Question about Hoover UH20040 Vacuum, Sprint Quick
My hoover Sprint quick vac stop working while I Was operating It.
Hoover vaccum u6434-900 switch replace
2 screws remove the handle. 3 screws in the holder for the hand-held beater, and then you can see to the power switch (black with read on/off switch and two copper leads).
Remove the wire clips. Find some safe way to connect the two wire and plug in/out the vac quickly to see if the motor runs. If so, then the switch is bad. Squeeze the ends and push it through to remove.
I found a cheap replacement online from. http://www.vacpartswarehouse.com/Hoover-On-Off-Switch-p/28161075.htm
I'm not associated with them, I just found them quickly and the part quickly.
I love the vac, so it's worth a few buck to fix it.
Nov 02, 2011 | Hoover U6437-900 / U6439-900 Windtunnel...
Operationing instructions for hoover model fh50020rm carpet clearner
I have an Hoover Steam Vac Carpet Cleaner Model# FH50020RM, it's not working. The water is not coming out and not retracking the water.
Jun 05, 2011 | Hoover Vacuums
Need operating instructions for Hoover Steam Vac model # F5905-900
Use Google and type this in the search box:
hoover steamvac manual filetype:pdf
This will give you several models of manuals to look at and I'm sure one of them will be very close to the model you are seeking, which will be enough to be able to use it.
Here is one that I quickly found using this method:
http://www.hoover.com/pdfs/manuals/F5857955.pdf
Please rate this solution! I hope this gets you off on the right foot.
Thanks,
~PCF
Mar 05, 2011 | Hoover Vacuums
Do not know how to use Hoover Steam Vac Spin Scrub
Hoovers website, Hoover.com has them free to print.
Jun 13, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Dirt Devil Extreme Quick Vac - Won't turn on
Check that the filters are completely clear and not blocked - especially the top filter on top of the bin assembly. If its clogged completely brush it free of dirt and then reassemble. Make sure the inner cone filter and mesh filter is also completely clean. Then check the hose and main dust channel - something is clogged that makes this machine overheat and stop working - and often with this model (Hoover also make it in the UK under the Alyx name) its down to clogged filters or small clogs of dust in the dust channels.
Don't forget to rate, thanks.
Mar 06, 2009 | Vacuums
Hoover Steam Vac
how do i get a manual on how to operate my hoover steam vac dual v spin scrub heated cleaning machine. i bought it used at a flea market and they did not have the manual. can you help me.
Thank you nessa
Oct 11, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
Hoover Steam Vac Clean Surge
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=407245
Posted by just a brat on Feb 22, 2008
I can not seem to get the attachment for the upholstery cleaner to operate what am i doing wrong????
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
The attachment works on the suction from the Hoover Steam Vac and it’s either a straight suction tool or a revolving brush, check the front of the machine to see if the is a switch to turn on and odd, also before you attach the upholstery tool check the end of the hose for suction, it may be that your upholstery tool may be clogged or the brushes are not spinning and a part may be broken. Feel free to check with you local vac dealer or a new or a good used part if you find out what is wrong. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Don – The Vac Man
Go Ahead. Use Us.
Feb 22, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover UH20040 Vacuum, Sprint Quick Logo
215 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
