Question about U.S. Robotics Modem: U.S.Robotics 56K V.92 Performance Pro Modem (FM3CP5610B)
Help Don't know how to delete last number I dialed
Hi I Don't know how to delete last number I dialed on my GE phone. Can you help?
0 characters
1 Points
Intex usb
Hi i am using aircel 3g sim with Intex data card from last 6 months, But when i try to connect today, m getting error that shows "Dial Failed, Do you want to retry". Please somebody help me to solve this issue,, I tried uninstalling the datacard software and installing it but that does not work for me...
May 06, 2013 | Modems
No security password
Hi I just joined 5 minutes ago....Maybe I can help you.I dont know what phone you have but here goes.....:)
1, Hold the DEL button till you are asked to enter first number.2, Use "Skip" to scroll through numbers, DEL to select.
3, Continue till all numbers are entered.4, Phone will tell you when its done!
Apr 02, 2013 | RCA Digital Cable Modem (DCM245R)
I'm using windows 7 with a wireless rca by thompson dcw725 router. my desktop is wired into it, but i got a laptop that connects wireless, but has no internet access, says limited connectivity. Any ideas...
First of all, you need to check if the laptop is correctly connectedto the router.
try the following steps to see if you are effectively connected to the router :
1. Open the command prompt on your desktop computer (Start -> All Programs -> Accessories -> Command prompt OR Windows Key+R -> type cmd).
2. Type ipconfig /all and then note down the value given for Default Gateway
3. Repeat the first two steps on the laptop and compare the values of Default Gateway.
If the values are different, then it means the laptop is not correctly connected to the router.
You will have to delete the Wireless network configuration (In the Network and Sharing Center, you will find it in "Manage Wireless Networks").Then start the wizard for connecting to a wireless network. Be sure that you enter the network security key correctly.
If the default gateway values are correct, check the firewall/antivirus settings on your laptop. If you cannot or don't know where to look, deactivate them completely and try again.
You may also need to check the parental control settings and your web browser settings (notably if it is in offline mode).
Last but not least, on the laptop, delete all broadband connections and/or dial-up connections that are present (in the Network and Sharing Center, go to "Change adapter settings" to find any broadband or dial-up connections).
May 05, 2011 | RCA Thomson Digital Cable Modem (DCM305R)
How do you change number of rings for the phone and auto attendant
You need to go into phone system admin programming
feature 00
left intercom
left intercom
Then the program for the ring delay on the Lines:
VMS Hunt Delay
Dial #506
Release 2.0 and earlier:
Dial 1=Immediate
Release 3.0 and later:
Dial 1=Day
Dial line number
Dial 0-6
The delay for extensions is:
VMS Cover Rings
Dial #321
Dial one digit (1-9) for the # of rings
before the call is sent to the voice messaging
3 is default
The phones worked last night, this morning nothing
If the phone rings but no dial tone, possible phone unit is faulty. I suggest to try a different phone unit to verify if it's faulty. If the other phone isn't working too, then report the issue to your phone provider.
Jun 10, 2009 | Linksys SPA-2102 NA Analog VoIP Adapter...
Clearwire VOIP ph adapter + Can only connect 1 phone downstairs
if you need more call me at 804-372-RROD
May 03, 2009 | Linksys SPA-2102 NA Analog VoIP Adapter...
I deleted my mxit password and i forgot them
Hello please how can i get beack my password
Mar 20, 2009 | Arris V.3600 Modem
No Dial Tone...
first check your phone lines, if they're good call the phone company, you should have a dial tone. netzero only offers dialup so the internet you are using is your neihbors....they didn't lock their router. good luck
Aug 11, 2008 | Modems
Zoom phone adapter problems
For zoom adapter, calling with handset
Dial 011+1+(zip and number) followed by *
ex. 01112223333*
This is for u.s. calls, just change the country code to the one you need, if not u.s. call.
Dec 09, 2007 | SKYPE / VOIP to PSTN (RJ11) Phone USB...
No longer dialing Lond Distance
If your modem can fax a local number or dial-up an Internet Service Provider in your Local Area then your Internal Modem is just fine. Check if the configuration of your Modem to access outside long-distance number. Go to your Control Panel-Open Phone & Modem Options-Dialing Rules (Tab)- then click on EDIT Button. You can enter the number needed to have a long distance dialing. If you don't know the number needed for long-distance dialing then ask your Local Phone Service Provider.
Apr 04, 2007 | Smartlink (I56KSPF00) Modem
U.S. Robotics Modem: U.S.Robotics 56K V.92 Performance Pro Modem (FM3CP5610B) Logo
41 people viewed this question
Top U.S. Robotics Modems Experts
Jeremy Murray
Jeremy Murray
Sudeep Chatterjee
Sudeep Chatterjee
Are you an U.S. Robotics Modem Expert? Answer questions, earn points and help others
