Question about Pentair 1.0 Hp Whisperflo Pump
Pump makes humming noise impeller spins slowly
Pump makes humming noise , impeller spins slowly
  • 2,760 Answers
Sounds as if pump has stuck start winding switch , try giving Motor not the pump a sharp knock with a rubber mallet when you 1st turn on , this might jar it loose if not a new motor might be needed , if motor was larger then say 2hp then id say get it fixed at a motor repair shop due to cost saving but smaller sizes it's not worth it most times
Posted on Dec 11, 2014
2 Suggested Answers
john224
  • 1378 Answers
SOURCE: I have a 2HP Pentair Whisperflow pump that has
Thank you for posting your question here on Fixya.com.
It could be the pump is bound up but it is more likely the motor is failing. It may be a small part such as the capacitor or the starting switch, but could also be more severe such as the winding itself. You will also want to examine the shaft where it passes thru the pump and motor and look for signs of rust from a pump seal leak.
If you are not familiar with testing these parts your best bet would be a local electric motor repair shop to see if the motor can be repaired or if it would need to be replaced. They should also be able to ensure there is no pump damage.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Oct 26, 2010
Pump making a buzz noise but won't start up
it sounds like the motor has seized. if not seized, there may be something blocking the impeller. disconnect the power and try to spin the impeller
Sep 10, 2014 | Hayward Pool & Spa
My saniflo macerator plus has stopped working-it had been making a humming noise not draining-now it's not making a noise at all-what might be wrong please?
It could be a blockage in the blade, impeller or the discharge line. Also could be a defective starting capacitor, since the capacitor spins the blade and impeller, if the capacitor goes bad it will make the unit hum and not pump out the waste until eventually it shuts off completely and would not kick on and off at all. At this point, the capacitor may have to be replaced. You should contact Saniflo to order parts.
Aug 21, 2011 | Saniflo 002/005/007 Saniplus Toilet with...
Make a humming noise and spins very slowly
MINE DOES THE SAME. HOUSING IS CRACKED THAT ATTATCHES TO DRUM. WHITE METAL CANNOT BE REPAIRED.
Jul 25, 2010 | GE WPXH214A Front Load Washer
Saniflo permanently on,
If the blade and impeller spin freely by hand after removing the obstruction but does not pump out the waste after assembling the unit back together, then could be a bad capacitor, since the capacitor spins the blade and impeller. If the capacitor goes bad then it will just make a humming noise and not pump the waste out.
May 20, 2010 | Saniflo & Saniplus& Macerator Pump
Leaks when filling
It could be a swollen impeller inside the pump causing it to wear a hole in the plastic housing and making the humming noise .It,s fairley easy to replace as it clips on to the end of the motor.Hope this helps.
Nov 28, 2009 | Whirlpool LSR5132PQ Top Load Washer
Maytag Neptune purchased brand new in 2007. Tumbler won't spin and water doesn't get pumped out, all I head is a humming noise coming from the water pump. I opened the back and could feel the water pump...
There is something jamming the impellers in the pump (coin, nail, bobby pin, ect.) You need to manually get the water out, remove the pump, and see if you can find and remove the obstruction. If you find something in the pump and remove it, check the impellers before you put the pump back in. There are 3 plastic impellers, make sure none of them broke off. If they did not break off, your good to go. If one or more broke off, you will need to replace the pump, you cannot buy just the impellers. good luck.
Oct 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Drain pump makes rattling noise when operating, pump has been clened.
I would look at the pump impeller and make sure there are no broken or missing blades. Hard objects can make it to the pump and cause damage to the pump impeller blades. Also, the impeller must spin freely. If the impeller has broken/missing blades or if the impeller won't spin freely, the pump is defective. Really sorry for your trouble and I hope this helped. Best wishes.
Sep 14, 2009 | Washing Machines
Roper wash machine ras7133kq1
no theres something in your pump,,it up against the impeller in your pump.....onthejob
Jan 31, 2009 | Roper RAS6233KQ Top Load Washer
Frigidaire front washer has power but won't fill up, drain or go through correct cycles
You'll very likely have something caught in your drain pump. First set the washer to drain and spin. If you hear a hum or grinding noise and the water in the tub isn't draining or it's draining slowly you have something in the pump. If you take the rear panel off you'll reveal the drain pump at the right front corner or maybe middle on this model. if you empty all the water from your machine you can take off the spring clamp (this can be tricky) attaching the thick rubber hose from your tub to your drain pump. (you may want to have some old towels ready) With this off you can feel around for what's blocking the drain pump's impeller. You may want to take the screws out that secure the drain pump to the base and the other spring clamp that attaches the drain hose to the drain pump. Good luck!
Oct 15, 2008 | Frigidaire ATF6000ES Front Load Washer
There is a noise (hum) when the spin is set. No spin.
probably pump plugged if that is a front load remove bottom panel pump has a clean out port clean thoroughly and retry is still only hum pump impeller may be jammed or damaged ..removing pump will allow better acess to impeller area
Aug 22, 2008 | Whirlpool Washing Machines
Pentair 1.0 Hp Whisperflo Pump Logo
182 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
