Question about NetGear MR814 Wireless Router
Please help I can't conect to Router MR814V2 with wireless card Encore ENPWI-G2
I'm not using any fancy setups or anything like that, my router sends signal good around the house, in fact one of my desktop computers conect well to the router, but this Encore ENPWI-G2 card doesn't want to conect, it picks up the signal but when I click conect i takes for ever and doesn't pick up an IP-address and won't conect. Please help...
  • 2 more comments
  • Elvis4th Oct 11, 2007
    It didn't work; it conects to other unsecure networks without a problem, but not to my Netgear.  I uninstall and reinstall my wirelesscard on my laptop about 4 times and nothing,  It picks up other unsecure networks like my friend next door, he uses a linksys wireless router and conects well to that network.   But I don't see the diference between the two, my netgear is also set up as unsecure wireless network as a matter fact; I reseted my wireless router to factory defults and still nothing.   I don't get it i;m confuse big time;  How come one of my desktop computers at home picks up the signal and connects well, and my laptop with this Encore card doesn't.
  • Elvis4th Oct 12, 2007
    Sorry, I didn't know how the rating works here.  i still need help, please!
  • Elvis4th Oct 23, 2007
    Ok, well is took this long because I  mess-up my computer and I had to reinstall windows XP,  nothing to do with the wireless card,  but now with a fresh install of windows xp home, all updates I still have the same problem, this card is the worse I’ve ever had.
    First try,
    My network SSID: is NETGEAR
    Network Authentication is: Open system
    Data encryption is: disable
    And yes I did reboot.
    Test it and no IP was assigned by the router.
    Second try:
    When I press connect to network,
    No ip address
    No subnet mask
    Nothing else
    Third:
    Yes, I?m using ENPWI-G2 with Encore wireless configuration Utility 1.5 version 1.0
    Still nothing.
    I also assigned a Shared-key and nothing,  reset the router to default settings and nothing, reinstall the wireless card and nothing;  but is weird that it will connect to other  unsecured networks without a problem,
     My system:
    Dell Inspiron 8100
    Intel Pentium III
    Mobile cpu  1000mhz
    1000 mhz
    512 MB of Ram
    Windows XP home
    SP2 with all updates
    Thank you for your help, I hope we can solve this thing..
    First try,
    Second try:
    No ip address
    No subnet mask
    Nothing else
    Third:
    Still nothing.
     My system:
    Dell Inspiron 8100
    Intel Pentium III
    Mobile cpu  1000mhz
    1000 mhz
    512 MB of Ram
    Windows XP home
  • Elvis4th Oct 29, 2007
    it didn't worked, Encore Wireless Configuration Utility HW.15 version 1.0” is running at Windows start-up, I also put in the IP address manually like you said and nothing the only thing I couldn't do was the ping I don't know where to put those numbers; or how to ping.  I starting to think that the drivever for this card is no good.  the ENPWI-G2 shows in the Device manager as Realtek rtl8185 54M wireless lan network.  I research something about this and I think it causes a problem in windows. I'm not sure.
    Brigadier General:
  • 6,966 Answers
On Windows XP, the OS will prevent a connection to an unsecured wireless network such as what you have.
You can try:
Double click on the red WiFi icon, click on the "Change the order of preferred networks",  Click on "Add", type in the Network name (SSID) of your router (you can get this by using the connected PC and log in to the NetGear's Webbased Interface), set Network Authentication to "Open", set Data encryption to "Disabled",  OK, reboot your PC.
Alternately, you can set the PC where the Encore ENPWI-G2 card is connected to manual configured settings rather than Auto obtain. Follow what is in the connected PC's settings except that the  last number of the IP add be different (ex. connected PC > 192.168.0.100, set the unconnected PC to 192.168.0.101, all the rest subnet, default dns be the same. Of course the 101 must not be in use, if double IP add, change to 102).
In some instances, you may need to use the Encore WiFi configuration utility (normally comes with the drivers in the installer CD) rather than the Windows buil-in WiFi Config utility,
Hope this be of some help/idea. Post back how things turns up or should you need additional information.
Good luck and kind regards.
Posted on Oct 10, 2007
  • 2 more comments
  • Louie  Role
    Louie Role Oct 12, 2007
    Thank you for your "Rating Locked! (?) Elvis4th has rated this solution as Not Helpful".
    There were 3 different methods posted, there are two more methods (a bit more complicated) , but obviously, you won't be getting those 2 from this poster.
    Cheers.
  • Louie  Role
    Post results of the first 3 methods:
    1. Network name (SSID): ?????
    Network Authentication: ?????
    Data encryption: ?????
    Did you reboot:
    Did you test?
    Was an IP Auto assigned by the Router?
    2. IP Address: ?????
    Subnet Mask: ?????
    Default Gateway: ?????
    3. The ENPWI-G2 card preferably is configured using the Encore Wireless Configuration Utility HW.15 version 1.0 and not the Windows built-in Wireless  Connection Utility. This normally comes with the driver CD and should have been installed. By chance are you using this one?
  • Louie  Role
    Louie Role Oct 24, 2007
    Hi again,
    On the Dell Inspiron 8100,  pls try:
    1. Set the WiFi card to "Use the following IP
      address”;
    IP address: 192.168.0.20
    Subnet mask:
    255.255.255.0
    Default gateway  192.168.0.1
    1. Verify that the “Encore Wireless Configuration
      Utility HW.15 version 1.0” is running at Windows start-up.
