Question about Acer Aspire 5630 Notebook
Part of my monitor display on the right side is not coming
On the right side there is a verticle line 2 inches the LCD comes almost as dead. But can view the whole window screen. I connecte to another Monitor and saw that there everything comes ok. y'day as I gave a gentle shake on the monitor it worked too. But today it again got back to the same problem. I have another problem . When i click on Empower button, it is saying that it is missing empower.exe button. What should i do for that.
  • 117 Answers
Confirm this is confirmed lcd panel problem
change your panel
Posted on Nov 07, 2007
SOURCE:
Samsung screen is not calibrated properly. There is a line on the right side of the screen that I can't get rid of.
Unfortunately the line didn't show up in the video.
1) New LCD screen?
Should have an Installation CD Disk that comes with it. Use it if so.
Has the Drivers on it.
Driver: Small piece of software that allows the Operating System to communicate with a device.
Don't know which version of the Windows O/S you have.
The device in this case is the LCD monitor.
2) What is the NATIVE screen resolution for the LCD monitor.
Look up the specs on the monitor using it's Model Number on back.
For example I installed an HP 2009M 20-inch widescreen monitor, along with the 26-inch RCA ENV HDTV I use for a monitor.
I had to use the drivers from the disk, but could still not set the native resolution in Display Properties.
There is an alternate resolution to the native one that can be used.
The drivers from the disk made it so.
The 20 inch widescreen is 1600 x 900 (Pixels)
The 26 inch HDTV is set at 1360 x 768 (Pixels)
Right-click on an empty area of your desktop screen.
Left-click on Properties at the bottom of the list.
In the Display Properties window click on the Settings tab.
What is the Screen resolution setting? What is it supposed to be?
The Slider on the line is clicked on with the left mouse button, left mouse button held down; then the Slider is slid to the left to decrease screen resolution, or to the right to increase with the mouse.
Color quality should be set to High (32-bit)
1) Installing software (Drivers) from the Installation disk, (Or from the monitor manufacturers support website);
And,
2) Setting the screen resolution;
doesn't help, replace the monitor cable with a known to be good one.
Still no? Your LCD monitor is going out.
Regards,
joecoolvette
Dec 07, 2012 | Computers & Internet
Hello sir my samsung lcd monitor model no 740N . in dis monitor right side display two verticle lines green n light pink but hoe to i resolved dis problem please give me suggestion
You cant resolve it tiny resistors in the screen have failed and that is why the lines have appeared, it is a case of live with it or buy a new monitor
Feb 24, 2011 | Samsung SyncMaster 740N 17" LCD Monitor
I have a blue verticle line top to bottom on my dell inspiron1300 laptop 3 inches from right side.Just appeared!Why?
hi murdockthefi
apparently these are dead pixel lines. it appeared as the pixels on the LCD screen of the laptop has already died down or is not anymore working as it should. it would only be resolved with replacing the LCD panel itself.
hope this answers your question. thanks
janc30
Feb 11, 2011 | Computers & Internet
I have a Dell computer with a flat screen now all of a sudden there are fine pink verticle lines along the right side of the screen. There is also a group of fine pink verticle lines about 1.5 inches wide...
Try the following steps:
  1. On the monitor, press Menu, and select Factory Reset.
  2. If the monitor has more than one type of connection available such as VGA, DVI, or HDMI, try a different type of connection.
  3. Connect the monitor to another computer. If the line appears when the monitor is connected to the second computer, the monitor might be damaged or defective.Otherwise, the video card and driver is causing the problem from the computer.let me know if this resolves ur issue.. if not then we need some other steps.. regards,guru
May 05, 2010 | Dell UltraSharp E153FPb 15" LCD Flat Panel...
What can cause a single red line to appear on my laptop LCD screen? It's a small/fine red line appear horizontally (left to right) It's NOT radio interference,back light,broken ribbon cable,or connector...
Thats a generic problem with LCD screens. Its more common in Mobile screens. Sorry, no there is no fix to it other than replacing the LCD itself. Just pray that it shall not grow because as and when the compressed gas from within the LCD will leak the line will be becoming broader and broader. It is caused by damage to the LCD corner Just a hit on side of LCD and a hairline crack for giving way to the encapsulated gas.
Jul 28, 2009 | Computers & Internet
One big black verticle line 2 inches from left side...Help
Honestly you have a big problem because the driver IC & Tape Carrier Package inside controller board at vertical area are damage or itself defective could cause you have 2 inches line appear in your display. The best solutions for this replace lcd panel to fix vertical line.
Mar 28, 2009 | Mitsubishi LT-46144 46 in. LCD HDTV
Mitsubishi LT46-144 LCD Verticle Line Problem
Go to Mitsubishi support page, look at warranties (scroll down) and see if your model is under the extended warranty section. Then if so have a tech repair person come look at the picture and order the parts while you keep the tv. Parts and labor are covered.
Mar 14, 2009 | Mitsubishi LT-46144 46 in. LCD HDTV
Dell Lattitude C840 Display NO WORK
If you are getting lines on an external display, then the video card needs to be reseated or it is bad. Since you just had it worked on, I'd take it back and tell them you aren't satisfied (most places will guarantee their work 30 days).
Mar 01, 2009 | Dell Latitude C840 Notebook
Dead or ?
I need the power cord. Would you sell that to me?
Aug 15, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Verticle blue lines, left side
Your Display cable (inside your monitor) needs to be replaced.
I would look on ebay to try and find the part and then take it to a local tech to replace it for you as I would not recommend anyone take apart a monitor (LCD OR CRT) if you had never done so before.
OR, Buy a new one.
Mar 07, 2008 | Dell UltraSharp 2001FP 20.1" LCD Monitor
Acer Aspire 5630 Notebook Logo
93 people viewed this question
Ekse
Alun Cox
