO speaker connected. It should be under 1/2 volt period. If it is, then check the resistance of the speaker. The DC resistance should be a little less than the rated impedance. Otherwise if the amp is kicking out a higher voltage or blows the fuse again, have the amp repaired.
Mar 28, 2011 | Ashdown Klystron 500w Bass Amp Head
Left speaker won't turn on, even if i plug the power lead from the right one in. What can i do?
This is a problem that may likely require the skills of an experienced repair tech. If you are not comfortable working on electronic devices, find someone who can do it for you. UNPLUG YOUR SPEAKER BEFORE INSPECTING A PROBLEM.
The first place I would look is the FUSE. Each of the speakers contains a power amplifier and each has a fuse that will blow to protect the power transformer, circuit and speakers. If you are getting NO POWER at all to the speaker, check the fuse first. It is located on the AC plug circuit board.
You can download the PDF for the HS series here. It includes all of the circuit diagrams, parts lists and close-up photos of the parts.
If the fuse is not the problem, the speaker's power amp has suffered more sever damage and you would certainly need an experienced technician to diagnose the problem.
Feb 27, 2011 | Yamaha HS50M Active Studio Monitor (Pair)
Fuse blowing on start up on Behringer PMH 518M
Try running the amp with no speaker cables connected. If it doesn't blow the fuse you know it's either your Speakon cables or the speakers themselves that are to blame (it's usually the cables)
If it still blows then there is a more serious problem with the power section.
Jan 19, 2009 | Behringer Pmp3000 16 Channel Audio Mixer
Music Logo
Top Gemini Sound Products Music Experts
Vito Vacirca Jr.
Colin Stickland
Colin Stickland
D. E. Hev
Are you a Gemini Sound Products Music Expert? Answer questions, earn points and help others
