Question about Klipsch Cs-500 Home Theater System Speakers
I have a Klipsch cs 500 that will not power on. Red light for the power button is all I get.
The red light turns blue for a second when I press it, and then goes back to red when I let go
Klipsch cs-700
my klipsch cs 700 subwoofer not work
Jul 19, 2012 | Klipsch Audio Players & Recorders
What is the pairing security code for xx3 plantronics
The following are detail instructions on how to Pair (sync) a Plantronics Bluetooth Headset to your Bluetooth Cell Phone:
1 - You need to go into the device you wish to pair it and turn the Bluetooth feature first.
2 - Then you need to place the headset in pairing mode so your phone will find it.
Find your model headset in the instructions below. Once the headset is in "Pairing" mode you will then need to follow the instructions in your cell phone or Bluetooth device's user guide on how to go it to your phone and search for the headset & pair it to a Bluetooth headset.
The passkey is 0000 (4 Zeros) except models M1000 and M1500 (see below for their number )
For the Plantronics M3000/M3500 (discontinued):
Pressing and holding down the volume up key and the talk button at the same time. Hold them in together until the indicator light on the headset starts flashing red then green.
For the Plantronics 510 Voyager:
Pressing and holding down the call control button and holding down the volume up at the same time until the indicator light on the headset starts flashing red then blue.
Plantronics Explorer 320,330,340 & 350
Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue.
Plantronics 655, 665
Plantronics Discovery 640, 645, 640e
Plantronics Pulsar 590/590e & 590A & a Bluetooth device:
Begin with the headset turned off. Press and hold the call control button then power the headset on and when the indicator light flashes red and blue, release the call control button. Once the headset is paired successfully the headset will flash blue.
pulsaradapter.jpgFor the Plantronics Pulsar 590 & 590A & the Universal Adapter: Begin with the headset turned off. Press and hold the call control button. Power the headset on and when the indicator light flashes red and blue, release the call control button. Turn the Universal Adapter on. Press and hold the adapter pairing/connect button for 7-10 seconds. When adapter starts flashing red and blue release the buttons. The headset and adapter will flash blue when paired successfully.
pulsar_260_128.jpgPlantronics Pulsar 260
For the Plantronics Pulsar 260, Begin with pendant powered on.
Press and hold both the mute/play/pause button and the power on/off/pairing button simultaneously. When the
indicator light flashes red and blue, release buttons. While pendant is flashing red and blue, use the phone menu to search for Bluetooth devices and select "260 Plantronics." When prompted for passkey,
enter 0000.
For the Plantronics M2500 (discontinued):
Start with the headset powered on. Press and hold down the call control button while also rotating the multi function dial upward (away from the light) until the indicator light on the headset starts flashing red then green. When prompted for passkey, enter 0000.
For the Plantronics M1000 (discontinued):
Hit and hold the volume/mute switch in until the indication light starts blinking.
For the Plantronics M1500 & A500 adapter (discontinued): Turn the headset on and the adapter off. On the headset push in and hold the mute/volume dial until the indicator light begins to flash. On the adapter press and hold the blue power button for 10 seconds. The light on the adapter will flash once after 3 seconds- continue to hold the power button for another-7 seconds until the light flashes red. If the pairing is successful, the headset will sound a tone and both the headset and adapter lights will turn off.
For both the Plantronics M1000/M1500 (discontinued): If you remove the battery cover from the headset and then remove the battery itself. On the Green PC board itself there will be a letter followed by 4 numbers. These 4 numbers are your personal PIN code.
You can also use the Plantronics Bluetooth Pairing Guide
Feb 05, 2011 | Cell Phones
How to connect with bluetooh
You need to:
  1. ensure the bluetoothicon1.png setting is turned on on the handset
  2. switch on the scala 500
  3. press and hold the scala 500 power button until the red and blue lights are both flashing (you have to hold the button in for quite a few seconds)
  4. now you can search for new bluetooth devices from your handset and it should find it to enable you to connect
  5. if it asks you for a code/passcode the default is 0000 for this headset
Sep 20, 2009 | Motorola Mobility Cardo Scala 500...
