Our soniq l32v11b tv takes 10 minutes before the picture stables then it's perfect.
Tv takes 10 minutes for picture to come clear then picture is perfect. What could be wrong?
jomabug76
  • 1148 Answers
SOURCE: fuzzy picture on my 42" akai lcd tv
Check the menu ,,it should have a option ,,called convergenge ,,that realigns the colors,, and some tvs have geomagnetic correction,, good luck
Posted on Oct 05, 2008
  • 4 Answers
SOURCE: Picture won't come in clear until TV "warms up" for 15 minutes or more
Change the capacitors first per the instructions in the link below. Symptoms could be anything from high-pitched hum to no picture at all. On these defective models, I would start at the caps and work back. It won't hurt to replace them anyway.
http://www.fixya.com/support/r741402-polaroid_flm_373b_lcd_tv_black_screen
Posted on Nov 13, 2008
premtech
  • 934 Answers
SOURCE: I have a samsung 52 inch lcd tv and it takes about
T-con or timing control board is defective or the syscon link board that feeds the panel itself... For that problem you'll need to take it to a shop - the whole Tv has to come apart to get to the T-con so it can be properly tested...
Good Luck!
William Rayburn, CET
Premium Technologies
Posted on Oct 05, 2009
  • 21 Answers
SOURCE: Samsung 4061F 40" LCD TV
To all who are having power supply issues: Samsung is now acknowledging a problem with faulty capacitors. I called 1 800 726-7864 and they said they would repair certain out-of-warranty TVs if the problem is related to the capacitors. I just called and they are sending a service rep out to diagnose the problem.
Posted on Feb 22, 2010
  • 8457 Answers
SOURCE: I must turn on and off multiple times for picture
Ur Tuner signal board have problems,must be change.The problems u discribing,only two boards cause this Power or Tuner boards.
Posted on Mar 30, 2010
Testimonial: "Solid answer. Thanks chu."
Soniq PT42SH plasma TV power on. No back light and no pictures
SONIQ LCD TV REPAIR Blank flickering screen Energy ...
? 1:32
https://www.youtube.com/watch?v=FUqdi7lwmcE
May 29, 2013 - Uploaded by WastedOne2
Fix ya Soniq Tv once loaded up hit menu button then channel + then ... SONIQ LCD TV REPAIR Blank flickering screen Energy Saving Mode Issue ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't turn on] ... Common easy LCD TV fix: bad picture screen rainbow colors - Duration: 4:04.
No Image & Blank Black Screen Flashlight Test - YouTube
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to Fix LCD & LED TVs ... Most LED TVs will have a t-con board, a power supply board, a main board and an LED ..... SONIQ Australia 1,718 views.
Soniq PT42SH plasma TV power on. No back light and no ...
Jan 08, 2016 | Televison & Video
Flashing Green Screen and lag
A green screen display to plasma displays is a bad symptom. It might be a panel defect. You just get into the site named 'Electro-help' by search, and get the site begins with 'electronicshelponline.blogspot' as its URL. There is screen shots to different faulty screens to plasma displays, which I can't include all of them this by this window. Check them and make confirm.
May 24, 2013 | Televison & Video
Samsung LN-T4071F picture starts clear, then gets grainy as the TV stay on.
I have samsung TV 40 inches flat screen comes on the picture ok but within 10 minutes the picture goes black and white
Jan 20, 2013 | Samsung LN-T4061F 40 in. LCD HDTV
Onkyo TX-SR604: Video in from cable box has taken increasingly longer to display a picture.
I would at least disconnect all units from power for a while and then reconnect to allow the units to reboot.
Oct 30, 2012 | Onkyo TX-SR604 Receiver
Hello, Well I have a Jensen antenna( Perfect for HDTV). How do I tune the antenna into a Soniq LCD TV Model E16Z10A. I can only get SBS channels and a few 9 channels. I have done everything! I need your...
I have the same problem with my soniq hd tv i got a digital antenna that plugs into the power and i have also tried the roof antenna and neither worked.. Could it be the tv?
Jan 01, 2011 | Televison & Video
Bought a soniq hdmi cable for lap top to tv & set up but can't get sound from tv, picture is perfect
You need to go to TV on screen HDMI sound set up, you can choose AUTO or select the sound to be through HDMI or through the audio ports, check your laptop HDMI sound set up also. I would set them to 'AUTO'
Dec 01, 2010 | LG Televison & Video
Sony WEGA KV30HS420 shuts itself off
Sony KV-30HS420 TV shuts off, indicator light blinks 7 times
Sep 23, 2009 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Hitachi Rear Projection TV which is all fuzzy for about 10 minutes. Once ther TV heats up, it has a perfect picture.
Hi...
If youre comfortable with taking the rear panel off UNPLUG the AC first and wait several minutes. Back off then spray out dusty areas with a can of "Dust off" or compressed CO2..Walmart and Staples and radio shack sell the stuff.
Dust is a major enemy of TV circuits
Take Care,
Scott
Jan 02, 2009 | Hitachi 46F510 46" Projection HDTV
57h82 toshiba projection tv
Hyper board bad = No longer available part # 23148024 PTS
rebuild only...send core in........57H82..............................T.
Part # is specific to model !....
Mar 20, 2008 | Toshiba 50H82 50" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
