Question about Titan Sport & Outdoor - Others
Titan xt250 sprayer is leaking oil
I just bought the titan xt250 airless sprayer. i assembled it according to directions but if i tighten the inlet hose too much the bottom falls off and it won't run. if i leave it loose i get an oil leak. HELP!!!
mmptruck
  • 124 Answers
SOURCE: Oil Leak
The oil leak at bottom of radiator could be oil cooler and/or supply hose. Try check closely for wettest area .
The other leak could be thermostat cover, it only uses a sealing ring and is prone to leaking after time.
Posted on Aug 04, 2008
  • 102 Answers
SOURCE: coolant leak from left side of engine block running down oil pan.
when you say left side are we talking passanger side or drivers side if drivers side which is my guess most likely your waterpump seal is leaking
Posted on Mar 22, 2009
  • 62 Answers
SOURCE: Sprayer leaking from inside handle mechanism
although it is possible that the spray head has gone bad, it is more likely that the diverter mechanism inside the kitchen faucet needs replaced. When this part is defective, it allows full pressure from the faucet to go to sprayer head even though the sprayer is not triggered. The sprayer is not designed to handle full pressure when it is not spraying.
Posted on Jun 12, 2009
  • 13 Answers
SOURCE: 1994 GMC Safari Oil leaked
Check the oil filter adaptor bracket. My 1993 Safari had the same problem, and the adaptor bracket and seal were bad. Replacement fixed the leak.
Posted on Jul 08, 2009
rylee_smith
  • 8619 Answers
SOURCE: Bosch dishwasher is leaking fresh water from water inlet assembly
Hi
Thanks for using FixYa. If you have nuisance water leaks around the base of your dishwasher, you may be using a detergent that is causing too much suds. Cut back on the amount of detergent you use, and see if that makes a difference.
Water that spills through the door vent is usually caused by improperly loading dishes. Leaks from the door itself may be caused by a faulty door gasket or door tightness adjustment. you should check the main tub seal, the door latch, the door gasket, the water-inlet valve, and the fill and drain hoses.
Also make sure the dishwasher is sitting level (you can adjust the front feet up or down, and many units have some type of levelers at the rear).
Water under the dishwasher may be originating from a leaky hose or loose hose connection. Remove the lower front panel, and check the hoses. The pump seal may be defective, too; replacing this is a job for an appliance repairperson.
An older dishwasher may corrode at the bottom, but this is fairly uncommon. If this is the case with your dishwasher, it's time for a new one.
Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Nov 11, 2009
What would make a paint sprayer lose suction while beeing used
Wore out packings You have a little titan
Check to see if you have flat valves or balls flat valves are better but the packing kit is around 60.00 dollars also check the prime knob it also has seals .
The KEY is to always clean the mechine after use and oil the pistion with throught oil and it will last forever if you repack it every 2or 3 hundred gallons or so and use good tips
Mar 01, 2015 | Titan Advantage 100 Airless Paint Sprayer
Hi my titan 400 its leaking from the oil cap area, I reduced pressure and still leaking?!
Hi Kamil,
Your Titan Advantage 400 needs to have its piston seals replaced which is why it is leaking into the oil cup. They are self-adjusting static packings. This is a classic airless wear situation; paint is abrasive. Its easy to do it yourself and if you do, you need to examine the piston; if it is worn or scored it must also be replaced otherwise it will wear out the new packings fast. All the parts to repack it can be purchased in a kit.
Jan 13, 2015 | Titan Advantage 400 Airless Paint Sprayer...
What type of oil does the 440 titan impact use
No oil! but you have to use throat seal at the pump piston
Jan 04, 2015 | Titan Airless Sprayer Owners-service-parts...
How to repack the sprayer
The packings are static and self adjusting. The repack kit includes the piston so it replaces everything. Just buy the kit and follow the instructions. Try Scott at American Airless on 770 4771337.
Aug 25, 2014 | Titan Paint Sprayer. Advantage 200 Airless...
Does a titan airless paint sprayer require oil
Yes throught oil to be filled at the top of the pistion read on mechine ware
May 03, 2014 | Titan Paint Sprayer. Advantage 350 Airless...
Pumps in up stroke but not in down stroke
Single stroking: You have something stuck in one of the valves, probably the inlet valve.
Sep 25, 2013 | Speeflo Titan PowrTwin 6900 Plus D.I....
Titan 640i wont prime
If you still have a problem with a Titan 640i please give us a call. We introduced this sprayer to the UK back in 1985. Lion Industries UK Ltd 01543 251 560
Dec 31, 2012 | Titan 440 Impact Airless Paint Sprayer...
My titan 330 airless paint spray will not shut off while primming
Airless paint sprayers should not turn off while in prime mode. As long as the prime valve is open the motor can pump paint but the system will not build any pressure. Once the prime valve is closed the pump should pump paint into the hose until it gets to the pressure level required to turn the motor off. If the pump does not turn off with the prime valve closed, it could be that the spring in the valve is weak and won't hold the valve closed under pressure. If the hose is up to pressure and the motor just keeps trying to pump paint, you may have a bad pressure sensor or it is disconnected from the circuit board.
Jul 10, 2012 | Air Tools & Compressors
Can't find a part #
http://www.chpower.com/webapp/wcs/stores/servlet/chCat_10051_10001_10661_-1
service center, find a part. write inlet outlet valve
May 15, 2010 | Campbell Hausfeld Airless Spray Guns &...
Sport & Outdoor - Others Logo
16 people viewed this question
Top Titan Sport & Outdoor - Others Experts
Bill Eager
Are you a Titan Sport and Outdoor - Other Expert? Answer questions, earn points and help others
