Question about Walgreens Humidifiers
I have a Dual Ultrasonic Humidifier (Walgreens). I have lost the caps for the two water tanks. How can I get replacement caps fast?
This may be the serial number from the box (462969-8)
SOURCE: Humidifier mist won't come out of tube
sounds like the small fan that is located in the base isn`t pushing the mist out. unplug it then take all the screws out of the base. there are screws under the black foam stands too. be careful not to touch anything that looks like live wires while you look inside then look inside while it is pluged in. it should turn. check for something blocking it like lint or dirt..you may be able to clean around the shaft with w d 40
Posted on May 30, 2008
  • 114 Answers
SOURCE: no mist, but i can see a water droplet fountain on the surface
if it's a cool mist unit it will not produce any mist. now if it's a warm mist unit it should. that's normal. it is possible to replace the transducer if it is damage but you are going to have some leakage from it. but the only way to get the transducer mainly is from the manufacturer
Posted on Aug 21, 2009
  • 6 Answers
SOURCE: Water tank broken V745A Vicks Humidifier
I just ordered my replacement tank from kaz.com. Search using the model number and find the tank. I got it for $12....
Posted on Oct 28, 2009
BarrettDenCo
  • 1772 Answers
SOURCE: I have the walgreens ultrasonic
just warm water and bleach, will have to do it a couple of times
Posted on Dec 19, 2010
SOURCE: lost the valve cap for the water tank
You can buy a replace tank cap online from Crane. As of the time of this writing, this link will take you there: http://shop.crane-usa.com/products/productdetail/part_number=EE-0865-1cap/1779.0.1.1
The cap is about $5, plus $5 shipping in the US.
Posted on Feb 07, 2011
How do I fill a Walgreens ultrasonic humidifier model NO: 2065?
Lift the clear tank straight up off the base. Turn it upside down and turn the filler cap clockwise about 3/4 of an inch. It should lift out. Fill and replace the cap and put the tank back on the body of the humidifier. Make sure that the seal to the filler cap is seated properly.
Mar 14, 2017 | Walgreens Humidifiers
Walgreens Dual tank humidifier 2035 stopped working
I've never seen this model, but it would suggest that the unit is unable to function due to either an electrical failure or needs a serious deep cleaning (esp.the part that interacts with the water to form mist.) I would completely empty the unit and clean it, then partly fill the reservoir with 50/50 mix of white vinegar and water and let it sit for 24 hours (possibly longer) to remove any deposits. (Doesn't take much build up to kill the ultrasonic process). Other than that, try calling the manufacturer and see what they will do for you. (Think it's Sunbeam).
Dec 21, 2015 | Walgreens Dual Tank Ultra Sonic...
How do I clean the dual tank ultrasonic humidifier membrane
Air Innovations Clean Mist Ultrasonic Dual Tank Humidifier ...
www.qvc.com/Air-Innovations-Clean-Mist-Ultrasonic-Dual-Tank-H...
QVCAir Innovations Clean Mist Ultrasonic Dual Tank Humidifier. Air Innovations ..... I did not realize that you needed a special filter if you have hard water. If you do ...
Sharper Image Dual Tank Warm &Cool Mist Ultrasonic ...
www.qvc.com/Sharper-Image-Dual-Tank-Warm-&Cool-Mist-Ultras...
QVCSharper Image Dual Tank Warm &Cool Mist Ultrasonic Humidifier ..... I've only had toclean the membrane once since I purchased it, and that's really not a big ...
How to Repair an Ultrasonic Humidifer ' eBay
Dec 14, 2015 | Humidifiers
Humidifier will produce mist for a min then stop If you look you can see it producing mist within but it will not come out of the top Walgreens cool mist ultrasonic humidifier
I have had times where my Crane humidifier won't produce mist if I haven't turned it on for several days (4+) or more. The water that sits in the reservoir may develop a film on the ultrasonic element which inhibits the creation of the mist to come out the top of your humidifier. I would lift off the tank and empty the reservoir. Then VERY GENTLY with a piece of paper towel, wipe the ultrasonic element (looks like a disk the size of a quarter at the bottom of the reservoir) to clean off any film. Then replace the tank and let the reservoir fill up the tank and try it again.
If your humidifier runs properly for a minute and then makes a whirring noise and goes silent (like the motor stopping), then it's a motor problem. The humidifier motor may have gone out of alignment due to bumping or rough handling of the humidifier when cleaning or emptying it. If that is the case, you will have to empty the humidifier reservoir, unscrew the base, and find the screws holding down the motor and check for misalignment. Loosen them a little and put it back together and try again.
Best of luck
thebqe
Feb 13, 2014 | Humidifiers
Bought this last year and don't have the manual. Can't remember how to fill the removable water chamber.
I would call or write to the warranty company: BW Consumer Services, POBox 8134, Elburn, IL 60119. 1-877-365-6274 and ask for the Walgreens Ultrasonic Humidifier 2055 user's manual. That is the information spelled out in the original users manual that come with the product.
Oct 18, 2011 | Walgreens Cool Mist Humidifier Humidifier
Sunbeam Ultrasonic Humidifier, model: 697-6
Located My Manual:
Hope this helps!
1. Remove tank from base. Turn upside down and unscrew filling cap. Fill tank with clean, cool, distilled, or tap water. Water temp should NEVER be too hot or too cold. Return tank to base and let sit for a few minutes. Be sure the filling cap of the tank is tightened firmly.
2. Plug power cord into a 110-120V AC wall outlet only. Turn power switch to "on" position. Power light will illuminate. Turn mist nozzle until desired level is being released. Aim nozzle away from furniture and walls.
3. Always turn humidifier off when water runs* out. Unit will continue to operate when tank is empty.
*Humidifier will run up to 12 hrs on low; 6 hrs on high.
DO NOT LET WATER SIT IN TANK FOR LONG. THIS CAN ENCOURAGE BACTERIAL GROWTH.
Place unit on level surface away from direct sunlight.
DO NOT ADD MEDICATION OF ANY TYPE INTO THE NOZZLE, BASE, OR WATER TANK.
ALWAYS LEAVE ROOM DOOR PARTLY OPEN. DO NOT MOVE, TILT, OR EMPTY WHILE OPERATING.
Mild bleach and water solution for cleaning, never detergent.
Clean every 3rd day during use. Clean after long storage
Humidity varies from room to room. Aim for 30 - 50% relative humidity. If windows/ walls fog or frost, reduce mist intensity. If room too humid, ventilate by opening door or window; adjust mist intensity.
Sep 22, 2008 | Sunbeam Ultrasonic Humidifier
Dec 31, 2007 | Sunbeam Ultrasonic 81696 Humidifier
Humidifiers Logo
64 people viewed this question
Top Walgreens Humidifiers Experts
Rich Brown
ray gallant
Paul Carew
Are you a Walgreens Humidifier Expert? Answer questions, earn points and help others
