Question about Behringer PMP2000 800 Watt 10 Channel Powered
How to connect speakers and monitors on a pmp2000
Where are the main speaker cables connected to in a behinger europower pmp 2000 mixer amp
The Behringer PMP2000 uses Speakon jacks on the speaker cables. The outputs are located on the back panel. Which ones you use is determined by how you configure the mixer. The Main inputs are located on the right side of the face of the mixer.
Dec 31, 2014 | AMP Music
My Behringer pmp2000 is now only giving an output through the tweeter horns of my speakers so the sound is very tinny. Any suggestions as to what might be wrong?
Your woofers are probably blown. To check plug a 1/4 inch or speakon into the speaker cabinet with the two bare wires exposed on the opposite end and touch with a 9volt flat battery if the driver doesn't move ir sound it's blown
Dec 15, 2014 | Behringer PMP2000 800 Watt 10 Channel...
Behringer PMP 2000 lost audio output
Sounds like a few capacitors have just blown, easy fix if your handy with a soldering iorn,
Aug 01, 2014 | Behringer PMP2000 800 Watt 10 Channel...
How to set up a behringer pmp 2000
http://www.behringer.com/EN/Products/PMP2000.aspx
You will find the manuals on this web page under "Documentation"
May 09, 2014 | Music
My band plugs into the input channels on the SX2442FX mixer, which we then hook up to the PMP2000 to use as a PA. Since the SX2442FX is not a "Powered" Mixer, I figured that we should be going...
Either way will work, however your friend's method probably would be slightly better since it goes through less stages within the PMP2000. The "left and right power amp inputs" are the INPUTS to the power amp in the PMP2000 and hence are the best places to connect the mixer if using the PMP2000 as only a power amp. Note doing this will LIKELY disconnect any other input to the PMP2000 from the power amps in it... that is all the preamps in the PMP2000. DO USE TRS cables!!! and power both units from the same receptacle to avoid ground bounce.
Aug 25, 2011 | Behringer Sx2442fx Eurodesk 24channel...
I have recently bought a Berhinger PMP4000, I set it up with an SM58 through mic input 1 but can get hardly any volume ? Please can you advise where I may be going wrong ? I am running the power amp with 2...
Things to check: You are using XLR mic cables... You have the speaker switch in the uppermost position A and B mains... the mute for that channel is off... For an SM58 the TRIM for that channel will be at about 3 o'clock to near full on, depending on vocalists voice strength... The CHANNEL fader will be at around -5 to 0 (75% up)... The MAIN fader will be around 50 to 80% depending on how big a room you are in. I assume the Peaveys are on separate channels IF they are 4 ohm speakers. The A and B outputs have a MINIMUM load of 4 ohms. With 4 ohm speakers you can get 400 Watts per side... about 250 Watts with 8 ohm speakers. DO NOT SET SPEAKERS to bridged mode... ALSO please read my tip on Fixya about a hazard of channel A polarity if you use 1/4 inch plugs on the ends at the speakers. The SLEEVE of channel A is the HOT, not the tip and grounding the sleeve can blow the channel A amp.
Aug 21, 2011 | Behringer PMP4000 / B212XL Mains Monitors...
How can a PMP 2000 be patched so that both internal amps are used to power the monitors, and the mains are sent from the mainpre-out to another power amp, while using one internal eq for the mains, and the...
No you can't quite do this since the EQ's are right before the power amps in the signal flow. The monitor output would drive two 8 ohm speakers daisy chained at roughly 300 watts RMS... I can't imagine needing more than that for a venue that is within the capabilities of this unit.
You can drive both power amps by the monitor output by setting the mon/main function on the switch and using a short TRS cable jumper between MONITOR PREAMP OUT and the RIGHT POWER AMP INPUT jack. Drive your mains from the LEFT PREAMP OUT. The EQ's will ONLY affect the monitors. Use an external EQ if you need to EQ the mains with this connnection. Use TRS balanced cables to the main amp and CONNECT all interconnected equipment to the SAME power source or receptacle, even if it means running an extension to the mixer.
Apr 05, 2011 | Behringer PMP2000 800 Watt 10 Channel...
Behringer pmp2000. I have Yamaha passive monitor and can not get sound out of it. any solutions.
The outputs are usually just for the front of house speakers - the monitors usually need their own amps.
Check the manual.
You have 1200 watss of power - so keep the volumes REALLY LOW to try things out - otherwise your speakers could be blown by the amp.
Mar 07, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
I Have a Peavey XR 600B mixer. There are only 2 inputs in the rear for speakers. I want to add more speakers to be used as monitors or just have extra speakers. How can this be done? I only have...
First off it's outputs to your speakers. If you had an extra set of powered or amplified speakers you could "Y" cable your speaker outputs. Your passive speakers won't work without an amp. You really need powered speakers or an amp for your extra speakers. (if you had powered/amp'd speakers you could run them off one of you "aux" out for monitors. Do not daisy chain your speakers connecting twi together, you'll change the resistance/ohms and damage your speakers. Trust me, I do this for a living.
Mar 06, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
Behringer PMP2000 800 Watt 10 Channel Powered Logo
41 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Are you a Behringer Music Expert? Answer questions, earn points and help others