Supertooth one user manual
Charge your Supertooth one via the car charger or by attaching a usb/mini usb cable to your computer usb port. Need to charge for 4-10 hrs. Indicator light glows red (needs charging), orange (charging) or green (charged)
Power on: Press green button for 1 second. Indicator light blinks blue. A beep will be heard
Power off: Press green button for 1 second. Indicator light turns red. A beep will be heard
To pair with your mobile phone:
1. Press green button on Supertooth for 5 secs until indicator light blinks red/blue 2. Access bluetooth menu on your phone. Turn bluetooth on. Execute a bluetooth search. 3. Select ST ONE from list 4. When phone requests password enter 0000 and press OK 5. The handsfree kit is now ready for use 6. Clip Supertooth on sun visor of your car so that the microphone and control buttons are directed towards you.
To make a call: Dial number on phone. Supertooth will automatically connect. Indicator light is steady blue during call
To end a call: Press red button for 1 second
To answer a call: Press green button for 1 second. The bluetooth indicator will turn a steady blue.
To increase/decrease volume. Press volume buttons repeatedly up or down. They are situated between red and green buttons.
Hope this helps.
Nov 22, 2008 | Cell Phones
Plantronics voyager 510 headset
Make sure the headpiece is charged. Turn the headpiece off by pressing the little black button on top of the earpiece and holding for about 5 seconds. Turn the earpiece back on again the same way. You should have a slow flashing blue light on the mic boom. The base station will now try to find the earpiece and within about 20 seconds the red light on the base should be steady and blue light on top should be on.
If this doesn't work you may need to manually pair the earpiece to the base by pressing and holding the Listen Volume Adjust + Button and headset Call Control Button on the earpiece until the light on the mic boom flashes red and blue repeatedly. As above, the base station will now try to find the earpiece and within about 20 seconds the red light on the base should be steady and blue light on top should be on.
Nov 05, 2008 | Plantronics - Bluetooth Headset Plus Base...
Free Pulse
The following procedure will re-establish the communication link between the Headphones and the Wireless adapter, this is called "pairing". Before you start please make sure both the headphones and the wireless adapter are fully charged and turned off.
Note: The headphones and the wireless adapter come pre-paired from the factory.
1. Press and hold the power button on the headphones. See Figure 1.
Figure 1
2. Continue to hold the button down until the LED starts flashing red/blue in an alternating pattern. Release the button when the LED starts flashing red/blue. See Figure 2.
Figure 2
3. Once the headphones LED is flashing red/blue, press and hold the power button on the wireless adapter. See Figure 3.
Figure 3
4. Hold down the button until the LED starts flashing red/blue in an alternating patter. The LED will blink blue, then turn off for a few seconds then blink red/blue. Release the button when the LED starts flashing red/blue. See Figure 4.
Figure 4
5. Once both the headphones LED and the adapter LED is blinking red/blue, press the volume up button once on the headphones. See Figure 5.
Figure 5
Once the headphones is paired with the adapter, the LED on the headphones will blink blue once every two seconds. See Figure 6.
Figure 6
When the adapter is paired the LED will be solid blue. See Figure 7.
Figure 7
The adapter may continue to blink red/blue for a few seconds even after the headphones LED starting blinking blue. This is normal; the adapter may take a few additional seconds before the LED turn solid blue.
Once the headphones and the adapter are paired, it is not necessary to pair them again even if the batteries on both units are completely drained.
Additional Note: Repeated pairing will not improve the sound quality or give the headphones and the adapter a cleaner connection.
Mar 11, 2008 | Logitech FreePulse Wireless Consumer...
Klipsch Cs-500 Home Theater System Speakers Logo
Top Klipsch Audio Players & Recorders Experts
rhodesworks
Tom Chichester
Are you a Klipsch Audio Player and Recorder Expert? Answer questions, earn points and help others
