SOURCE: How do I get past this Drivelock HDDBay password
Basically, for most of the notebooks, there is a Password provided to secure the data in the Hard Drive and restrict it from un-authorize access.
However, if the Drive Lock Password is set and forgot, it is not possible to unlock the Drive without the password.
However, you can try contacting any of your Friends who is familier with Hard Drives and is a technician who should be having some advanced methods to remove the Password or the Circuit Board of the Hard Drive.
Hard Drive is locked. Needs password from whoever you got it from or replace it with another hard drive.
SOURCE: DriveLock HDD Bay Password
hello,
Will your NX6110 allow you to get into the Bios before the drive lock password coes up? If it doesnt and you dont know the password, you have two options. One being to send the laptop off somewhere to get the password an pay thru the nose. The other is just to buy another hard drive and re-load your system. Those passwords are build into the hard drives and there is really no way to get the password easily. You could of course pay for a machine that will hopefully get your password, but why pay all that money just to use it once, or twice. It comes down to the facts of how importand is the data on your hard drive?
SOURCE: i open my laptop i got the message " Drivelock HDD Bay password"
seems like the access to your harddrive is password protected at BIOS level,
try another hd.
if same message occurs, please renew your request at fixya!
SOURCE: Is buying this Hp Compaq 6910p Battery a wise decision?
I have bought a couple of batteries from them before. They work just make sure that the voltage of the battery. (10.8v) matches the voltage on your battery. Also make sure that the mah 6600mah is greater or the same as the battery that you have. The mah is the mili ampers per hour (in other words the fuel) the bigger the mah the longer your battery will run. I also find ebay a great place to buy hp batterys from. Just make sure that they are oem hp and not a generic knock off and you will be fine and use the same rules from above. and also make sure they will fit your model number. I hope this helps
thanks
Steven.
The Compaq drivelock feature is designed to protect the data on a laptop's hard drive by assigning a password.
This password protects the drive in the event the laptop is lost or stolen, but can be removed when necessary.
Knowing how to remove or change the drivelock feature can make your Compaq more useful and more secure.
Power on your laptop and enter the drivelock password you established when you turned the drive protection feature on.
You will need this password to access the drive and turn off the drivelock feature.
Click the "Disabled" option in the drivelock menu.
This will turn off the drivelock feature on the Compaq laptop.
Do not enter anything in the password blocks.
Log on to the laptop, click the "Start" button and choose "Shut down." Choose "Restart" from the menu to power cycle your laptop and verify the drivelock setting is off.
If the drivelock setting is off you will not be prompted for a password when the laptop starts up.
hope this helps