    Click on Start,
    Run, type “msconfig”,  click on Startup
    tab;
    It should be
    checked and included among the normal start-up programs If it is not, you may
    have a utility program preventing it from running/installing right such as
    Ad-Watch;
    Reboot.
    1. Verify that you can ping
    127.0.0.1
    192.168.0.20;
    192.168.0.1
    Pls post back results.
    Hi again,
    1. Set the WiFi card to "Use the following IP address”;
    ·        IP address: 192.168.0.20
    ·        Subnet mask: 255.255.255.0
    ·        Default gateway  192.168.0.1
    1. Verify that the “Encore Wireless Configuration Utility HW.15 version 1.0” is running at Windows start-up.
    ·        Click on Start, Run, type “msconfig”,  click on Startup tab;
    ·        It should be checked and included among the normal start-up programs If it is not, you may have a utility program preventing it from running/installing right such as Ad-Watch;
    ·        Reboot.
    ·        127.0.0.1
    ·        192.168.0.20;
    ·        192.168.0.1
  • Louie  Role
    Louie Role Oct 30, 2007
    To perform the ping operation:
    Go to Start, click on "Run",  type "cmd", in the window that opens, type "ping 127.0.0.1", wait for reply;  "ping 192.168.0.20", wait for reply; and "ping 192.168.0.1", wait for reply.  Each try should reply with something like:
    Pinging 127.0.0.1 with 32 bytes of data:
    Reply from 127.0.0.1: bytes=32 time<1ms TTL=64... (4 times)
    It is possible that the reason that in your Device Manager the
    ENPWI-G2 shows as a Realtek RTL8185 54M wireless lan network is because the ENPWI-G2 is using a Realtek RTL8185 chipset. This is most likely therefore the drivers are correct since in your initial post "Encore ENPWI-G2 card ...picks up the signal."
    Soon as your next comment/result is posted will figure out a way to defeat the built-in Windows config and force it to connect to your router.
How to get my password
Your default IP Address username and password are given below
Default IP Address: 192.168.1.1
Default Admin Username: admin
Default Admin Password: admin
If you are having further doubts regarding the Router please visit the following link (http://www.speedguide.net/routers/encore-enhwi-g2-80211g-wireless-router-54-mbps-618 ).Hope you are satisfied with my solution.Your valuable feedback would be appreciated.Thanks for choosing Fixya.
Jun 12, 2011 | Encore ENHWI-G2 Router
I need an installer for encore ENHWI-G2
Please Find the below details for Encore 802.11G WIRELESS LAN ROUTER
Feb 28, 2011 | Encore 802.11G WIRELESS LAN ROUTER...
How to make password for my encore enhwi-g2 wifi
There a great article at General Router Setup.
If you need more help post back!
Thumbs and testimonial are welcome!
Feb 23, 2011 | Encore ENHWI-G2 Router
How do i configure my Encore ENHWI-G2 router?
a user manual is here http://www.encore-usa.com/download/manual/ENHWI-G2_Manual.pdf Power everything off connect the modem to the WAN port on the router - switch on the modem - allow lights to settle switch on the router - allow lights to settle
you can loginto the router and setup according to your ISP instructions you should be able to log onto the ISP website and see what settings are required Often the default settings in a router and connected to a modem will work
Mar 14, 2010 | Encore 802.11G WIRELESS LAN ROUTER...
Installing encore enhwi-g2 router wuithout cd rom
You can configure the wireless router from unauthorized access by connect a LAN cable from the computer to the router and open a browser and enter the router's configuration URL IP address.
To secure your wireless network from unauthorized access please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Mar 07, 2010 | Encore ENHWI-G2 Router
Encore Wireless Router Wireless connection problem
You need to have a cable connection from the laptop to the router first then go to the router setting by typing something like 192.x.x.x which differs from router to router.This should be available in the manual or in many cases are printed underneath the router.Once you get to the set up page for the router then you can set up the encryption type and create a key which will be needed by the laptop to connect to the network.Hope this helps.
Dec 15, 2009 | Encore ENHWI-G2 Router
Cannot connect my laptop wlan to encore enhgi-g2 with my pc.
What is the Operating system on the laptop ?
If it is XP then in the bottom right hand corner you will find Wireless network connection ( looks like 1 computer monitor). Use that icon to connect to the wireless network.
If it is windows Vista, then in the bottom right hand corner you will find 2 computer monitor icon. Use that icon to connect to the wireless network.
If it is Windows 98/ME/2000 then use the adapter utility to connect to the wireless network.
For MAC you will see the AIRPORT icon at the top.
Check the wireless settings of the router first . Make sure that you have all the wireless settings of the router. If you are not sure about the settings, then open the router set up and check the settings.
Click Here
for step by step instructions on how to connect to the wireless network and troubleshooting steps
Dec 13, 2009 | Encore 802.11G WIRELESS LAN ROUTER...
It cannot detect the wireless detection
Hello Friend
Below is the link of User manual of Encore wireless router ,
A short reading of topic "Installation setup" of Wireless router Manual will give you a cross check from your configuration setup.
, Also check your Wireless Receiver card is properly working or not
Sep 06, 2009 | Encore 802.11G WIRELESS LAN ROUTER...
NetGear MR814 Wireless Router Logo
635 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
