My Polaris EOS 3 command center keeps shutting off. When I flip the breaker off and on, it comes back on, but then goes black again within a day. Do you think I need to replace the PVE12 activator b
The pool was installed in 2007, so the unit is about 6 years old. I did take the cover off of the command center and when I reset the breaker, there is a green light blinking on the circuit board. Not sure if that is normal or not. Any suggestions would be appreciated.
  • 1694 Answers
SOURCE: mitsubishi ws-55613 55in.
Four bad capacitors in DM module = common repair for
qualified Mits tech.......................T.
Posted on Nov 22, 2007
SOURCE: Flashing green light
sounds like the bulb is blown. Its the main lamp in the side of the set. you will see a small door there once you take it off there is 2 screws to remove and bulb in its casing will slip out. by looking at the buld you should be able to see if its blown. You should get approx 3000 to 4000 hours from a bulb but if you are a heavy user of this tv with higher contrast the bulbs dont last. i have this model tv myself and ive been told that they are not designed to be run for long periods of time and dont use gaming machines on them. Shame they dont tell us this when we are buying them.. hope this helps you Craig (crazy@woosh.co.nz) let me know how you get on
Posted on Feb 25, 2008
Slinteriors
  • 8617 Answers
SOURCE: Blinking green power light & shut down
There are (4) 1000uf @35V capacitors all together on the DM board that need to be replaced some models have 1000uf @ 16V but they are all right beside each other and all rated at 1000ufs the voltages will be stamped on the capacitor along with the uf ratings.
Posted on Apr 07, 2008
myterminal
  • 178 Answers
SOURCE: Display powers of with power up of AVC
Actually, I have heard about this kind of a problem before too.
Let me enquire more about it and I will let you know.
Posted on Apr 26, 2008
SOURCE: No picture, green light blinks then short buzz sound
I had the same problem with my TV. I called the Zenith support line and found out my model (E44W46LCD) had a manufacturer's defect and Zenith said they would be taking care of it. I am in the process of waiting for them to let me know how, but they took all of my info and said they would be responsible for fixing it.
Posted on Jul 09, 2008
My 2015 viking spa circuit breaker keeps kicking off when i flip the switch, what do I need to do?
There is a capacitor on or near the motor that is most likely bad or the centrifugal switch inside the motor is intermittent. Service tech is needed
Sep 14, 2017 | Heating & Cooling
Unit powers up for 5- 10 min good picture....then it goes black power light goes from green to red and flashes once and solid and repeats pattern .........if i go up to unit and push power off and back on...
There is circuit problem inside. For safety reasons power might get shut down! Unless the fault is rectified, this problem will continue. Do not attempt switching ON again & again. Get authorised service center assistance.
Apr 20, 2010 | Televison & Video
2004 polaris sportsman 700, shuts off while riding.
I have a 2004 700 carb that shut off while riding and then would start up 3-5 minutes later after many nights working on it Ifinally figured it out no help from any dealer. There are 2 circuit breakers under the front rack mine were very rusted, Replaced both never had the problem again. My situation was always only when the lights were on.
Hope this helps
Aug 07, 2009 | Polaris ATV
POLARIS PB-4 3/4 HP BOOSTER PUMP -- body of pump very hot, too hot to hold hand on. 20 amp breaker gets very hot also. Has not tripped the 20 amp breaker yet.
A motor can run that hot and still be within the temperature it can handle. It likely has an internal overload device that will shut it off if it exceeds that temperature. If you see something like "thermally protected" on the motor nameplate, you are ok. If it is getting noisy as it runs it may need servicing.
Jun 08, 2009 | Polaris Pb4 - 60 Booster Pump
Polaris booster pump overheats and trips the breaker
The motor may be repairable. Check with local electric motor repair shops in your area. The motor may need to be replaced though and if so, we sell it at www.arrowmotor.net
May 29, 2009 | Polaris Pb4 - 60 Booster Pump
After my ciurcut breaker was fliped on and off my samsung 46" 71f has had problems
Ive had a element lcd tv that i bought, out of nowhere the power cut off, so i went to flip the breakers, and since i had the Tv still plugged up, after i flipped the breaker to get the power back on. Power came back on, went to go turn on the tv, the light would be on but nothing on the screen no picture. Sometimes it would come on a little bit after awhile but that is it. So yes i do recommend you have there tech come out and fix it. Before you ever flip a breaker off and on, unplug all computers, tv's, anything in that nature before you do it.
Oct 31, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Sidekick 3 wont stay shut.
prod7-
Flip the LCD screen open, look on the backside of lcd assy, in the top center is where the magnet goes. You will need to take the front lcd cover off to put it back on.
Sidekick 3 LCD Cover Screen Replacement
May 03, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
